11-12-2009, 17:22 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In a point from Universe! Age: 40
Member: 235325 Status: Offline Sonork: 100.1593552 Thanks Meter: 523 | Genie_hardware pcb;info's! Thanks! |
11-12-2009, 18:12 | #3 (permalink) |
Member: 235325 Status: Offline Sonork: 100.1593552 Thanks Meter: 523 | And why do You say this?Because my serial it can be seen by others?I forgot to cover it;with this problem what can say in this thread?the serial is also seen in the log of other user of genie. http://forum.gsmhosting.com/vbb/showthread.php?t=858928 Can You be more clear?In the post it wasn't about security serial what I asked. Last edited by Burebista; 11-12-2009 at 18:14. Reason: correct the sentence |
11-12-2009, 18:21 | #4 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Yes
Member: 192652 Status: Offline Sonork: No Thanks Meter: 121 | No no, not because of this, how you can see there is two board, if you split them, the data on eeprom is gone ... ps. you can try to start the bb5notp, and you will get error 26... |
11-13-2009, 00:32 | #6 (permalink) | |
Member: 235325 Status: Offline Sonork: 100.1593552 Thanks Meter: 523 | Quote:
I've opened the clip twice and nothing happened;it's working OK without errors. | |
11-13-2009, 00:38 | #7 (permalink) |
No Life Poster Join Date: Dec 2000 Location: J.A.U - Just Another Unlocker Age: 43
Member: 2878 Status: Offline Thanks Meter: 9,123 | i have also dissasebled my genie complelty i have soldered in aa better reset button, cause the original was fast demaged and the hole was to smal, i have used a power button from a old nokia board. the big metall one, this are perfekt reset buttons for genie. also i have soldered in a bigger speaker to get more volume from it. i have soldered two original nokia BLC-5 batteries instead of china one. and if it where possible, i would solder in a siemens S65 display. this displays are perfekt to control and have good resolution, also open source drivers are available. is it possible to make modefikations on genie os ??? btw. genie seems to have jtag port connector, so if batterie is demaged it should be no problem to rewrite the secruity key or not? br. hari |
11-13-2009, 18:03 | #9 (permalink) |
No Life Poster Join Date: Feb 2000 Location: UK
Member: 1024 Status: Offline Thanks Meter: 5,510 | Hi, Yes the backup battery is keeping the PCB alive non stop, but unless you short/remove the battery - there is no way you can destroy the device key (even soldering of components is ok, not that I imply you have as good as me soldering skills - don't do it please ) It is similar technology like UB, but rated life of the battery is if you suck some current from it. Our design uses something of 1-50 nA, which is basically open circuit for this battery. Not sure what caused UB problem - faulty batteries or too much consumption from the Dallas. We had some problems as well - all related to the sweat shop Alan used to assemble not soldering some batteries properly. The device could be restored by the recovery bootloader or in worst case scenario - the usb rom driver. Regarding adding new LCD - it is not easy as it has to be SPI and needs to have video ram buffer on board (like the current one). BR, Alex |
05-01-2011, 20:52 | #10 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Somewhere in the World Age: 54
Member: 9848 Status: Offline Thanks Meter: 144 | Assumed this internal battery of an two years old Genie will be exhausted in e.g. 5 years - will there a possibility to revive the Genie by reprogram the device key? |
12-18-2022, 21:34 | #15 (permalink) | |
Freak Poster Join Date: Nov 2010 Location: romania, brasov
Member: 1439020 Status: Offline Thanks Meter: 16 | Quote:
I know it is 2022 but I have a genie universal clip and the current of the CR2032 battery is at 3,098V so I assume it is still working. When running bb5notp I get error 18 I would like to replace the battery with a new one and I would like to ask if something goes wrong, could you provide paid support? | |
The Following User Says Thank You to -Scypax- For This Useful Post: |
