Help me !!! My FLS5 Emu On genie error !!!!!!! 3 Attachment(s) after trying a variety of ways including reinstall WINDOWS I finally have to yell resort story: My Genie clip error on the emulator FLS5 because the other work, such as: * No BB5 TP * Genie Plus * NK4 Ccalculate * Nokia Contact Services * Flash BB5 Via USB with Phoenix except that all the software interface FLS5 such as: * PM Tool * Phoenix Software GenieFTP but still can access to the server all the previous work only 1 week later this error so I screenshot: http://forum.gsmhosting.com/vbb/atta...1&d=1250661293 http://forum.gsmhosting.com/vbb/atta...1&d=1250661293 http://forum.gsmhosting.com/vbb/atta...1&d=1250661293 Steps like I do:
http://forum.gsmhosting.com/vbb/atta...1&d=1250661293 This error means VPP not connected. Best Regards Alan Tan |
and connect with BB5NoTP |
Alan Tan, this error is not as not connected to VPP, the problem in the emulator FSL-5, and you yourself know about it, I use a 10 pin cable GPG and this error is constant. |
this error is not as not connected to VPP Have you solution for this froblem?? |
You should use Phoenux 2008, this is the solution 2009 is not supported :( |
When NEW phoenix will be supported ???? |
Forget about FLS5 emu on phoenix flashing , use other tool !! |
I have 2 brand new packs for GPG cables, the few cables i have tried for flashing and the VPP was rooted from RJ-45 to the battery case, but inside was not soldered to the pin, it was just left floating inside the case. Please check in your cable, could be the same problem. Also why do you re-install Windows ? In some old threads i have posted full guide how to clean-up bad Phoenix installation without touching Windows. BR |
if not difficult to make a chart of your cable that you can check the piles to the cable. |
Genie pinouts here. BR |
NK officially dropped FBUS - Flashing - Support for FLS-5. FPS-21 is only supported solution now. |
