Help nokia C3 Pinout RM-614 Help nokia C3 Pinout RM-614 for FBus_Cable |
C3, X2, X5, 2710c, 6788i using ST or Broadcom chipset, so there's no way to FBUS Flashing this kind of phone. |
USB ONLY GSM... 7020 BroadCom C3-00 BroadCom X2-00 BroadCom 2710c BroadCom USB ONLY CDMA with GSM (uses different flash parent drivers!!!) 6788i ST X5-00 ST FBUS :O) X5-01 RAPS :O) |
Can we back up RPL and Simlock Data with USB using Genie or any other box ????????? Thanks Mike |
br |
ill want to try in usb flashing but im afraid hehehe |
c3 security code how to remove security code on nokia c3 ,help plz |
Flash with phoenix than security code will be removed. |
thank,s............................ |
using mt box and usb cable for his model, only put a resistor between - and neutral conector of bat, then, conect, select usb mode in the mt box, then, fact reset. is very easy, may be dont need the resistor,only install, drivers, before, try. |
yes via fenix key u use all backup and also save |
driver sonyericsson W595 |
Svp donnez moi le site de téléchargement des drivers sony ericsson |
if only usb ..can write rpl with usb or write pm sir??? tq |
