Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Genie Universal
Old 02-05-2012, 01:27   #1 (permalink)
Member: 1716078
How to change Product Code nokia N8 with NSS Pro?
Hello, I tried many times to change my nokia n8 product code in order to flash my phone with a foreign firmware, the soft say OK but the code still the same, no changes...How to do?
Thank you for your help!
Old 02-05-2012, 09:01   #2 (permalink)
Product Supporter and selective member Nsspro
Bph&co's Avatar
Member: 1024
Hi,
On some models product code change is protected. Probably hidden and encrypted in
sec area. If i only had the time to research and do this ;(
Old 02-05-2012, 14:23   #3 (permalink)
Member: 1716078
Ok, so for the moment there is no way to change the firmware of a nokia n8 since the product code is unchangeable?
if there is another way to do it please tell me.
Thank you.
Old 02-05-2012, 15:09   #4 (permalink)
Bph&co's Avatar
Member: 1024
Hi,
Not sure if this is applicable to N8, but if you select dead usb flashing in Phoenix,
phone is off, and just manually point to downloaded flash files, you can flash the
phone to this version (make sure is newer than the current one you have) and
new product code will be written by the end of the process.
It's risky anyway, as with any flashing.
Old 02-05-2012, 18:25   #5 (permalink)
DieArmeSau's Avatar
Member: 175700
Originally Posted by Bph&co View Post
... and
No, the Product Code is still the same
Old 02-05-2012, 20:13   #6 (permalink)
Member: 1716078
ok the product code still the same, but the firmware is installed?did you test it Diearmsau? I don't care if it still the same since the firmware is successfully changed.Thank you
Old 02-06-2012, 00:32   #7 (permalink)
*phone-company*'s Avatar
Member: 60001
Sonork: 100.106474
firmware should be completly changed after flash
Old 02-06-2012, 08:33   #8 (permalink)
Bph&co's Avatar
Member: 1024
Hi,
I haven't tested on every single model, so you must be right. Anyway, its a
good idea to investigate this further.
Old 02-06-2012, 08:58   #9 (permalink)
Member: 1716078
Please dear experts can someone explain clearly if I can or not flash my nokia n8 (to a foreign firmware), and if I can, to tell me how to do.thank you for help!
Old 02-06-2012, 20:39   #10 (permalink)
DieArmeSau's Avatar
Member: 175700
sure, you can flash any firmware to your N8. Firmware should work, but Product Code is the Factory Product Code
Old 02-06-2012, 22:54   #11 (permalink)
Member: 1716078
Yes but it could be very risky if the code is not changed before updating frimware for a foreign one? when the code is changed there is almost no risk, isn't it?
thank you.
Old 02-07-2012, 08:29   #12 (permalink)
Member: 60001
Sonork: 100.106474
why should it be risky? in worst case next update with Nokia-Updater will be up to original Productcode.
regards
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 0.28296 seconds with 11 queries
