Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Crazy Poster ![]() ![]() ![]() Join Date: Feb 2009
Member: 977456 Status: Offline Thanks: 361
| how convert .log readet with NssPro v22 to LBF Hello how to convert .log readet with NssPro v22 to LBF? I have .log data from Nokia N8 but i cant use it for Fenix LBF THX Best Regards Chris |
| | #2 (permalink) |
| Junior Member Join Date: Jan 2012
Member: 1716078 Status: Offline Thanks: 1
| Dear, I have a basic knowledge in all this, and I'm trying to unlock my n8 too. I tell you what I have done maybe it can help (I'm not sure that is correct): you should have 2 .log files, in one of them you have a line like rap3= .... where ".... " is a sha1 hash. As I know that the unlock code is 15 digits I used ighashgpu (a bruteforce free soft) with this command line : ighashgpu.exe -h:27100111DE3200499B4B570B15F9D7E975A93E98 -t:sha1 -c:d -min:15 -max:15 where 27100111DE3200499B4B570B15F9D7E975A93E98 is my sha1 found in rap3. for the moment it is bruteforcing and I'm waiting...hope it will work. Alexis. |
| | #3 (permalink) |
| Sorry, I was wrong, the sha1 hash is in the file named : <imei>.log And it is the first 40 characters of the second line, for example you have: B26097B80C8409508AE6B75E0540862B5858FEDDF92EADFC66 E13DA83F4E48.... then the sha1 hash is : B26097B80C8409508AE6B75E0540862B5858FEDD so the command line to bruteforce it should be : ighashgpu.exe -h:B26097B80C8409508AE6B75E0540862B5858FEDD -t:sha1 -u:0123456789 -min:15 -max:15 hope it will help you! Regards. |
| | #4 (permalink) |
| Product Supporter and selective member Nsspro ![]() ![]() ![]() Join Date: Feb 2000 Location: UK
Member: 1024 Status: Offline Thanks: 618
| Hi, 30 Jan 2012, v 0.28 - Fully implemented Nokia BB5 bruteforce system Download Possible scenarios: 1.Have one PC Run local server, client and Admin as 3 instances of NssPro - Submit jobs, bruteforce, manage and get unlock code, even upload to phone 2. Have 2 PCs Run BF client on first to get maximum speed. Second PC can run server and second NssPro instance for uploading, management, control, etc 3. Have more than 3 PCs at home/office Run one Pc for server only, use second for management control, all the rest run video hardware to BF and call your server to speed process 4. You have Server at home, and all PCs in another country where electricity is cheap Same as case 3, just external computers connect to your IP remotely In any case, you can publish your server online and all NssPro users can see it. You can create accounts for them, charge them money to use your server,etc. All managed automatically via NssPro. Here little help how to start: Code: Simple SL3 unlocking guide for NssPro v 0.28 Let's assume you know what SL3, bruteforcing etc etc is. In theory you can run on single PC. Best is to have 3 comp minimum - one for server, one for a cluster(BF machine) and one to monitor, do administration, load jobs, etc. Lets asume you have 3 PCs, put NssPro on all of them. ------------------------------------ Server PC: 1. Make sure this copy is with annual subscription (get licence via Activate) 2. Go to Simlocks Tab, then click SL3 BF tab, then Server tab 3. Press auto fill, if you dont like server name - change it, if you can't see external IP, enter by hand, put contact e-mail or icq, etc in third box. Press Register 4. Press start 5. If your server needs to be accessed from outside, do SLL server port forward on your router Notes: External IP is your internet visible address, not LAN address of the PC that runs the server instance of NssPro. If you tick 'Make my server Public' and click on register, all NssPro users will see your server Do not run skype or other soft on same pc that register SSL server on port 443 ------------------------------------ Client PC: 1. Copy ighashgpu and hashcat files to bf coresponding directories 2. Click Simlocks Tab, then click SL3 BF tab, then Client tab 3. Enter IP of your server, if your client machine is on LAN, you can put local address, if remote, use external address 4. Adjust what soft you will call, arguments, etc 5. Click Start Notes: Expect to have some video card on this machine, compatible with supported BF soft ------------------------------------ Monitor: 1. Go to Simlocks Tab, then click SL3 BF tab, then Account Management tab 2. Enter server IP, enter your desired un and pw as admin and press Create 3. Press Check to see if admin account is ok 4. Create one test user by typint un and pw and press Create in the Users group 5. Check if ok, should have 1 credit 6. You can create as many you want, topup they credits, or delete them by puting zero in the credit value box, then press TopUp Note: Process Monitor tab give status of jobs on the server, clusters, nodes, etc You can also remove jobs(except active ones). Use the Refresh button to get status ------------------------------------ To unlock phone: 1. Go to Simlocks Tab, then click SL3 BF tab, then User Account tab 2. Press Update to get servers list 3. Select yours from the list, then enter user name and pass created (not admin!) 4. Press Save, then you can use Check - to see credits 5. You can upload log file via Upload Log 6. You can submit phone directly via BB5 tab, Submit to Server button 7. You can also cancel idle jobs via the Cancel button, need to put IMEI first After a job is finished - you can get the code via the Check button in the User Account tab. Hopefully more detailed guide when i got some free time. |
| The Following User Says Thank You to Bph&co For This Useful Post: |
| | #5 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2004 Age: 43
Member: 60687 Status: Offline Thanks: 390
| Checking data...Done. Registering your server...Missing certificate. == Sorry, this function requires annual subscription == Local Server process aborted. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() im must register/activate or what? wbr |
| | #6 (permalink) | |
| Quote:
Code: ------------------------------------ Server PC: 1. Make sure this copy is with annual subscription (get licence via Activate) | |
| | #7 (permalink) |
| yes arnoldmasa, you have to subscribe to have fully access to server functions, it is only 20Ģ for one year of service (read .log and get own server). By the way, anyone have a SUPER PC(strong graphic cards) to help me to bruteforce my sha1. It would be very kind, thank you in advance, Alexis. |
| | #8 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Oct 2009 Location: Poland Age: 31
Member: 1139057 Status: Online Sonork: 100.109924 Thanks: 5,657
| If want calc file in few hours just ask me by msm, sonork, icq and price is 13 euro(paypal money send like masspay or gift). |
| | #9 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2001 Location: Bulgaria
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks: 51
| Quote:
. My own is under NssPro control now ... Very good job Bph&co! | |
| The Following User Says Thank You to debeliamark For This Useful Post: |
| | #11 (permalink) | |
| Quote:
free feature anyway(client) so no much incentive to go beyond windows as its working very well. BR | |
| | #12 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2004 Location: Nederlands / Germany / Danmark Age: 40
Member: 60001 Status: Offline Sonork: 100.106474 Thanks: 132
| reading logfile not work for me in my device (Nokia6303i via usb) Checking selection...Supported(USB) interface selected. Init connection...Done. Check backup...Done. Read SW version...Done. SW Version: V 10.80 21-01-11 RM-638 (c) Nokia Read imei...Done. IMEI number: 354345045187052 Read Permanent memory: section 120, key 0...Done. Data: 80000000000000002620200000000000... Read Permanent memory: section 120, key 1...Done. Data: 4844BE11F9AF4F386566C3627EFE0E00... Read Permanent memory: section 120, key 2...Done. Data: 1906ADF6E7B7DA7D946C4CCA248BB74B... Read Permanent memory: section 120, key 3...Done. Data: 00000000000000000000000000000000... Detecting simlock type from data... This phone has old SL3 type of simlock server running. Auto restart to flash mode...Done. Init connection...Done. Requesting ROM info...Done. RAP3 ID: 1A10010A09520049654392E64E9598ABB9EC833B RootKey Hash: 7B045400E1752022F9EB80B0DEA9C65D RAP3 CPU ID: 020C192102054100 PubRom CRC: 67E82268 PrvRom CRC: F29CEA60 Searching for suitable loader, based on CPU ID... Loaders directory: C:\Dokumente und Einstellungen\gsm-service\Desktop\NssPro_0.28\loaders\special\usb\ Trying bcm21351_usb2nd.fg Trying to open file...Done. Checking supported IDs...No compatible ID found in this file. Trying bcm21351_xsr16_usbalg.fg Trying to open file...Done. Checking supported IDs...No compatible ID found in this file. Trying h3_sam_nand_format.fg Trying to open file...Done. Checking supported IDs...Index 0xD4 is missing! Trying h3_sam_nand_gbbm.fg Trying to open file...Done. Checking supported IDs...Index 0xD4 is missing! Trying h3_sam_nand_hdd.fg Trying to open file...Done. Checking supported IDs...Index 0xD4 is missing! Trying h3_sam_nand_xsr.fg Trying to open file...Done. Checking supported IDs...Index 0xD4 is missing! Trying h3_sam_nand_xsr_small.fg Trying to open file...Done. Checking supported IDs...Index 0xD4 is missing! Trying h3_xsr15_flash_alg.fg Trying to open file...Done. Checking supported IDs...Index 0xD4 is missing! Trying helen3_2nd.fg Trying to open file...Done. Checking supported IDs...Index 0xD4 is missing! Trying helen3_2nd_hdd.fg Trying to open file...Done. Checking supported IDs...Index 0xD4 is missing! Trying hera_usb2nd.fg Trying to open file...Done. Checking supported IDs...Index 0xD4 is missing! Trying hera_usbalg.fg Trying to open file...Done. Checking supported IDs...Index 0xD4 is missing! Trying hwdbt_rapidov11_2nd.fg Trying to open file...Done. Checking supported IDs...No compatible ID found in this file. Trying hwdbt_rapuv21_2nd.fg Trying to open file...Done. Checking supported IDs...No compatible ID found in this file. Trying microv10_alg2nd.fg Trying to open file...Done. Checking supported IDs...No compatible ID found in this file. Trying omap2420_2nd.fg Trying to open file...Done. Checking supported IDs...Index 0xD4 is missing! Trying omap2420_m1_2nd.fg Trying to open file...Done. Checking supported IDs...Index 0xD4 is missing! Trying omap2420_xsr15_alg.fg Trying to open file...Done. Checking supported IDs...Index 0xD4 is missing! Trying rap3gv2_2nd.fg Trying to open file...Done. Checking supported IDs...No compatible ID found in this file. Trying rap3gv30_2nd.fg Trying to open file...Done. Checking supported IDs...No compatible ID found in this file. Trying rap3gv30_xsr14_alg.fg Trying to open file...Done. Checking supported IDs...No compatible ID found in this file. Trying rap3gv3_2nd.fg Trying to open file...Done. Checking supported IDs...No compatible ID found in this file. Trying rap3gv3_algo.fg Trying to open file...Done. Checking supported IDs...No compatible ID found in this file. Trying rap3gv3_algo_xsr15.fg Trying to open file...Done. Checking supported IDs...No compatible ID found in this file. Trying rap3gv40_2nd.fg Trying to open file...Done. Checking supported IDs...Found. Checking supported root hashes...Found. Will use rap3gv40_2nd.fg Detecting CPU type from loader name: RAP3Gv4 CPU assumed. Will try to extract and prepare the loader... Open loader file...Done. Extracting raw block...Done, Patching correct signatures... Look for KEYS...Found,inserting into loader...Done. Look for SILO...Found,inserting into loader...Done. Look for PRIMAPP...Found,inserting into loader...Done. Setting boot mode to USB...Done. Replacing SILO with ULO... Done. Sending loader...Done. Check loader execution and init...Done. Loader Mode Responce: 0x377862 Prepare custom RAP3Gv4 loader... then nothing... How to fix? |
| | #13 (permalink) | |
| Quote:
Do you have subscription buyed from Alex and software is register ?? | |
| | #14 (permalink) |
| no i want to try this software and i downloaded from official source here no need register?! I only want to read the logfile needed for calculation?! |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| How to add a language in 51xx/61xx | tati | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 8 | Yesterday 19:20 |
| How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 28 | 08-30-2012 03:40 |
| How can I do a Welcome note for my 6110 a dosn't have any one ? | Viper | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 07-18-2012 07:57 |
| news headlines to gsm phone | mos | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-18-2011 11:00 |
| Help with 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 05-25-2009 16:29 |
