12-20-2009, 15:13 | #1 (permalink) | ||
Cheater -Don't Deal with him- Join Date: Nov 2007
Member: 635691 Status: Offline Sonork: 100.1592330 Thanks Meter: 137 | Info&SimLock...Error5! [ANSWERED] i changed some cable and i used X-Fbus with Genie adapter but same ... Error5! but with JAF,MT,UB, work good i teste N96, 6303, 5220, 5130 and 6300 and 3110 .... in Genie_BB5notp he detected but in Remote Tools and GeniePlus(1209, 1650, 6030 rm-225...) cant connect Quote:
12-20-2009, 15:38 | #2 (permalink) |
Junior Member Join Date: Oct 2009
Member: 1133067 Status: Offline Thanks Meter: 5 | Had same problem yesterday with an 5800. If you are using 7 pin cable with adapter try to change resistance on adapter cable to NC or 5,7 or just try them all untill it works. Worked for me with 5,7 resistance. B.R. |
12-20-2009, 16:01 | #3 (permalink) | |
Member: 635691 Status: Offline Sonork: 100.1592330 Thanks Meter: 137 | Quote:
12-20-2009, 23:09 | #5 (permalink) |
No Life Poster Join Date: Feb 2000 Location: UK
Member: 1024 Status: Offline Thanks Meter: 5,510 | Hi, The new version of the script (0.72) will set the phone in Fbus mode and keep it powered. Check if your phone is in Local/Test mode. The new version of the script has problem switching between modes(Fbus/flash) with some cables that have to higher value resistor inside. BR, Alex |
The Following User Says Thank You to Bph&co For This Useful Post: |
12-21-2009, 11:13 | #6 (permalink) | |
but why i cant connected any phone in! GeniePlus? Phoenix? PM Tool SX4? Nk4calculator? Last edited by mimounts; 12-21-2009 at 11:22. | |
01-12-2010, 22:40 | #10 (permalink) |
Freak Poster Join Date: Nov 2005
Member: 196046 Status: Offline Thanks Meter: 3 | every fone i have is error 5 i have 2 genie converter cables with white wires and the resistor bit i have tried with all settings and still nothing will go local mode this is useless box if they cant fix it and as for software im on 181 so cant be due to an upgrade . |
04-05-2010, 02:34 | #11 (permalink) |
Junior Member Join Date: Apr 2009
Member: 1016070 Status: Offline Thanks Meter: 0 | Nokia SL_X Remote Tools V 1.0.0.33 Waiting Device......Found. Reading data...Done. Script v 0.0.0.104, Device SN: 100858, OS v 0.0.0.191 ------------------------------------------------- Check credits on Server...Done. Connecting to server...Error: 5 ------------------------------------------------- Check credits on Server...Done. Connecting to server...Error: 5 ------------------------------------------------- Check credits on Server...Done. Connecting to server...Error: 5 ------------------------------------------------- what heaven work bra,,, error 5, 6 |
04-05-2010, 09:17 | #13 (permalink) |
Freak Poster Join Date: Jan 2006
Member: 218667 Status: Offline Thanks Meter: 19 | Last 5800 ok with bb5notp.Yes with server NOT working.The same problem 3 diferent adapter ,diferent type of phone without conect.One time is working.I believe is a server problem.But i see now is unlock 2680 and 5800 .Slow but very good work.Thanks genie team |
help pls error5 | mimounts | Genie Universal | 5 | 01-19-2010 18:09 |
help me error5..!!! | Santiago LEE | Genie Universal | 3 | 08-29-2009 13:43 |
have lost 10 credits : still Connecting to server...Error5! | rolko_mobile | Genie Universal | 1 | 08-14-2009 18:46 |
C450 unlock error5 | thamaniac | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 6 | 10-28-2008 23:51 |
