09-18-2008, 20:08 | #1 (permalink) | ||
No Life Poster Join Date: Feb 2004 Location: ALGERIA
Member: 54116 Status: Offline Thanks Meter: 218 | Mbus Flashing Cables / solution im very happy with my GENIE device , but for now i dont succes for flashing any phone with Fbus cables . with usb and phone working all ok satisfed , but with Mbus nothing i have all the time same error . plz tel me why i got this with usb connection sometimes when phone is dead or blinking : Quote:
i trayed with the 4 postion of the adapteur and nothing , same cable succes flashing with MT or Jaf . thanks for support . wbr | ||
09-19-2008, 05:37 | #14 (permalink) | |
No Life Poster Join Date: Nov 2001 Location: China GuangDong
Member: 7220 Status: Offline Thanks Meter: 1,592 | Quote:
1. Uart test menu This is basically the old phone check script that tries to read the phone SW version via FBUS command. It will test only phone power, RX and TX. 2. Flash test menu This test will boot a BB5 (not DCT4!) phone in flash mode and will read bootrom information and will display it on the screen. The test is good to detect problems with phone/battery connection. It will be good sign that phone power, BSI, MBUS, RX and TX are connected 3. Pin test menu This is the most advanced mode, but requires some technical skills + correct pin out for the tested phone model. The mode will allow you to select the level of each line as high or low (3.3 V, 0 V). So by using a multimeter or a LED you can test for any disconnected lines. Please do not use mode 3 with a phone connected !!! Best Regards Alan Tan | |
09-19-2008, 16:49 | #15 (permalink) | |
Member: 54116 Status: Offline Thanks Meter: 218 | thanks Quote:
wbr | |
Easy Flash Cable solution | Temani | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 04-21-2009 08:26 |
Convert 8310 Mbus Cable To Flash Cable | ccwong | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 06-16-2002 06:33 |
Convert 8310 Mbus Cable To Flash Cable | ccwong | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-2002 13:59 |
flasher cable <-> MBUS only cable? | starhunta | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-11-2002 08:14 |
Can any one give me the schematics for the Mbus/Fbus cable please? | Blunty | Hardware Equipments for GSM | 1 | 06-10-2001 19:31 |
