Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Aug 2005 Location: Pakistan
Member: 170380 Status: Offline Sonork: 100.1577994 Thanks: 528
| My First Sl3 2730c Unlock Via Brute Forcing With My New Computer ![]() Seconds Remained: 22.6 NCK Not Found Trying salt 519 Seconds Remained: 22.6 NCK Not Found Trying salt 9442 Seconds Remained: 22.6 NCK Not Found Trying salt 5916 Seconds Remained: 22.6 NCK Not Found Trying salt 4399 Seconds Remained: 22.6 NCK Not Found Trying salt 1586 Seconds Remained: 22.6 NCK Not Found Trying salt 6490 Seconds Remained: 7.7 NCK Found, saving COD File -->job 0: imei: 35152304375****, status: done Code: #pw+441557628759083+7# |
| The Following 17 Users Say Thank You to ..::Mobile Smoker::.. For This Useful Post: |
| | #3 (permalink) |
| core i7 950 3.06ghz D6T Asus crossfire 8gb corsfer ram 2000gb hard disk atx cooler master casing blue ray rom ATI Radeon HD 5970 dual-GPU video card XFX(2 Cards) 22.3 Sec Per Salt 18 hrs Time |
| | #8 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2000 Location: J.A.U - Just Another Unlocker Age: 33
Member: 2878 Status: Offline Thanks: 1,584
| you need a minimum of 850w. even this is not enugh if you whant to overclock it, and oc for HD5970 is realy A MUST! because you can get 800-1000 million h/s per card more power! ![]() if you spent 2x500 euro for 2 5970 cards and 200 euro for mainboard and again 200 for cpu and little bit more for hdd, ram, casing then you can also buy a good 1000 watt supply... ps: my first sl3 was also a 2730c phone (taken me 2 days)2nd was N97 (taken me 8 hours). 3nd N97 mini (taken me 2 days). .... so most are done in 2 days till now... not good result... need more power ![]() need to build some more sl3 killer mashines... ![]() but its hard to get cheap 5970 cards under 400 euro... easy to get it for 500-600 euro online... but for under 400 euro is hard to get. |
| The Following 5 Users Say Thank You to oOXTCOo For This Useful Post: |
| | #9 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2001 Location: Bulgaria
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks: 51
| With result of 2 days per phone ( near ) ... mean 15 unlocks per month ... so what a price for unlock must get from customer to achieve ROI ( return of investments ) for few monts? and this is without to count electrical bill ... so - look like a better algorithm is needed ... |
| The Following User Says Thank You to debeliamark For This Useful Post: |
| | #10 (permalink) | |
| Product Supporter ![]() ![]() ![]() Join Date: Oct 2009 Location: Poland Age: 31
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks: 5,648
| Quote:
Then maybe you write your sw to bruteforce becosue like Ivan write he not have time to fix sw to only search code in digits 0 to 9 and now software search code check all possibility with letter and this optimization should speed up about 30% on 1 hd5970 then on 2 about 50-60% faster will be. I know you can do this write this sw that only for sl3 will be and will not calc what not should. | |
| | #11 (permalink) | |
| Quote:
there is something wrong with your comp or card drivers | |
| | #13 (permalink) | |
| Quote:
no... its okay, first tests are done with only 1 HD5970. and yes... before i used win xp and found only 1 gpu running... then i switched to win 7 and now all 2 gpus are working. (what i wonder, way both gpu“s a just running at 50%) then i tryed a HD5970 witt a 2nd card NVidia GTX8800, i toutgh it should bring me minimum 880 million hashes /s more, but it was not... it was even less then before with only one card, i think because it dont works in crossfire mode. but i have seen screenshots from gobulev using mixed cards togetter... but 3148 Million Hash / s for 1 card is okay or not? it is near the maximum after overclocking the card. what have other users with same card? how mutch hashes / second ? | |
| | #14 (permalink) | |
| Quote:
realy? it realy bforce also in letters? i cant belive it, because what i have seen, i can enter in the bforcer wich letters or digits i whant to use... and what i have seen, it is only 0..9 (i have reversed the log2cod.exe). or it is a bug and it use latters anyway? from wohm you have this information? see here (some results from my reversings): Code: [DS:0047A93C]=00A1AB08, (ASCII "-hm:0 /t:sha1 /min:11 /max:11 /uh:00010203040506070809 /salt:09000902003560640336306100 /h:52645D00AC6D0D0179C6169755A989F6BC0C53F6") see in red... this is the used charset... so you must be wrong or a bug. ps: i dont know nothing about gpu programming... i have downloaded some sources for it, but till now never taken any look into it. i have it already implemented into jau just for fun... but since i have only laptop at home, i cant test... need to take desktop computer at home to make it finihed... what i have tested is customloaders working, now i have also implemented a possibility to enter unlock code manualy to phone for fbus and keypress all locklevels... (but the local bforce will not be in the puplic version, only if i find something to make it faster then the others, or it will be useless) Last edited by oOXTCOo; 01-12-2011 at 02:22. | |
| | #15 (permalink) |
| Ivan write on his blog that chartset is not working in v80 and becosue this even if you write that need only use digits not doing this. |
| The Following User Says Thank You to wgmmmx1 For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Unlocking 5190 | Ryu | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 23 | 09-16-2012 23:57 |
| How can I do a Welcome note for my 6110 a dosn't have any one ? | Viper | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 07-18-2012 07:57 |
| Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 5 | 05-10-2012 14:14 |
| my 8810 is phone locked ,can somebody please help | duyphuc | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 16 | 02-01-2012 05:18 |
