Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2006
Member: 383592 Status: Offline Thanks: 119
| N97 mini support via usb? N97 mini support via usb to reah has? And which line of data is needed to calculate code has via lbf after reading data from phone? |
| | #2 (permalink) |
| Check this error.... Checking selection...Supported(USB) interface selected. Init connection...Done. Check backup...Done. Read SW version...Done. SW Version: V ICPR72_09w44.18 28-05-10 RM-555 (c) Nokia Read imei...Done. IMEI number: 353391042879078 Read Permanent memory: section 120, key 0...Done. Data: 80000000000000002140400086388183... Read Permanent memory: section 120, key 1...Done. Data: 715329F3C2F88D88B85C6549A550FC67... Read Permanent memory: section 120, key 2...Done. Data: 9A7B998AE7826120CC100050797BC266... Read Permanent memory: section 120, key 3...Done. Data: 00000000000000000000000000000000... Detecting simlock type from data... This phone has old SL3 type of simlock server running. Auto restart to flash mode...Done. Init connection...Done. Requesting ROM info...Done. RAP3 ID: 1DC001109F980052F871D02730D97A51600792F7 RootKey Hash: 479C6DDE3942E12C429C1D6ADED80371 RAP3 CPU ID: 400C192101051103 PubRom CRC: 4B9B7510 PrvRom CRC: 3E691FF8 Searching for suitable loader, based on CPU ID... Loaders directory: C:\Users\Carl vs Georgia\Documents\nokia\loaders\special\usb\ Trying bcm21351_usb2nd.fg Trying to open file...Done. Checking supported IDs...No compatible ID found in this file. Trying hwdbt_rapidov11_2nd.fg Trying to open file...Done. Checking supported IDs...Found. Checking supported root hashes...Found. Will use hwdbt_rapidov11_2nd.fg Detecting CPU type from loader name: RAPIDO CPU assumed. Will try to extract and prepare the loader... Open loader file...Done. Extracting raw block...Done, Patching correct signatures... Look for KEYS...Found,inserting into loader...Done. Look for SILO...Found,inserting into loader...Done. Look for PRIMAPP...Found,inserting into loader...Done. Setting boot mode to USB...Done. Replacing SILO with ULO...Done. Sending loader...Done. Check loader execution and init...Error write! |
| | #4 (permalink) |
| Now whats is this error now? Checking selection...Supported(USB) interface selected. Init connection...Done. Check backup...Done. Read SW version...Done. SW Version: V ICPR72_09w44.18 28-05-10 RM-555 (c) Nokia Read imei...Done. IMEI number: 353391042879078 Read Permanent memory: section 120, key 0...Done. Data: 80000000000000002140400086388183... Read Permanent memory: section 120, key 1...Done. Data: 715329F3C2F88D88B85C6549A550FC67... Read Permanent memory: section 120, key 2...Done. Data: 9A7B998AE7826120CC100050797BC266... Read Permanent memory: section 120, key 3...Done. Data: 00000000000000000000000000000000... Detecting simlock type from data... This phone has old SL3 type of simlock server running. ---------------------------------------------------------------------- Please disconnect the USB cable... Now power off the phone... Reconnect the USB cable... Now quickly press the Power On button... ---------------------------------------------------------------------- Init connection...Done. Requesting ROM info...Done. RAP3 ID: 1DC001109F980052F871D02730D97A51600792F7 RootKey Hash: 479C6DDE3942E12C429C1D6ADED80371 RAP3 CPU ID: 400C192101051103 PubRom CRC: 4B9B7510 PrvRom CRC: 3E691FF8 Searching for suitable loader, based on CPU ID... Loaders directory: C:\Users\Carl vs Georgia\Documents\nokia\loaders\special\usb\ Trying bcm21351_usb2nd.fg Trying to open file...Done. Checking supported IDs...No compatible ID found in this file. Trying hwdbt_rapidov11_2nd.fg Trying to open file...Done. Checking supported IDs...Found. Checking supported root hashes...Found. Will use hwdbt_rapidov11_2nd.fg Detecting CPU type from loader name: RAPIDO CPU assumed. Will try to extract and prepare the loader... Open loader file...Done. Extracting raw block...Done, Patching correct signatures... Look for KEYS...Found,inserting into loader...Done. Look for SILO...Found,inserting into loader...Done. Look for PRIMAPP...Found,inserting into loader...Done. Setting boot mode to USB...Done. Replacing SILO with ULO...Done. Sending loader...Done. Check loader execution and init...Done. Loader Mode Responce: 0xC300FF Prepare custom RAPIDO loader...Done. Code will be loaded in memory at: 0x08005000 Sending loader...Done. Attempting to take over execution...Done. Check loader execution...Done. -- NssPro Custom Usb loader v.0.23 © 2012 GenieProjects -- Establishing secure connection...Done. Testing loader connection...Done. Prepare custom RAPIDO payload...Done. Sending payload...Done. Checking if payload is alive...Done. Reading data...Done. Prepare RAPIDO final...Done. Sending final...Done. Testing if final is alive...Done. Reading data...Done. Decode on server...Success. Server Version: 1.94 Error2: SL RSA key not in DB yet. And which line of data should i used for lbf? [Phone] swvv=V ICPR72_09w44.18 28-05-10 RM-555 (c) Nokia/v 12.0.110 imei=353391042879078 data0=80000000000000002140400086388183001801000000 00000020000001FFFFFF000000007FFF6F07FFFFFFFFF80000 340300050221404FFF data1=715329F3C2F88D88B85C6549A550FC67B8E52A2E56CF A33EBB3F9A0CD372C65A325CF665A6FA5674ECE1E990750F47 8EB9B013286CE033F97C51F4884F9A971CABFF227D5D6F6752 03FCD41881AFDC6548C904DDD053F4F751EDCB1F114792CCC4 E89E5BDA0FF48E9B10E30FE4581CDC75AA0137E9783DCFDA9A E91EA4A6CAAB1D2FB1F75246283116D64B502D1B06A6DEC02F 7E383D89A8242E2694F0EB50C3 data2=9A7B998AE7826120CC100050797BC2660D0889D49C87 6D835005A2A78285D25ED455C0D1B65CF13AE8EE88FF8881B7 2F69257D516A16660249662E945F29D3668DA8EC0CD9E03AB1 E0F203AA8FBD76094A4D088AA620A33035841E7F13E8C073E3 A766B6DD07D80AAFCD1C31B38F67E06BEEDAA6796FABDD9191 AA584CF101120100 data3=00000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 000000000000000000000000000000 rap3=1DC001109F980052F871D02730D97A51600792F7 hash=479C6DDE3942E12C429C1D6ADED80371 uniq=67390B4183C563FA16AF1B3AC9D9D11FD360C5E2C503F 88AA20DF973937B79CCA5F8FEB3B5CB2DD312F7898F3966E52 9E4BB8966D7B6207A8710EF35A0DFCF01BF2BC2EA3DE6BF17C 6E95B10A19D00B1140785E552A62A3CB34CD25B6B1319F063F 251A547E956939076500A4DB2ECEC8C1626A38550151B0CE1A 0BEA39645B8 |
| The Following User Says Thank You to karlleeto For This Useful Post: |
| | #5 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Oct 2009 Location: Poland Age: 31
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks: 5,660
| Just wait to tommorow to Alex add this hash to RSA and tommorow read log file will work. This file what you give nothing is for bruteforce you need log file. |
| The Following User Says Thank You to wgmmmx1 For This Useful Post: |
| | #6 (permalink) |
| Product Supporter and selective member Nsspro ![]() ![]() ![]() Join Date: Feb 2000 Location: UK
Member: 1024 Status: Offline Thanks: 618
| Hi, The server is updated, you can get your log file now. BR |
| The Following User Says Thank You to Bph&co For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| 5110 Contact Service Repairer via MBUS/FBUS | Allen | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 11-15-2010 03:17 |
| Help to connect data cable to notebook throught USB | casper | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 06-21-2001 14:08 |
| Nokia 5110 v5.29 via M+F-Bus Data Cable | gsmdeemon | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 1 | 01-30-2001 20:17 |
| SMS via system connector | pasisoft | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 1 | 10-21-1999 11:05 |
