10-13-2009, 21:41 | #2 (permalink) |
Banned Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139272 Status: Offline Sonork: 100.109924 Thanks Meter: 12 | HI sory for delay need do this connect power supply to clip in clip select programs/nokia/geniep connect clip to computer install genie plus software from 01.2009 (software is in download section on genie page that is write on clip) when computer ask about driver select driver from genei plus directory after correct install driver turn on genei plus software on computer software should see genie clipand write info about it. connect phone to rj48 in clip with 10pin FBUS cable. If not have 10pin cable use adapter and connect it to clip and to adapter connect 7pin jaf FBUS cable to phone. Press in software POWER wait to got massage OK press in software READ INFO software should read info about connected phone press in software INSTALL now phone is unlocking wait to finish and phoen will be unlocked That all |
The Following User Says Thank You to gsm-matrix For This Useful Post: |
10-13-2009, 21:55 | #3 (permalink) | |
Insane Poster Join Date: Jan 2005 Location: ireland Age: 68
Member: 105896 Status: Offline Sonork: 100.1587311 Thanks Meter: 4 | thanks but no sucess it reads the phone but says unlock manually Quote:
10-13-2009, 23:21 | #4 (permalink) |
Member: 1139272 Status: Offline Sonork: 100.109924 Thanks Meter: 12 | Copy log from software and after can help more. You are sure you use FBUS( easy flash cable not work with genei clip) cable with correct ressistor in BSI line ?? |
10-15-2009, 18:28 | #5 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Sahara Desert Age: 77
Member: 150570 Status: Offline Thanks Meter: 52 | When message says 'manually', I normally try a few more times to unlock. Sometimes it works, sometimes not. I have also removed cable from phone when it says 'manually' or when reading say 70% and it appears stuck/frozen, and then repeated unlock. Sometimes works. I also make sure that phone is in local mode, before doing anything. Marty |
07-01-2011, 17:52 | #6 (permalink) |
Freak Poster Join Date: May 2007 Location: cameroon
Member: 516860 Status: Offline Sonork: chickiesmp Thanks Meter: 12 | please help me i tried a solution with jaf and it said choose mcu.after choosing mcu file,it stuck at flashing.now phone is dead customer can kill one please help............................................ the log is cleared so i cant semd it |
07-02-2011, 17:57 | #7 (permalink) | |
Member: 150570 Status: Offline Thanks Meter: 52 | Quote:
marty | |
Nokia 6600i-1c RM-570 Unlocked using Genie Universal | Mr.Ultimate | Genie Universal | 4 | 10-12-2010 14:02 |
Nokia 1680c unlock done | m_tahir1 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 12-13-2009 08:31 |
Nokia 6500 Unlocking using Rebel No Cut Simcard using v44 | RebelSimCard | Rebel SIM Card | 0 | 03-05-2009 19:49 |
