Go Back   GSM-Forum > Product Support Sections > Hard/Software-Products (official support) > Genie Universal
Old 12-14-2009, 13:06   #1 (permalink)
Product Supporter and selective member Nsspro
Bph&co's Avatar
Member: 1024
Nokia SL_X Remote Tools Updates [05-5-2010]
V 1.0.0.18 - 14 Dec 2009
- Reading of the startup self tests added
- Running of single test also is possible now
- Boot delay option removed
BR, Alex
B-phreaks
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiShare on FacebookTwitterStumble this Post!
Old 01-18-2010, 14:44   #2 (permalink)
Bph&co's Avatar
Member: 1024
V 1.0.0.24 - 18 Jan 2009
- Support for SL3 data requests and status check. No
more need for separate executable for Beta testing
of SL3 Unlock, all is activated based on the user
server privileges
- User Name and Password boxes moved to the About menu.
The login credentials will be saved to the ini file
regardless if use server check box is selected
- New loaders added for not supported RAPIDO hashes
Now will be possible to unlock E63 v200 via RPL file (thanks
to James for the test phone !)
- No more need for good quality cable with RX2 connection
this should increase the comm stability with the cables in
mass use
- Super Dongle data added to calculated RPL file
- No more need to have 200 credits for the code reading
function
Old 01-27-2010, 17:37   #3 (permalink)
Bph&co's Avatar
Member: 1024
V 1.0.0.28 - 27 Jan 2010
- Support for the new Remote OS update of Genie
- Bug fix on reading wrong data if old script is
running in the device
Old 02-04-2010, 12:03   #4 (permalink)
Bph&co's Avatar
Member: 1024
V 1.0.0.29 - 04 Feb 2010
- Some small changes to allow usage of our new free
service for BB5 RPL files
Old 02-11-2010, 09:38   #5 (permalink)
Bph&co's Avatar
Member: 1024
V 1.0.0.31 - 11 Feb 2010
- Small improvments over v 1.30
- Ability to repair dead Genie devices via recovery
bootloader
Old 03-17-2010, 15:44   #6 (permalink)
Bph&co's Avatar
Member: 1024
V 1.0.0.33 - 17 March 2010
- New button added - SL3 Cancel to allow canceling of
jobs on the server. IMEI of the job needs to be inserted
in the Imei to Cancel box first
Old 05-05-2010, 13:58   #7 (permalink)
Bph&co's Avatar
Member: 1024
V 1.0.0.34 - 05 May 2010
- Critical bug fix regarding USB update of Genie
Firmware. Clicking onto another program, then clicking
in Remote Tools was crashing the USB comunication during
OS update and causing the device to go to blue screen mode
Download
Important Update:
If you experience the following problem:
When trying to update, you get "Waiting Device...Error1!", its worth doing the following check:
1. Run log.smx
2. Press Conect, then go to the About Tab
3. Enter your US and PW
4. Press Check Credits
If you get "Check credits on Server...Error2!" this means you probably run some old
unpatched/cracked etc version of windows.
Please download this file and install to make Remote Tools v 1.34 to work
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 52 03-21-2012 09:34
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 24 02-14-2012 02:39
Powered by Searchlight © 2012 Axivo Inc.
- GSM Hosting Ltd. - 1999-2011
Page generated in 0.55836 seconds with 10 queries
