11-05-2008, 12:50 | #1 (permalink) |
Major Poster Join Date: Sep 2006
Member: 341849 Status: Offline Thanks Meter: 3 | Problem with N95 unlock Checking Phone... Done Backup Security... Skipped Calculating... Done Uploading.... Error1 Anyone tell me why? Perhaps is because v13 Regards |
11-05-2008, 17:24 | #5 (permalink) |
No Life Poster Join Date: Feb 2000 Location: UK
Member: 1024 Status: Offline Thanks Meter: 5,510 | Hi, We would have never advertised this as a feature, if it is not working. I can see from your log that everything works, except the last step, where the phone is rebooted. Possible reason is that the phone boots too slowly into flash mode, or wrong resistor in the cable makes it unable to 'talk' via FBUS. BR |
11-05-2008, 17:45 | #6 (permalink) | |
Banned Join Date: Apr 2005 Age: 42
Member: 137474 Status: Offline Sonork: 100.109924 Thanks Meter: 471 | Quote:
11-05-2008, 17:46 | #7 (permalink) |
No Life Poster Join Date: Dec 2003 Location: SWEDEN
Member: 45814 Status: Offline Thanks Meter: 34 | I have the same problem as you, i will other cable to. @ Bph&co, if possible, can I contact you to talk about other problem I have with my Genie, eveytime when i try to do someting with ac-adapter connected to genie, I get errors all the time, but not if i do the same thing without it? Thanks Bernie |
11-06-2008, 13:44 | #10 (permalink) |
Member: 1024 Status: Offline Thanks Meter: 5,510 | Hi, Little update on the N95 unlock problems. There are 2 type of errors: 1. Upload SP lock error. This is caused by slow booting. We already have new version of the application, right now testing with few guys, to see the result. Probably will upload later on today 2. Backup security error - this could be caused from low power supply (phone and Genie will blink together) or because of charging while using the bb5notp.exe To prevent first problem you can use other suppy - fully charged battery or USB only power. For the charging problem will be a fix - new OS version for Genie, but this probably in few days. Regards |
11-06-2008, 16:13 | #11 (permalink) |
No Life Poster Join Date: Dec 2000 Location: UK
Member: 2868 Status: Offline Thanks Meter: 514 | We have improved the N-95 unlocking Currently i am uploading the applications on the server. Later on when all is uploaded, i will post announcement. Best regards Danny |
eternal problem with n95 and mt-box! | h&c | MT-BOX | 12 | 10-16-2007 09:31 |
Major problem with N95 unlock MT_PRO | mobilewiz | MT-BOX | 19 | 10-01-2007 17:47 |
big problem with n95 | manpikin | MT-BOX | 3 | 09-08-2007 17:35 |
