10-28-2008, 18:50 | #1 (permalink) |
No Life Poster Join Date: Dec 2000 Location: gsmdoctor.pl Age: 48
Member: 2755 Status: Offline Thanks Meter: 42 | voltage on vpp pin I think I found the reason of my fbus flashing problems. I just measured the voltage between vpp and gnd, and during booting is 0.16 V - far too low, isn't it ? can you give me a hint, what to check ? Last edited by *MaTeOoSh*; 10-28-2008 at 18:59. |
10-28-2008, 21:18 | #2 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: Yes
Member: 192652 Status: Offline Sonork: No Thanks Meter: 121 | Quote:
NO, this is not the reason. VPP is turning no only during flashing. And VPP voltage is between 9 and 12 volts depend on phone model. If you what to find the reason of your problem just post the "flash log" file here. ps. Alex tell on the official forum how to turn on the flash logging. | |
10-29-2008, 00:19 | #3 (permalink) |
Member: 2755 Status: Offline Thanks Meter: 42 | yep, switched the logging on, and right, the vpp is turned on by the software. And indeed, everythings right, ~10V appears on vpp pin at end of the cable. So, OK. Anyway phone (N82) refuses to be flashed. There's a known llimitation described in readme regarding fps devices and n82, but no word about fls-5. Anyway, I still fighting ... EDIT: I restore all loaders from version 8.36.02 and I receive [ 61.578](195) xx ERROR xx Failed FLE5SendBootstrapDCT5 : Timing Values were not passed to an FLE5 function that uses MODE_CONFIRM - 65 (41h) [ 61.578](195) xx ERROR xx SearchForBootstrap_DCT5 : Timing Values were not passed to an FLE5 function that uses MODE_CONFIRM - 65 (41h) so, followed bph&co notice and copied RAPIDOv11_2nd.fg from 8.24.010 over. And guess what ? Flashing started BTW. on whole loaders pack 8.24.010 always became "status response ..." which pointed me wrong to failure in VPP. Seems, it was loaders problem ... Uff ... Last edited by *MaTeOoSh*; 10-29-2008 at 00:25. |
10-29-2008, 01:58 | #4 (permalink) | |
No Life Poster Join Date: Nov 2001 Location: China GuangDong
Member: 7220 Status: Offline Thanks Meter: 1,592 | Quote:
Best Regards Alan Tan | |
10-29-2008, 02:06 | #5 (permalink) | |
nice to heard it ps. Phoenix's logging system in very powerful debugging system | |
10-29-2008, 08:21 | #6 (permalink) |
Member: 2755 Status: Offline Thanks Meter: 42 | Hi, As I said - finally managed to flash this n82 via fbus, but it was a real pain 1. on loaders 8.32.02 always "Timing Values ..." 2. on loaders 8.24.010 always "status response ..." - this have me mislead 3. on loaders 8.32.02 and RAPIDOv11_2nd.fg from 8.24.010 - success !! So, once again bugz in Nokia software - no little wonder, that their stocks are falling ... Indeed, Phoenix logging system is quite comprehensive - lot a useful infos can be read from it. Anyway, thanks to all for help. |
The Following User Says Thank You to *MaTeOoSh* For This Useful Post: |
10-29-2008, 09:29 | #7 (permalink) |
No Life Poster Join Date: Feb 2000 Location: UK
Member: 1024 Status: Offline Thanks Meter: 5,510 | Hi, Very good research. Thanks for posting it! Regarding VPP, it is switched on and off in a combination of command to the running algorithm + toggle of the voltage. It is done dynamically based on settings declared in the flash files + info returned from the Flash chip. Could be put on for erase of certain blocks, or programming of some blocks, etc. But i can confirm that is never on while booting(before the algo is executed). Regarding the problem with the latest loaders - yes it is really sad. Let's hope they fix in next Phoenix, i still prefer good old Fbus flashing to the USB flash. BR |
10-29-2008, 09:58 | #8 (permalink) | |
Member: 2755 Status: Offline Thanks Meter: 42 | Quote:
No I see how much work you had to put into fls-5 reversing. Respect ! | |
cect p168c not charge,low voltage 2,5v on battery pin solution? | nykocam | Chinese Models & Cloned Phones | 3 | 03-09-2010 07:56 |
WARNING: VPP pin is not connected, disabling VPP. | gsaalmeida | MT-BOX | 4 | 10-26-2007 07:04 |
VPP pin not connected | rowin | MT-BOX | 3 | 07-15-2007 16:03 |
Is Vpp pin really needed? | pavlin | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 11-18-2002 08:00 |
3210.. vpp pin ? | micklong | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 05-03-2001 13:46 |
