04-11-2009, 01:03 | #2 (permalink) |
No Life Poster Join Date: Mar 2006 Location: lost in a supermarket
Member: 239318 Status: Offline Thanks Meter: 51 | i just received my box and was wondering same thing, i guess is good to unlock not flash anyway . but wold be better someone answers to explayn this pop port cable witch models supports in unlock |
04-11-2009, 07:31 | #3 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Yes
Member: 192652 Status: Offline Sonork: No Thanks Meter: 121 | You CAN'T use pop-up cable for flashing, pop-up cable allow following things: -Probably unlock BB5 (NOT DCT4) -Use with Phoenix to read informations from phone, resetting setting, testing etc -Reading/Writing PM BR, g-gabber |
The Following 3 Users Say Thank You to g-gabber For This Useful Post: |
04-12-2009, 01:07 | #4 (permalink) | |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
just need one small modification for this. Need add mbus testpoint. for unlock need RX,TX, Mbus line, V+ and bsi line. I'am make cable with 3 conector(dcu2, miniusb and ca-101) with this one cable you can unlock all BB5 phones. Not need keep lot of cables for unlock. Without Mbus conected you can read phone state, and restore phone. For unlock need mbus conection. | |
04-12-2009, 08:24 | #5 (permalink) | |
No Life Poster Join Date: Feb 2000 Location: UK
Member: 1024 Status: Offline Thanks Meter: 5,510 | Quote:
That's interesting, maybe you can make some pictures and attach here ? BR | |
04-12-2009, 10:05 | #6 (permalink) | |
Freak Poster Join Date: May 2006 Location: A
Member: 272591 Status: Offline Sonork: 100.1579461 Thanks Meter: 45 | Quote:
yes not bad to look at it, can be put on public display | |
04-21-2009, 12:12 | #7 (permalink) | |
No Life Poster Join Date: Feb 2004 Location: Devon, England
Member: 55766 Status: Offline Thanks Meter: 333 | Quote:
04-21-2009, 12:53 | #8 (permalink) |
Member: 1024 Status: Offline Thanks Meter: 5,510 | Hi, Really nice idea, i haven't seen this schematic before. Would be cool if somebody make universal Genie cable, with 10 pin connector instead of 8 pin, so no need for adapter. Also because of the free pins, we can have some digital potentiometer, SW controlled from the Genie application itself. This will allow to adjust correct BSI value and enter local mode easily. BR |
04-21-2009, 13:46 | #9 (permalink) | |
and again this goes into local made with + and bsi connected. The TP goes to MBus pad on fone (usually the middle pad. Havent got a phone to unlock to test but have tested jungle with other boxes so I see no reason for it not to work. | |
04-22-2009, 13:39 | #10 (permalink) |
Member: 55766 Status: Offline Thanks Meter: 333 | I havent made multi conector but have attched TP prode to use as unlocker. I attach video link but please excuse poor quality as I'm not used to doing videos and as you can see it took me longer to attach bsi clip than it took for genie to unlock http://www.youtube.com/watch?v=OTDw4Y8qgok |
The Following 2 Users Say Thank You to FU_Too For This Useful Post: |
04-23-2009, 03:27 | #11 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Georgetown
Member: 455304 Status: Offline Thanks Meter: 417 | i see genie come with 3 set pop cable... could you list all these model these 3 cable support..and where could i purchase the rest of cable to unlock BB5 that the three cable don't support... thank |
05-04-2009, 11:18 | #12 (permalink) | |
No Life Poster Join Date: Nov 2004 Age: 45
Member: 93284 Status: Offline Thanks Meter: 202 | Quote:
What's wrong? BR | |
05-04-2009, 12:53 | #14 (permalink) | |
BR | |
05-04-2009, 13:31 | #15 (permalink) |
Member: 55766 Status: Offline Thanks Meter: 333 | Well it looks like correct pad, Ive not needed to connect mbus to read info. The only time this cable not work for me and gave wrong info was when I connected wrong pad on 6120c. |
HI What Is Pinout Of Cable Rj45 For samsung m7600l | Braycel | UST Pro II | 1 | 10-28-2009 19:20 |
What is the cable used for sumsung F400 | foufou34 | HWK | 2 | 02-16-2009 15:05 |
What is SDmake 1.0p2 used for? | gatot_susatijo | Nokia Base Band 5 ( BB-5 ) | 1 | 05-16-2008 05:52 |
what is the service code use for? | JOEY.CN | LG | 2 | 12-16-2005 15:58 |
