Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Support (SIM Solution) > YESSIM
Old 07-25-2008, 19:17   #1 (permalink)
Member: 122236
Big problem with firmware 2.4 b and Nokia H3G Italy
Dear sirs,
I found out that new firmware 2.4b is not anymore compatible with Nokia 6280 / 6288 / 6680 and others. (the only one I've tested are H3G Italy SIM/OPERATOR lock)
After the update if I put a SIMCARD on this locked phone I have signal but I annot receive calls (many times I have no signal too), with firmware 2.3 it's perfect. I've tried to set H3G Italy operator on yessim, but even in this way bad results.
Is it possible to downgrade the yessim firmware to 2.3 or did you will quick make a new firmware?
I need to buy other 50 / 100 units, but in Italy I'm mostly sell them for nokia unlock, and with firmware 2.4 the risk is that most of them will not be useful for my clients.
Other question, wich parameter I need to use in orther to use with iphone 2g? Firmware 2.3 or 2.4?
Many thanks for your attention and hope for a quick reply.
Andrea
Old 07-26-2008, 00:17   #2 (permalink)
Member: 220008
I also have the same problem since the Yesim upgraded to version 2.4 I have worked with me nokias are in limited service or simnplemente not give signal to see if they can re-download the version 2.3 which will operate estabn as with other buys this version and are working smoothly expect prompt response
Old 07-26-2008, 06:41   #3 (permalink)
Member: 799206
Sonork: 100.67372
Thx for comments. I am sure we are facing other problems here. Would u pls add me on Yahoo so we can make some crossed test?
Big Problem with GDFS repairing on S500 and K810 Diman39 Cruiser Suite 1 12-05-2008 15:53
Julvir... very very big problem with C4-2 Spalato Redbox 1 12-29-2005 23:31
Page generated in 0.21540 seconds with 11 queries
