Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Support (SIM Solution) > YESSIM
Old 07-25-2008, 14:20   #16 (permalink)
Member: 303848
Thanks Meter: 14
Originally Posted by Yessim Support View Post
lol I think u are not YESSIM User u readand don't know what things are about
If you have better solution pls tell me I am in middle of 5000 Iphone 3G in hk will save me time
yes im yessim user and i sell yessim not a coder and part of ur team so i dont have solutions. i try your settings in my iphone 3g softbank phone after some hrs, 1 day no signal.
Old 07-25-2008, 15:34   #17 (permalink)
Member: 799206
Sonork: 100.67372
Thanks Meter: 276
contact me I will explain u Yahoo : ID gsmboutique
Old 07-26-2008, 05:38   #18 (permalink)
Member: 303848
Thanks Meter: 14
tenks for the supports sir, yessim is great product and supports are greats than others. so tenks sir i already satisfied with my iphone3g x-xxm inside.
Old 07-26-2008, 06:42   #19 (permalink)
Member: 624446
Thanks Meter: 5
@YessimSupport&beans
why you not share here what you did with iphone3g and got it working?and can you check please signal situation in 72 hours with 2G simcards.some phones loosing newtwork signal when changing location(celltowers).
Old 07-26-2008, 06:43   #20 (permalink)
Member: 799206
Sonork: 100.67372
Thanks Meter: 276
simply because we rather explain you step by step to avoid any problemes. it is easy add me on yahoo
I explain u the steps and make u happy
Old 07-28-2008, 20:30   #21 (permalink)
badi's Avatar
Member: 11945
Thanks Meter: 76
How is this? IPHONE3G Unlock mission Done...
Here are the right settings :
2.4 beta
Boost Mode
00101
Patch count 30
Our phone still not in our hands Thx to https://www.gsmphone-unlocking.com for the video
Enjoy your life in YESSIM
when w'll be available in stock?
regards.
Old 07-29-2008, 03:48   #22 (permalink)
Member: 799206
Sonork: 100.67372
Thanks Meter: 276
regards.
V2 Modified YESSIM ready for shipping just contact me via PM
Br.
Old 07-29-2008, 05:23   #23 (permalink)
Member: 799206
Sonork: 100.67372
Thanks Meter: 276
If you haveany problem onIphone make sure to make thismodif first:
http://www.yessim.com/hard_mod.php
Phonemust be Activated or Jaibreaked
Old 07-29-2008, 23:11   #24 (permalink)
Member: 825542
so to clarify:
i need to modify the yessim card (with yesup) before it works on iphone 3g?
Old 07-30-2008, 07:40   #25 (permalink)
Member: 799206
Sonork: 100.67372
Thanks Meter: 276
Originally Posted by geniux View Post
so to clarify:
Correct! And then should follow those steps:
1. Jailbreak your phone
2. Make sure your Carrier simcard is valid and catch network(better double check in any other phone)
3. Set your YESSIM as boost mode
4. Able DATA ROAMING in you Iphone
5. Put your Carrier sim and yessim into your Iphone 3G
6. Go to Plane mode then Normal mode on your Iphone 3G
7. In case you still have NO SERVICE kindly go to courier mode, wait for around 20s, an error message will be displayed and you will have network
Old 07-30-2008, 11:27   #26 (permalink)
Member: 825542
okido, thanks for the explanation, i'm gonna order one right away Any suggestions on whats the best place to order them (without having to wait for weeks)
Old 08-02-2008, 04:37   #27 (permalink)
Member: 66742
Sonork: 100.88618
Thanks Meter: 7
iPhone 3G AT&T USA
Successfully Unlocked AT&T USA iPhone 3G by YESSIM with tried 3 holes modification
Test with Indosat SIM. Outgoing Call, Incoming Call and Internet is ALL OK!
Reading Yessim info ..
Reading Yessim SN..OK.
Yessim SN : 0A0A0***
Frimware version : Yessim Firmware V:2.4 Beta (c)
MCC-MNC : 001-01
Mode : Normal Mode.
IMSI Patch Count : 1
Please select ON at Enable 3G and Data Roaming in the setting menu
But i hope YesSim support for Japan Mobiles too
Regards,
Irwan
Symphony-Shop.com
Old 08-02-2008, 10:11   #28 (permalink)
Member: 799206
Sonork: 100.67372
Thanks Meter: 276
Kindly get 1.7 client in dwl section. And update firmware to 2.4.4...enjoy
Old 08-03-2008, 04:43   #29 (permalink)
Member: 799206
Sonork: 100.67372
Thanks Meter: 276
@Joel
Thx for your email :
Good Morning !!
After a good night's sleep and internet searching for settings I have successfully got the Yessim to Work on the Japanese Softbank network using the 3G iPhone !!!! :-)
Settings: Universal Mode
Boost Mode on
Patch Count set at 30
Do not use MCC-MNC 44020 which is also the code for Japan Vodafone / Softbank because it does not work.
I can confirm that I can now receive phone calls, make phone calls. I need to test text messaging in a good reception area. 3G internet connectivity confirmed-- able to browse :-)
Could you advise on any better settings in case there is a problem with SMS texting. I will test it further this weekend to see if there is loss of complete settings in low reception areas etc....fingers crossed.
I hope this helps!!
By the way, how would you like to write up my review? On the Yessim forum ???
Please let me know accordingly.
All the best
Joel
Old 08-03-2008, 04:44   #30 (permalink)
Member: 799206
Sonork: 100.67372
Thanks Meter: 276
@Alexis! Thx for your feed back!
http://www.youtube.com/watch?v=E_iXs-hgmJE
Page generated in 0.21416 seconds with 8 queries
