Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Support (SIM Solution) > YESSIM
Old 08-02-2008, 08:30   #76 (permalink)
Member: 465819
i keep getting error while reading one of my yessim, while the rest are fine. is it spoilt?
Reading Yessim info ..
Reading Yessim SN..Error!
Old 08-02-2008, 09:53   #77 (permalink)
rudyandremely's Avatar
Member: 108193
Originally Posted by Yessim Support View Post
Please make the hardware modification on your sim. No cards will come back. Kindly talk to me on YAHOO ID : gsmboutik I will explain you all process and we will make test together
ok explain here please.
Old 08-02-2008, 10:13   #78 (permalink)
Member: 799206
Sonork: 100.67372
oki
Pls download new fclient from here : http://www.yessim.com/download.php
And check hardware modificatione here : http://www.yessim.com/hard_mod.php
Old 08-02-2008, 11:14   #79 (permalink)
Member: 828118
Maybe you press too much yessim on the yesup....try to be more delicate...and you'll see you will read all yessim 100% times! I had same problem in past...
Old 08-02-2008, 11:55   #80 (permalink)
Member: 465819
i had a few which i use with the same method and is able to read. only 1 pc is not able to read and keep giving error info.. so i dont think is how i press the yessim.
Old 08-02-2008, 12:27   #81 (permalink)
Member: 170548
LG-SH130
boost mode n normal mode, still can't read sim-card...
Old 08-02-2008, 13:46   #82 (permalink)
Member: 828118
Originally Posted by ardiancia View Post
LG-SH130
Maybe it works with 128k SIM only. Try to use a 128K sim
Old 08-02-2008, 14:23   #83 (permalink)
Member: 465819
pardon me but what is a 128k SIM and 64K sim?
Old 08-02-2008, 16:01   #84 (permalink)
Member: 64213
TESTED SAGEM MY411C OPERATOR O2
Searching YesUP..Found.
Reading Yessim SN..OK.
Yessim SN : ******
Frimware version : Firmware V :2.4 Beta4 (c)
MCC-MNC : 001-01
Mode : Boost Mode.
IMSI Patch Count : 30
Old 08-03-2008, 09:00   #85 (permalink)
FU_Too's Avatar
Member: 55766
oki
how about a direct link to get v1.7 as you need to register a second time after you click on download and for some reason my pc crashes with that site and i cant register. after this error I have to go into task manager to end iexplorer to unfreeze all current windows. so please give direct link from support not through another site
Old 08-03-2008, 12:46   #86 (permalink)
Member: 799206
Sonork: 100.67372
Here is direct link :
http://www.yessim.com/dwl/Yessim_17_USB_Cable.exe
The Following User Says Thank You to Yessim Support For This Useful Post:
Old 08-03-2008, 19:47   #87 (permalink)
Member: 90092
hi could u post direct link for rj45 clint v1.7 cannot seem to download from the site thanks in advance
Old 08-04-2008, 04:35   #88 (permalink)
Member: 799206
Sonork: 100.67372
Our server back online; You can dwl diretly from server. Sorry about this
Old 08-04-2008, 05:07   #89 (permalink)
EBRJO's Avatar
Member: 105175
the server is offline.... i cannot connect...
Old 08-04-2008, 15:51   #90 (permalink)
Member: 90092
thanks i did manage to download from the site. but when i am update frimware it showing ( Connecting to server... SERVER is OFFLINE!!! )
please sought this problem thanks
pls give us solution with this,after unlock contact service probs MT-BOX 1 03-10-2009 12:12
Please HELP To give us your Data Base djkadiross UnlockBase 3 09-20-2008 01:08
i have problem with KG220 from O2 when i want to make it arabic tsarkh VygisToolbox 4 06-13-2007 10:04
may be a problem with myx5, but after unlock phone unable to make call ashvin Redbox 2 07-24-2005 04:33
Page generated in 0.41951 seconds with 12 queries
