08-06-2008, 10:07 | #1 (permalink) |
Freak Poster Join Date: Apr 2004
Member: 63782 Status: Offline Thanks Meter: 7 | Solved Network Lose, Do TRY! After that do try cos i tested with other phone doesnt help sometime still network lose but for N95 to be the signal catcher it help with no problem till now, more than 2 weeks even Japan phones like p905i, sh905i, etc......!!! No Network signal Lost!!! Do try !!!!! Last edited by Yessim Support; 08-06-2008 at 10:21. |
08-06-2008, 10:55 | #2 (permalink) |
Freak Poster Join Date: Sep 2005 Age: 42
Member: 176522 Status: Offline Thanks Meter: 17 | yes,, we do that things,, but sad to say if you go to a place where there is no signal.. of cource the japan phone ex. toshiba 904 has lost it no signal.. then when you go back to the city were the signal is strenght,, the japan phone could not return back the signal... what you do is get out the sim card operator put it in the other unlock phone to catch a signal.. then insert it back to the japan phone so the signal will be back. this problem is very inconvenient to our client.... hope yessim team can address this problem |
08-06-2008, 11:03 | #3 (permalink) |
Member: 63782 Status: Offline Thanks Meter: 7 | you just try with the new updates 2.4 japan and use N95 unlocked with the sim card you want to put into the locked japan phone. then once u see signal make a call out then off it put it into the locked japan phone it will search the network by itself . Try you will know but only the new update. Softbank phone use 2.4japan, docomo phone use 2.4.4 |
08-06-2008, 17:43 | #4 (permalink) |
Member: 176522 Status: Offline Thanks Meter: 17 | I'll try your suggestion then i post here the result.. in fact i have here,, 2 pcs 804 sh,, 3 pcs 904t, 2 samsung softbank 707 II, ,705 P, toshiba 902, and more docomo,,foma,, these phone are return back to me because the signal will lost down after how many days.. i have to try those new setting,, provided by the yessim supporter.. from now on.. i just observe the phone that i have. |
08-11-2008, 14:47 | #6 (permalink) |
Member: 176522 Status: Offline Thanks Meter: 17 | not solve problem 904t & 804 sh, lost signal again. here is my previous post.. http://forum.gsmhosting.com/vbb/showthread.php?t=570014 after doing those suggestion by yessim team and other contributor.. my phone work fine in regards to incoming and outgoing text and call.. but the problem lost signal after a minimum of two days or more is not solve.. action taken: 1. modify the hardware from version 1 to 2. 2. i use different sim from 32, 64, and 72 k 3. make a different setting in yesup software Searching YesUP..Found. Reading Yessim info .. Reading Yessim SN..OK. Yessim SN : CB071B56 Frimware version : Firmware V: 2.4 beta Japan (c) MCC-MNC : 001-01 Mode : Normal Mode. IMSI Patch Count : 30 even i use firmware v : 2.3 is same also,, drop signal after how many days theres a lot of people who say it work with them,, please share it with me so i can testemony that is true.. i have a phone now 3 pcs toshiba 904,, 2 pcs sharp 804, toshiba 903, docomo F 902is.. below is my YM [email protected] hope yessim team can help to solve my problem. Report Post Reply With Quote so i apply your suggestion.. set to gsm mode and use different type of sim but still the signal will drop after how many days.. can help me? |
08-11-2008, 15:37 | #7 (permalink) |
Major Poster Join Date: Sep 2006
Member: 353802 Status: Offline Thanks Meter: 4 | The phone loses signal when changing from one Cell Tower to another it just do not catch network when changing Cell Tower. Also provider shows it twice. instead of shows ORANGE once. IT says orange Orange. I think this has to do with our network loss. |
08-11-2008, 16:06 | #8 (permalink) | |
Member: 176522 Status: Offline Thanks Meter: 17 | Quote:
thanks for the reply.. normally in our daily life.. we move our body from one place to another.. so in short.. the phone also move from here to there,,or sometimes to place where there is no signal.. but if you come back to place where the signal is.. it cannot catch-up so need to insert in other unlock phone to catch the network and return it back to the japanese phone. | |
08-15-2008, 04:23 | #10 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: Philippines
Member: 306786 Status: Offline Sonork: 100.1596805 Thanks Meter: 516 | Quote:
@YESSIM Team Pls. nextime don`t release your products if almost all model are not yet tested... This model 705sh, 812sh and 816sh are working fine with other sim, but in YESSIM always give a headache... | |
08-19-2008, 06:52 | #11 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Philippines
Member: 252201 Status: Offline Thanks Meter: 148 | same problem with me 804sh, 816sh, 705sh.. we need working solution not bla bla coz we invest money here with no ROI. |
The Following User Says Thank You to cetech For This Useful Post: |
08-21-2008, 03:07 | #13 (permalink) |
Member: 176522 Status: Offline Thanks Meter: 17 | hello to yessim team.. is there any good update to some of Japanese to fix the drop signal after how many days? do you have a solution now? or any setting that improve? most of us are waiting your reply.. not only me can encounter that problem.. mosy of us.. so i think there is little bug which is not you discouver in such Japanese phone model. |
08-23-2008, 04:15 | #14 (permalink) |
Member: 306786 Status: Offline Sonork: 100.1596805 Thanks Meter: 516 | We GIVE ALMOST ALL OUR FEEDBACKS...! BUT EVEN SMALL PIECE OF OUR SH*T FEEDBAcks STILL YOU CAN`T SOLVE...! |
The Following User Says Thank You to FMC_GSM For This Useful Post: |
huawei c2900 network lose after ftm mode off help | mayank bajaj | Various CDMA/TDMA Cell Phones | 4 | 03-29-2009 05:06 |
Always network lose | EALEXGC | YESSIM | 11 | 11-22-2008 17:59 |
Network Lose on iPhone 3G Fix HERE | yueyo | YESSIM | 10 | 08-14-2008 20:15 |
t600 to solve network problem | sudeeshveekey | Sony Ericsson | 11 | 06-06-2006 15:23 |
D500 Blocked To All U.k Networks, How Do I Unblock | solid_snake | SWIFT Platform | 3 | 09-24-2005 15:04 |
