Unlock Server
Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Support (SIM Solution) > YESSIM
Old 11-09-2008, 17:03   #1 (permalink)
Member: 217280
Yessim does not work on htc startrek
Hi!
Your Product does not work on HTC StarTrek. I tried all methods of settings and different Yessim Firmwares but always got the message "invalid Simcard, enter Unlock code" after entering the PIN Code.
The Standard Settings (Boost Mode, Patch Count 30, Universal Mode) did not work in this model.
Have someone fixed it?
Unterulmen
Old 11-09-2008, 19:13   #2 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
please try to use last firmware version and also try with Iphone Firmware or use patch count 1
Old 11-09-2008, 19:53   #3 (permalink)
Member: 397409
Configuration yessim
http://www.yessim.com/brand.php
Old 12-05-2008, 10:16   #4 (permalink)
Member: 217280
Sorry, that still does not work.
When I open the Link and choose HTC i get no models.
So pls give me the exact settings!
Old 12-05-2008, 10:57   #5 (permalink)
Member: 217280
Problem Solved!
I used the following settings (after approx. 200 tries):
___________________________________________
Firmware 2.3 (not one of that fu**ing Beta versions)
Boost Mode
MCC-MNC Set to which the phone is locked
Unlock Type 1
Patch count 1
If the phone canīt find a network after that, remove simcard and let this sim connect to the network in another mobile phone, which is unlocked or to the corresponding (to sim) network locked.
After that you can use yessim with locked startrek!
Either you have no settings on yout hompage or your php script is failing.
unterulmen
YesSim does not work with iphone 3G? i tried every version lost signal!!! pls respond virtue YESSIM 2 01-01-2009 00:56
3G card from optimus net work does not work on E616v unlocked RICSIL NEC 0 11-25-2004 17:15
Winimei for E700 does not work on all versions??? Burnt Cobba SYSOL Platform 10 05-27-2004 16:24
Vxxx Triplet Clip original Does not work on New V600 strangerboy P2k Series 7 05-25-2004 18:40
why t28 Data cable does not work on t65 mirghany Old Ericsson Phones & Sony Phones 4 02-10-2002 10:25
Page generated in 0.30261 seconds with 11 queries
