Unlock Server
Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > CPF-box Products > CPF-BOX Ⅱ
Old 07-16-2008, 14:33   #1 (permalink)
gsmfans's Avatar
Member: 612230
CPF-BOX II guides check here
How to detect MTK pinout,read/write flash file and format
First find phone'Pinout
Now,we can read phone、write phone、unlock phone
SET PHONE PINOUT:
READ PHONE:
WRITE PHONE:
UNLOCK PHONE(FORMAT FLASH)
FLASH SIZE——>FORMAT ADDRESS:
8M FLASH——>Begin address:0x700000,format length:0x100000
16M FLASH——>Begin address:0xE00000,format length:0x200000
64M FLASH——>Begin address:0x2000000,format length:0x2000000
128M FLASH——>Begin address:0x2000000,format length:0x6000000
The Following 13 Users Say Thank You to gsmfans For This Useful Post:
Old 07-16-2008, 14:36   #2 (permalink)
gsmfans's Avatar
Member: 612230
How to read/write/unlock SPD phone
SET CABLE:
Find the GND&VCC of the Phone,Inquires from the known definition
Then setup Cable.
Then connects the phone.Open Computer equipment supervisor
The platform found the port automatically.Now may carry on the operation to the telephone .
Read Flash:
Write Flash:
Telephone's starting password :
First read flash
then Click 'Find Password'
Telephone's security lock:
If flash size smaller than 16M,please write flash with the file no lock.
If flash size bigger than 16M(NAND flash),Please according to under method operation :
1.Read flash;
2.Erase Nand;(Before erasing open the flash files which already read )
[3.write flash.(with the flash files which already read)
The Following 3 Users Say Thank You to gsmfans For This Useful Post:
Old 07-16-2008, 14:41   #3 (permalink)
gsmfans's Avatar
Member: 612230
How to write SI4904 cpu flash file
Detect the definition
Save cable:
Run Software,set cable:
Write Flash:
The Following User Says Thank You to gsmfans For This Useful Post:
Old 07-16-2008, 14:42   #4 (permalink)
gsmfans's Avatar
Member: 612230
How to read/write/unlock philips CPU
Set Cable:
Read Flash:
Write Flash:
Find password:
Old 07-16-2008, 14:43   #5 (permalink)
gsmfans's Avatar
Member: 612230
How to read/write/unlock TI cpu
[Set Cable:TI CPU USE FT232BM
Read Flash:FT232BM(com19)+Baud(812500):
Write Flash:
Find password:
The Following 2 Users Say Thank You to gsmfans For This Useful Post:
Old 07-16-2008, 14:45   #6 (permalink)
gsmfans's Avatar
Member: 612230
How to read/write/unlock infineon 7880CPU
Set Cable:
Read Flash:Select Flash Type
Write Flash:
Find password:
Old 07-16-2008, 14:47   #7 (permalink)
gsmfans's Avatar
Member: 612230
How to read/write infineon 7870cpu flash file
Save cable:
Read flash:
Write flash:
Old 07-16-2008, 14:50   #8 (permalink)
gsmfans's Avatar
Member: 612230
How to write infineon 7850CPU flash file
Detect RX/TX
Save Cable:
Run software,Set Cable:
Select Flash Type
Open Flash Fiel
Write Flash
Old 07-16-2008, 14:52   #9 (permalink)
gsmfans's Avatar
Member: 612230
How to read/write/unlock ADI CPU
Set Cable
Read Flash:
Write Flash:
Find Password:
Old 07-16-2008, 14:54   #10 (permalink)
gsmfans's Avatar
Member: 612230
How to rread/write SKY flash file
Set Cable:
Read Flash:
8M Flash:Base Address_1000000 or 400000
16M Flash:Base Address_1000000
32M Flash:Base Address_1000000
12M Flash:Base Address_400000
Write Flash:
Old 07-16-2008, 14:57   #11 (permalink)
gsmfans's Avatar
Member: 612230
How to auto detect charger pin and USB pinout
Must insert a MMC in phone before find USB pinout
Select 'Detect':
Select 'Detect Usb':
Select 'Cable':
Select 'Detect Charge Pin':Heavy line black clip +Red line red clip
first need to detctet charger pin, when soft mark a pin and show command for select it or not, at the moment though your phone show charging in phone screen, click "YES" though phone not show charging click "NO" and though you find charger pin next find D+ D- and though not found this pin, after you click "NO" soft find again charger pin than one time soft find correct charger pin by checking every pin.
Set charge Pin with VCC:
Click 'Detect USB':
Click 'YES'
Detected USBD+,USBD-
Save cable:
The Following 12 Users Say Thank You to gsmfans For This Useful Post:
Old 08-07-2008, 17:03   #12 (permalink)
gsmfans's Avatar
Member: 612230
how to use new 7880 platform avert sim lock
The Following 16 Users Say Thank You to gsmfans For This Useful Post:
CPF-BOX II Updates check here! phones-china CPF-BOX Ⅱ 54 08-06-2011 09:22
intending to buy cpf box II benny Haraba CPF-BOX Ⅱ 10 09-06-2010 14:05
what is CPF-BOX II sharaz191 CPF-BOX Ⅱ 4 09-06-2010 13:52
Can't download Guide for CPF Box II tomlat CPF-BOX Ⅱ 1 09-01-2009 07:12
CPF-BOX II features! phones-china CPF-BOX Ⅱ 0 07-16-2008 14:37
Page generated in 4.63424 seconds with 12 queries
