Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > CPF-box Products > CPF-BOX Ⅱ
Old 06-15-2010, 12:46   #1 (permalink)
ru_dee's Avatar
Member: 911645
HELP :back-up/ Format mt 6235 using flashtool
phone model Taxco VX1; mt6235
error loading sms
i intended to back-up and format it using cpf box.
pin detection succeeded using CPF BOX.
but got an error while reading: error 300, 307
then i tried using flash tool, while using cpf box as interface.
here's memory test using flashtool 3.1016
===============    Memory Detection Report     ===============
Internal RAM:
    Size = 0x00010000 (64KB)
External RAM:
    ERROR: External RAM was not detected!
NOR Flash:
    ERROR: NOR Flash was not detected!
NAND Flash:
    Device ID = "[TOSHIBA] TC58NVG0S3AFT" (20)
    Size = 0x08000000 (128MB/1024Mb)
the problem is i'm unsure which address shoould i fill in its lenght address.
when i need to back-up/ format this phone, on length tab what address should i fill in?
is it length/ end address= size = 0x08000000?
i tried it
and i got error message
please help me, how to solve this problem?
Old 06-15-2010, 13:39   #2 (permalink)
ru_dee's Avatar
Member: 911645
and now i got a dead phone
Old 06-16-2010, 15:38   #3 (permalink)
ru_dee's Avatar
Member: 911645
hello, where is supporter...
anyone please help
Old 06-16-2010, 15:50   #4 (permalink)
FasGsm's Avatar
Member: 283725
Sonork: 100.1584053
cpf should read [TOSHIBA] TC58NVG0S3AFT bec support it. u try with both mtk tool? with low baud rate? if stiill want to read with flash tool use new version and read it with low baud rate.
Old 06-17-2010, 01:26   #5 (permalink)
Member: 251293
not supported yet , i have the same chip and nand flash chip like that
i used other sw it supported yet
Old 06-17-2010, 01:27   #6 (permalink)
Member: 251293
Timer: _2010_6_16_23_12_9>> Press ON/OFF key please...
Timer: _2010_6_16_23_12_11>> Target's hw_ver :0x0001
Timer: _2010_6_16_23_12_11>> Target's new hw_ver :0x8A04
Timer: _2010_6_16_23_12_11>> Target's hw_code :0x6235
Timer: _2010_6_16_23_12_11>> Target's sw_ver :0x8A01
Timer: _2010_6_16_23_12_12>> Get correct bootloader for target...
Timer: _2010_6_16_23_12_12>> MTK_AllInOne_DA_v3.0952.00.00
Timer: _2010_6_16_23_12_12>> DA--->6 is selected!
Timer: _2010_6_16_23_12_12>> You can release ON/OFF key!
Timer: _2010_6_16_23_12_12>> [DA] loading bootloader 1...
Success!Timer: _2010_6_16_23_12_20>> [DA] loading bootloader 2...
Success!Timer: _2010_6_16_23_12_28>> [BROM] start to test UART link...
Timer: _2010_6_16_23_12_28>> [DA] Check NOR flash IC...
Fail!Timer: _2010_6_16_23_12_30>> [DA] Check NAND flash IC...
Timer: _2010_6_16_23_12_30>> Waiting the bootloader initilize...
Timer: _2010_6_16_23_12_31>> [COM] Success to set baudrate!
Timer: _2010_6_16_23_12_31>> [DA] Bootloader running now,OK
Timer: _2010_6_16_23_12_38>> [DA] Can not get auto format address&size,by Mannul please!
Timer: _2010_6_16_23_12_39>> [DA] Start to read Target flash
Timer: _2010_6_16_23_12_39>> [DA] Backup NAND to:NEOTEL35_08B_GEMINI_PCB01_GPRS_MT6235B_S01.B300 _GH_EN1_TY1G_JST_V005.bin
Timer: _2010_6_16_23_12_39>> Start:[0x00000000] size:[0x08000000]
Timer: _2010_6_16_23_12_39>> [DA] Nand data size 0x08400000 will be readed...
Timer: _2010_6_17_6_14_36>> [DA] file size:138412032Bytes
Timer: _2010_6_17_6_14_36>> [DA] Read full flash file complete!
i used other tool
Old 06-17-2010, 01:29   #7 (permalink)
Member: 251293
Waiting for phone's response,press the Power on the phone
Connecting...
Hardware version:8A04
CPU Type:6235
Software version:8A01
Boot downloading complete!
Flash type: NAND_UNKNOWN
Baud adjust...complete.
Flash reading...
>>Error 300
i used cpf box
Old 06-17-2010, 05:20   #8 (permalink)
ru_dee's Avatar
Member: 911645
yes Sir ,i tried with both of them, tried all sets of baudrate,
here's log when i used the lowest -115200-
using mt expanded 3.11
  Available Ports:COM1 COM2 COM7 COM16 COM32 COM33
  Current Port:COM16
  Connecting...
  CPU Type:6235
  Flash reading...
>>Error 300
here's using mt ver 2.65b
lowest baudrate
Old 06-17-2010, 05:54   #9 (permalink)
ru_dee's Avatar
Member: 911645
tried also using flash tool 3.1016.
i think it is the latest, baudrate 115200
still the same error: S_FT_READBACK_FAIL (4010)
Old 06-17-2010, 06:02   #10 (permalink)
FasGsm's Avatar
Member: 283725
Sonork: 100.1584053
ok New update will support fully that flash chip [TOSHIBA] TC58NVG0S3AFT w8 till next weak.
The Following User Says Thank You to FasGsm For This Useful Post:
Old 06-17-2010, 06:38   #11 (permalink)
duniacell's Avatar
Member: 958761
i used other tool
it seems a good tool.
what tool name it, sir?
I want to buy too.
Old 06-18-2010, 08:55   #12 (permalink)
Member: 251293
I want to buy too.
i used spiderman with new update 2.65
but when tyring to read backup , it size almost 128 mb cause never have backup before ,so i search by google and this site too , there is no fw with 128 mb size only on infinity i found the fw seem almost like those fw but with lower version its only 18 mb
maybe product supporter can explain why backup from nand flash chip it has different size then from the site,isn't it?
i also have CPF BOX but i still wait for next update, been waiting for along time honestly product supporter had a big update for next week
also for nand flash chip
Old 06-18-2010, 09:57   #13 (permalink)
nanoy's Avatar
Member: 724814
next week...????? are you serious sir...?
i'm waiting....
br
Old 06-18-2010, 10:37   #14 (permalink)
Member: 161279
i hope so next week,not month or year
Old 06-19-2010, 04:20   #15 (permalink)
Member: 251293
appreciating our product supporter honestly, but we can't wait so long too
we have tool that we have to use it , we need to make money , cause there is lot of phone comes to our service centre like those fiture
so we need fast support too
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 16 02-01-2012 05:18
HELP!!! BACKGROUND SCREEN LOGO Michael Go Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-25-2011 23:56
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 11-29-2010 18:04
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
Winlock 1.10 - Help rdmfs Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 06-25-1999 08:21
Page generated in 0.59443 seconds with 11 queries
