01-30-2010, 15:13 | #1 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 469011 Status: Offline Thanks Meter: 33 | help me cpf teem Information: Before the system self-inspect, make sure the computer and the the USB ports and serial port connections have been good, and ensuring that equipment did not connected to any mobile phone. Click "XX test" button will activate the internal software for the automatic detection procedures, the process will lasts 1 or 2 minutes, then will give the test results . You may based on this result to determine whether the software for internal have any faults . Is Base pin testing... On circuit 3 the number of rounds send cannot receive. On circuit 4 the number of rounds send cannot receive. On circuit 3 Tests Dtr, Dcd no changed. On circuit 3 Tests Dtr, DSR no changed. On circuit 3 Tests Dtr, Cts no changed. On circuit 3 Tests Dtr, Ri no changed. On circuit 4 Tests Dtr, Dcd no changed. On circuit 4 Tests Dtr, DSR no changed. On circuit 4 Tests Dtr, Cts no changed. On circuit 4 Tests Dtr, Ri no changed. On circuit 15 the number of rounds send cannot receive. On circuit 16 the number of rounds send cannot receive. On circuit 15 Tests Dtr, Dcd no changed. On circuit 15 Tests Dtr, DSR no changed. On circuit 15 Tests Dtr, Cts no changed. On circuit 15 Tests Dtr, Ri no changed. On circuit 16 Tests Dtr, Dcd no changed. On circuit 16 Tests Dtr, DSR no changed. On circuit 16 Tests Dtr, Cts no changed. On circuit 16 Tests Dtr, Ri no changed. Pin 4 short-circuits with Pin 14. Serial port receiving and dispatching makes a mistake. Serial port receiving and dispatching makes a mistake. * The base pin test finished Is Voltage testing... When Pin 3(10) set VCC, Pin 1(6)'s voltage is high, the value is 5.00v When Pin 3(10) set VCC, Pin 4(12)'s voltage is high, the value is 4.93v When Pin 3(10) set VCC, Pin 5(14)'s voltage is high, the value is 5.00v When Pin 3(10) set VCC, Pin 6(16)'s voltage is high, the value is 4.89v When Pin 3(10) set VCC, Pin 7(18)'s voltage is high, the value is 5.00v When Pin 3(10) set VCC, Pin 9(21)'s voltage is high, the value is 5.00v When Pin 3(10) set VCC, Pin 11(5)'s voltage is high, the value is 5.00v When Pin 3(10) set VCC, Pin 12(9)'s voltage is high, the value is 4.92v When Pin 3(10) set VCC, Pin 13(11)'s voltage is high, the value is 5.00v When Pin 3(10) set VCC, Pin 14(13)'s voltage is high, the value is 4.93v When Pin 3(10) set VCC, Pin 15(15)'s voltage is high, the value is 5.00v When Pin 3(10) set VCC, Pin 17(19)'s voltage is high, the value is 5.00v When Pin 3(10) set VCC, Pin 19(3)'s voltage is high, the value is 5.00v When Pin 3(10) set VCC, Pin 20(7)'s voltage is high, the value is 4.91v When Pin 3(10) set VCC, Pin 21(2)'s voltage is high, the value is 5.00v When Pin 3(10) set VCC, Pin 23(24)'s voltage is high, the value is 5.00v When Pin 4(12) set VCC, Pin 1(6)'s voltage is high, the value is 5.00v When Pin 4(12) set VCC, Pin 3(10)'s voltage is high, the value is 5.00v When Pin 4(12) set VCC, Pin 5(14)'s voltage is high, the value is 5.00v When Pin 4(12) set VCC, Pin 6(16)'s voltage is high, the value is 4.91v When Pin 4(12) set VCC, Pin 7(18)'s voltage is high, the value is 5.00v When Pin 4(12) set VCC, Pin 9(21)'s voltage is high, the value is 5.00v When Pin 4(12) set VCC, Pin 11(5)'s voltage is high, the value is 5.00v When Pin 4(12) set VCC, Pin 12(9)'s voltage is high, the value is 4.93v When Pin 4(12) set VCC, Pin 13(11)'s voltage is high, the value is 5.00v When Pin 4(12) set VCC, Pin 14(13)'s voltage is high, the value is 4.95v When Pin 4(12) set VCC, Pin 15(15)'s voltage is high, the value is 5.00v When Pin 4(12) set VCC, Pin 17(19)'s voltage is high, the value is 5.00v When Pin 4(12) set VCC, Pin 19(3)'s voltage is high, the value is 5.00v When Pin 4(12) set VCC, Pin 20(7)'s voltage is high, the value is 4.93v When Pin 4(12) set VCC, Pin 21(2)'s voltage is high, the value is 5.00v When Pin 4(12) set VCC, Pin 23(24)'s voltage is high, the value is 5.00v When Pin 5(14) set VCC, Pin 1(6)'s voltage is high, the value is 5.00v When Pin 5(14) set VCC, Pin 3(10)'s voltage is high, the value is 5.00v When Pin 5(14) set VCC, Pin 4(12)'s voltage is high, the value is 4.91v When Pin 5(14) set VCC, Pin 6(16)'s voltage is high, the value is 4.91v When Pin 5(14) set VCC, Pin 7(18)'s voltage is high, the value is 5.00v When Pin 5(14) set VCC, Pin 9(21)'s voltage is high, the value is 5.00v When Pin 5(14) set VCC, Pin 11(5)'s voltage is high, the value is 5.00v When Pin 5(14) set VCC, Pin 12(9)'s voltage is high, the value is 4.93v When Pin 5(14) set VCC, Pin 13(11)'s voltage is high, the value is 5.00v When Pin 5(14) set VCC, Pin 14(13)'s voltage is high, the value is 4.94v When Pin 5(14) set VCC, Pin 15(15)'s voltage is high, the value is 5.00v When Pin 5(14) set VCC, Pin 17(19)'s voltage is high, the value is 5.00v When Pin 5(14) set VCC, Pin 19(3)'s voltage is high, the value is 5.00v When Pin 5(14) set VCC, Pin 20(7)'s voltage is high, the value is 4.92v When Pin 5(14) set VCC, Pin 21(2)'s voltage is high, the value is 5.00v When Pin 5(14) set VCC, Pin 23(24)'s voltage is high, the value is 5.00v When Pin 6(16) set VCC, Pin 1(6)'s voltage is high, the value is 5.00v When Pin 6(16) set VCC, Pin 3(10)'s voltage is high, the value is 5.00v When Pin 6(16) set VCC, Pin 4(12)'s voltage is high, the value is 4.92v When Pin 6(16) set VCC, Pin 5(14)'s voltage is high, the value is 5.00v When Pin 6(16) set VCC, Pin 7(18)'s voltage is high, the value is 5.00v When Pin 6(16) set VCC, Pin 9(21)'s voltage is high, the value is 5.00v When Pin 6(16) set VCC, Pin 11(5)'s voltage is high, the value is 5.00v When Pin 6(16) set VCC, Pin 12(9)'s voltage is high, the value is 4.92v When Pin 6(16) set VCC, Pin 13(11)'s voltage is high, the value is 5.00v When Pin 6(16) set VCC, Pin 14(13)'s voltage is high, the value is 4.93v When Pin 6(16) set VCC, Pin 15(15)'s voltage is high, the value is 5.00v When Pin 6(16) set VCC, Pin 17(19)'s voltage is high, the value is 5.00v When Pin 6(16) set VCC, Pin 19(3)'s voltage is high, the value is 5.00v When Pin 6(16) set VCC, Pin 20(7)'s voltage is high, the value is 4.91v When Pin 6(16) set VCC, Pin 21(2)'s voltage is high, the value is 5.00v When Pin 6(16) set VCC, Pin 23(24)'s voltage is high, the value is 5.00v When Pin 11(5) set VCC, Pin 12(9)'s voltage is high, the value is 4.92v When Pin 12(9) set VCC, Pin 1(6)'s voltage is high, the value is 5.00v When Pin 12(9) set VCC, Pin 3(10)'s voltage is high, the value is 5.00v When Pin 12(9) set VCC, Pin 4(12)'s voltage is high, the value is 4.92v When Pin 12(9) set VCC, Pin 5(14)'s voltage is high, the value is 5.00v When Pin 12(9) set VCC, Pin 6(16)'s voltage is high, the value is 4.89v When Pin 12(9) set VCC, Pin 7(18)'s voltage is high, the value is 5.00v When Pin 12(9) set VCC, Pin 9(21)'s voltage is high, the value is 5.00v When Pin 12(9) set VCC, Pin 11(5)'s voltage is high, the value is 5.00v When Pin 12(9) set VCC, Pin 13(11)'s voltage is high, the value is 5.00v When Pin 12(9) set VCC, Pin 14(13)'s voltage is high, the value is 4.93v When Pin 12(9) set VCC, Pin 15(15)'s voltage is high, the value is 5.00v When Pin 12(9) set VCC, Pin 17(19)'s voltage is high, the value is 5.00v When Pin 12(9) set VCC, Pin 19(3)'s voltage is high, the value is 5.00v When Pin 12(9) set VCC, Pin 20(7)'s voltage is high, the value is 4.92v When Pin 12(9) set VCC, Pin 21(2)'s voltage is high, the value is 5.00v When Pin 12(9) set VCC, Pin 23(24)'s voltage is high, the value is 5.00v When Pin 13(11) set VCC, Pin 14(13)'s voltage is high, the value is 4.95v When Pin 14(13) set VCC, Pin 1(6)'s voltage is high, the value is 5.00v When Pin 14(13) set VCC, Pin 3(10)'s voltage is high, the value is 5.00v When Pin 14(13) set VCC, Pin 4(12)'s voltage is high, the value is 4.94v When Pin 14(13) set VCC, Pin 5(14)'s voltage is high, the value is 5.00v When Pin 14(13) set VCC, Pin 6(16)'s voltage is high, the value is 4.92v When Pin 14(13) set VCC, Pin 7(18)'s voltage is high, the value is 5.00v When Pin 14(13) set VCC, Pin 9(21)'s voltage is high, the value is 5.00v When Pin 14(13) set VCC, Pin 11(5)'s voltage is high, the value is 5.00v When Pin 14(13) set VCC, Pin 12(9)'s voltage is high, the value is 4.94v When Pin 14(13) set VCC, Pin 13(11)'s voltage is high, the value is 5.00v When Pin 14(13) set VCC, Pin 15(15)'s voltage is high, the value is 5.00v When Pin 14(13) set VCC, Pin 17(19)'s voltage is high, the value is 5.00v When Pin 14(13) set VCC, Pin 19(3)'s voltage is high, the value is 5.00v When Pin 14(13) set VCC, Pin 20(7)'s voltage is high, the value is 4.94v When Pin 14(13) set VCC, Pin 21(2)'s voltage is high, the value is 5.00v When Pin 14(13) set VCC, Pin 23(24)'s voltage is high, the value is 5.00v When Pin 15(15) set VCC, Pin 1(6)'s voltage is high, the value is 5.00v When Pin 15(15) set VCC, Pin 3(10)'s voltage is high, the value is 5.00v When Pin 15(15) set VCC, Pin 4(12)'s voltage is high, the value is 4.92v When Pin 15(15) set VCC, Pin 5(14)'s voltage is high, the value is 5.00v When Pin 15(15) set VCC, Pin 6(16)'s voltage is high, the value is 4.90v When Pin 15(15) set VCC, Pin 7(18)'s voltage is high, the value is 5.00v When Pin 15(15) set VCC, Pin 9(21)'s voltage is high, the value is 5.00v When Pin 15(15) set VCC, Pin 11(5)'s voltage is high, the value is 5.00v When Pin 15(15) set VCC, Pin 12(9)'s voltage is high, the value is 4.92v When Pin 15(15) set VCC, Pin 13(11)'s voltage is high, the value is 5.00v When Pin 15(15) set VCC, Pin 14(13)'s voltage is high, the value is 4.93v When Pin 15(15) set VCC, Pin 17(19)'s voltage is high, the value is 5.00v When Pin 15(15) set VCC, Pin 19(3)'s voltage is high, the value is 5.00v When Pin 15(15) set VCC, Pin 20(7)'s voltage is high, the value is 4.91v When Pin 15(15) set VCC, Pin 21(2)'s voltage is high, the value is 5.00v When Pin 15(15) set VCC, Pin 23(24)'s voltage is high, the value is 5.00v When Pin 19(3) set VCC, Pin 20(7)'s voltage is high, the value is 4.93v When Pin 20(7) set VCC, Pin 1(6)'s voltage is high, the value is 5.00v When Pin 20(7) set VCC, Pin 3(10)'s voltage is high, the value is 5.00v When Pin 20(7) set VCC, Pin 4(12)'s voltage is high, the value is 4.92v When Pin 20(7) set VCC, Pin 5(14)'s voltage is high, the value is 5.00v When Pin 20(7) set VCC, Pin 6(16)'s voltage is high, the value is 4.90v When Pin 20(7) set VCC, Pin 7(18)'s voltage is high, the value is 5.00v When Pin 20(7) set VCC, Pin 9(21)'s voltage is high, the value is 5.00v When Pin 20(7) set VCC, Pin 11(5)'s voltage is high, the value is 5.00v When Pin 20(7) set VCC, Pin 12(9)'s voltage is high, the value is 4.94v When Pin 20(7) set VCC, Pin 13(11)'s voltage is high, the value is 5.00v When Pin 20(7) set VCC, Pin 14(13)'s voltage is high, the value is 4.93v When Pin 20(7) set VCC, Pin 15(15)'s voltage is high, the value is 5.00v When Pin 20(7) set VCC, Pin 17(19)'s voltage is high, the value is 5.00v When Pin 20(7) set VCC, Pin 19(3)'s voltage is high, the value is 5.00v When Pin 20(7) set VCC, Pin 21(2)'s voltage is high, the value is 5.00v When Pin 20(7) set VCC, Pin 23(24)'s voltage is high, the value is 5.00v When circuit 3(10) set GND, the voltage is excessively hign, the value is 3.39v When circuit pin4(12)set GND, Pin 1(6)voltage is low , the value is 0.00v When circuit pin4(12)set GND, Pin 3(10)voltage is low , the value is 0.01v When circuit pin4(12)set GND, Pin 5(14)voltage is low , the value is 0.03v When circuit pin4(12)set GND, Pin 7(18)voltage is low , the value is 0.00v When circuit pin4(12)set GND, Pin 9(21)voltage is low , the value is 0.00v When circuit pin4(12)set GND, Pin 11(5)voltage is low , the value is 0.14v When circuit pin4(12)set GND, Pin 13(11)voltage is low , the value is 0.09v When circuit pin4(12)set GND, Pin 15(15)voltage is low , the value is 0.00v When circuit pin4(12)set GND, Pin 17(19)voltage is low , the value is 0.00v When circuit pin4(12)set GND, Pin 19(3)voltage is low , the value is 0.04v When circuit pin4(12)set GND, Pin 21(2)voltage is low , the value is 0.00v When circuit pin4(12)set GND, Pin 23(24)voltage is low , the value is 0.00v When circuit pin5(14)set GND, Pin 7(18)voltage is low , the value is 0.00v When circuit pin13(11)set GND, Pin 14(13)voltage is low , the value is 0.18v When circuit pin14(13)set GND, Pin 1(6)voltage is low , the value is 0.00v When circuit pin14(13)set GND, Pin 3(10)voltage is low , the value is 0.08v When circuit pin14(13)set GND, Pin 5(14)voltage is low , the value is 0.03v When circuit pin14(13)set GND, Pin 7(18)voltage is low , the value is 0.00v When circuit pin14(13)set GND, Pin 9(21)voltage is low , the value is 0.00v When circuit pin14(13)set GND, Pin 11(5)voltage is low , the value is 0.13v When circuit pin14(13)set GND, Pin 13(11)voltage is low , the value is 0.01v When circuit pin14(13)set GND, Pin 15(15)voltage is low , the value is 0.00v When circuit pin14(13)set GND, Pin 17(19)voltage is low , the value is 0.00v When circuit pin14(13)set GND, Pin 19(3)voltage is low , the value is 0.04v When circuit pin14(13)set GND, Pin 21(2)voltage is low , the value is 0.00v When circuit pin14(13)set GND, Pin 23(24)voltage is low , the value is 0.00v When circuit 15(15) set GND, the voltage is excessively hign, the value is 3.25v * The voltage test finished. help me fast thenks |
01-30-2010, 16:17 | #3 (permalink) | |
Freak Poster Join Date: Sep 2009 Location: another place
Member: 1128422 Status: Offline Thanks Meter: 67 | Quote:
i am sorry... the problem just like this : http://forum.gsmhosting.com/vbb/showthread.php?t=870073 may be someone already have the solution. BR | |
instalation vedio plz help me mx teem | mobiletuch | Nokia Hardware & Hardware Repair | 1 | 01-07-2010 11:09 |
Mxkey problam Please Help me Mxkey teem | SYRYA TEL | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 12-20-2009 09:04 |
please cpf teem help me | mithon | CPF-BOX Ⅱ | 0 | 12-10-2009 14:07 |
