06-30-2010, 05:59 | #1 (permalink) |
Freak Poster Join Date: Feb 2008 Location: Djemboet City, Alaska
Member: 712974 Status: Offline Thanks Meter: 55 | HElp.. My box can't Detect Rx/ TX my box can't detect Rx/ TX... especially to E107 & E 036 I try to do according to the procedure of the CPF team recommended but but still the same.. my box can't detect RX/ TX from the normal Phone this is log: * Best Pin Test: Code: Is Base pin testing... On circuit 1 the number of rounds send cannot receive. On circuit 2 the number of rounds send cannot receive. On circuit 1 Tests Dtr, Dcd no changed. On circuit 1 Tests Dtr, DSR no changed. On circuit 1 Tests Dtr, Cts no changed. On circuit 1 Tests Dtr, Ri no changed. On circuit 2 Tests Dtr, Dcd no changed. On circuit 2 Tests Dtr, DSR no changed. On circuit 2 Tests Dtr, Cts no changed. On circuit 2 Tests Dtr, Ri no changed. On circuit 9 the number of rounds send cannot receive. On circuit 10 the number of rounds send cannot receive. On circuit 9 Tests Dtr, Dcd no changed. On circuit 9 Tests Dtr, DSR no changed. On circuit 9 Tests Dtr, Cts no changed. On circuit 9 Tests Dtr, Ri no changed. On circuit 10 Tests Dtr, Dcd no changed. On circuit 10 Tests Dtr, DSR no changed. On circuit 10 Tests Dtr, Cts no changed. On circuit 10 Tests Dtr, Ri no changed. On circuit 13 the number of rounds send cannot receive. On circuit 14 the number of rounds send cannot receive. On circuit 13 Tests Dtr, Dcd no changed. On circuit 13 Tests Dtr, DSR no changed. On circuit 13 Tests Dtr, Cts no changed. On circuit 13 Tests Dtr, Ri no changed. On circuit 14 Tests Dtr, Dcd no changed. On circuit 14 Tests Dtr, DSR no changed. On circuit 14 Tests Dtr, Cts no changed. On circuit 14 Tests Dtr, Ri no changed. * When tests 7 the short circuit and set 2303, Receive order data failed. Code: Is Voltage testing... * The voltage test finished. Code: The system is restoring ... * The system recovery finished. Code: Is detecting Vcc and Gnd... ... Vcc: 4 Gnd: 2 Is detecting the short circuit pin... ... Has not found the short circuit pin. Is detecting the input output ... ... Input Pin: 6 8 10 Output Pin: 1 5 7 9 * The detect finished! Code: Is detecting Vcc and Gnd... ... Vcc: 4 Gnd: 2 Is detecting the short circuit pin... ... Has not found the short circuit pin. Detection is starting, please connect the phone well and press Power-on button... * [Detect] - Has not detected RX and TX, the detection overtime, please try again. thanks be for.... br, r4r4 |
07-03-2010, 08:02 | #4 (permalink) |
Freak Poster Join Date: Mar 2010
Member: 1272863 Status: Offline Thanks Meter: 33 | open software, push detect upperside choose cable number , mtk, and push detect rx tx , (phone must be connected with voltage cables and not open) first soft see your phone gnd , If it not see gnd. I do not think rx and tx will see after writing power on device, push your phone power on , cpf find your rx tx. ( if you cannot caught that point, your box right lamp not lighting , try again) |
The Following User Says Thank You to protool For This Useful Post: |
07-04-2010, 05:22 | #5 (permalink) | |
Member: 712974 Status: Offline Thanks Meter: 55 | Quote:
but my box can't find rx tx Is detecting Vcc and Gnd... ... Vcc: 4 Gnd: 2 Is detecting the short circuit pin... ... Has not found the short circuit pin. Detection is starting, please connect the phone well and press Power-on button... * [Detect] - Has not detected RX and TX, the detection overtime, please try again. i think my box is trouble..... but i don't know where's the problem.... | |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
