03-02-2009, 05:47 | #1 (permalink) |
Freak Poster Join Date: Jul 2008 Location: 中国
Member: 811677 Status: Offline Thanks Meter: 192 | <<<< How to avoid & remove infineon 7880 sim lock (Updates)>>>> now i explain here how to avoid infineon 7880 sim lock: ---------------------------------------------------- when a infineon 7880 cpu phone we recive from client, maybe its dead, restarting, no net etc etc. than we try to flash this phone with a good flash file. but, its not correct solution. when you recive a phone 7880 cpu, you must first read phone current flash file (maybe this file is bad, also you read it first) than when you flash your phone, you must write "full flash" full flash = write 2 file at a time (phone read bad file and a good flash file) normally "phone file" option was hide, but when you mark on "full flash" now you can work with it. see pic- if you do flash by this way, you don't face "sim lock" problem for infineon 7880 cpu phone. thanks Last edited by .::CPF-TEAM::.; 03-02-2009 at 09:48. |
The Following 15 Users Say Thank You to .::CPF-TEAM::. For This Useful Post: |
03-08-2009, 18:18 | #2 (permalink) |
Member: 811677 Status: Offline Thanks Meter: 192 | if you do wrong to write full flash, here is how to rebuild IMEI and remove "sim lock block" ================================================== =============== here is tool and configuration file- download this tool and configuration fie, setup "infineon phone tool setup" than paste configuration file to your pc this folder > C:\Program Files\IFWD\PhoneTool_ulc_8_1_ULC2 infineon phone tool download Configuration file here- file 1 file 2 file 3 file 4 Last edited by .::CPF-TEAM::.; 09-09-2009 at 09:48. |
The Following 4 Users Say Thank You to .::CPF-TEAM::. For This Useful Post: |
03-08-2009, 18:25 | #3 (permalink) |
Member: 811677 Status: Offline Thanks Meter: 192 | Manual for use this tool ================================================== == after this process, flash your phone with a good flash file Last edited by .::CPF-TEAM::.; 03-08-2009 at 19:25. |
The Following 3 Users Say Thank You to .::CPF-TEAM::. For This Useful Post: |
03-08-2009, 18:27 | #4 (permalink) |
Member: 811677 Status: Offline Thanks Meter: 192 | if you phone not going to "test mode" by pressing * + # + pw how to enter test mode, see here- |
The Following 6 Users Say Thank You to .::CPF-TEAM::. For This Useful Post: |
03-08-2009, 18:28 | #5 (permalink) | |
Member: 811677 Status: Offline Thanks Meter: 192 | video manual for this tool Download Video Manual Quote:
The Following 18 Users Say Thank You to .::CPF-TEAM::. For This Useful Post: |
Secured update not possible, device not prepared. - how to avoid it? | Stoyan | S-Gold Based Phones | 7 | 11-01-2009 23:57 |
How to avoid damaged erom? | Simonee | Cruiser Suite | 4 | 04-09-2007 21:28 |
How to avoid contact service in 6610i 100%? | hooi76 | UFS2 + UFS3-Tornadoflasher | 11 | 07-22-2005 04:56 |
How to Unlock MW 930 from D2 - Sim Locked ? | AboAli | Infineon C16X M51 & ARM7 M52 BASED | 1 | 07-07-2001 14:25 |
