04-06-2009, 16:04 | #1 (permalink) |
Insane Poster Join Date: Apr 2008 Location: some where
Member: 753924 Status: Offline Thanks Meter: 8 | Req pinout it-mobile x-607 phone condition is blank i try with cable E104 E034 ( 4in1 ) using universal cable on pcb on system still can't find tx rx need help ? |
04-07-2009, 11:26 | #5 (permalink) |
Member: 753924 Status: Offline Thanks Meter: 8 | Is detecting Vcc and Gnd... ... Vcc: Null Gnd: 3 Is detecting the short circuit pin... ... Has not found the short circuit pin. Is detecting,confirmed the phone is connected, and press the POWER ON/OFF key ...... * [Detect] - Has not detected RX and TX, the detection overtime, please try again. |
04-07-2009, 11:37 | #6 (permalink) |
Member: 753924 Status: Offline Thanks Meter: 8 | i recheck today on phone connector only 5 pin, and i change cable to E034(3 IN 1)[5P]Motorola C330Gnd_1, not work change cable again E107[10P]10 pins(two-line)Gnd_2 Vcc_9 Is detecting Vcc and Gnd... ... Vcc: 9 Gnd: 2 Is detecting the short circuit pin... ... Has not found the short circuit pin. Is detecting,confirmed the phone is connected, and press the POWER ON/OFF key ...... * [Detect] - Has not detected RX and TX, the detection overtime, please try again. thanks for your respond |
04-12-2009, 14:55 | #8 (permalink) |
Member: 753924 Status: Offline Thanks Meter: 8 | thank you for your support finally : E107[10P]10 pins(two-line)Gnd_2 Vcc_9 Rx_5 Tx_7 Is detecting Vcc and Gnd... ... Vcc: 9 Gnd: 2 Is detecting the short circuit pin... ... Has not found the short circuit pin. Is detecting,confirmed the phone is connected, and press the POWER ON/OFF key ...... MT6225 RX = 5 TX = 7 Is setting [PinOuts]... * Setting [PinOuts] success. |
req....pinout LG kg276 plz...... | kyt_jwn | LG | 3 | 05-06-2013 14:54 |
Req, Pinout K-touch a615 please | gepenx_fausta | CPF-Dongle | 0 | 05-21-2009 03:59 |
[REQ]******* Hunter Mobile | Slothly | Nokia Multimedia | 0 | 05-14-2006 12:36 |
