Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > NoooX Box
Old 10-08-2008, 14:08   #1 (permalink)
kaiserstumm's Avatar
Member: 100770
6234 can not unlock
hello, I have allready unlocked more than hundred bb5 phones with DKbb5 unlock box and I have unlocked 11 phones with nooox box which means that I am not a begginer..I am also conecting the tp on clk and on 27 pin from left..means AD0..I even tryed AD8. No succes
The soft versinos in phone was 5.10-no succes
5.43-no succes
The log from JAF:
Reading...
MCU SW version: V 05.43
30-03-07
RM-123
(c) Nokia
HW version: 1020
PCI version:
RFIC version:  17211721
DSP version:  pb05wk46v49
LCD version: SEIKO
PPM version: V 05.43
30-03-07
RM123_145_-
(c) Nokia
DVF
Retu version: 32
Tahvo version: 53
Content Pack version: Content: d
V 05.10
21-12-06
RM123_145_-
(c) Nokia
Production serial number: 2GL364638
Product code: 0555782
Module code: 0202772
Basic production code: 0525641
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 358643015989044
IMEI spare to net: 3A 85 46 03 51 89 09 04
IMEI SV to net: 33 85 46 03 51 89 09 04 F6
LOCK STATUS:
CONFIG KEY: 8000000000000000
PROVIDER KEY: 2934000000000000
Provider: Si.mobil;Slovenia
Key Code count: 0, FBUS Code count: 0
Block 1:
Lock 1: CLOSED -> Lock Data: 29340F
Whwn i conect the phone it gets readen well showing right simlock status...pm308 can be also writen well...everything seems quite normal beside the fact when I press unlock..the box is registering TP contact even if I HAVE NOT CONECTED IT!! If I turn of the microscope lamp that i am using this does not happens but then no TP can be detected even if I 100% connect it right...I sold my old DK box so I woul apriciate every advice
Mario
Old 10-08-2008, 15:16   #2 (permalink)
NoooX-Box's Avatar
Member: 833635
Sonork: 100.1578967
You can unlock this version 100%
Tested many times!
Use small TP needles, connect yellow = CLK TP and after that the green TP on AD0 (pin 27).
Yes i know this phenomenon with fluorescent lamp. Use halogen or led lamp.
NoooX-Team
Old 10-08-2008, 16:47   #3 (permalink)
Member: 100770
Tested many times!
NoooX-Team
phone was on 2 ver 5.10 and 5.43, tp-100% (DONE THIS MANY TIMES), without any lamp it wont recognize the tp...it seems that the phones hw isnt 100% ok
Old 10-08-2008, 19:34   #4 (permalink)
Member: 100770
This phone cant be unlocked on MT lite or DK..so it hw fault I guess tnx for reply
Old 10-10-2008, 04:05   #5 (permalink)
NoooX-Box's Avatar
Member: 833635
Sonork: 100.1578967
Maybe the CLK pin is damaged!
NoooX-Team
Old 10-11-2008, 13:11   #6 (permalink)
Member: 100770
nope...under microscope seems to be ok...perhaps some rap issue..but it doesnt matters any more..phone turned back to customer tnx for trying to help
Old 10-12-2008, 10:35   #7 (permalink)
NoooX-Box's Avatar
Member: 833635
Sonork: 100.1578967
If you press to much on the RAP TP with your TP needle you can break the small pin.
So be very careful with RAP TP pin!
And please us only "small" TP needles for RAP TP.
NoooX-Team
Old 10-12-2008, 13:10   #8 (permalink)
Member: 100770
As I said...I unlocked over 100 phones on BB5 box by DK and already a few on nooox box..so I am quite familiar with the procedure...i didnt break of any pin and have not damaged anything...please do not threat me like an beginner...tnx
Old 10-12-2008, 14:48   #9 (permalink)
koksi's Avatar
Member: 19575
problem solved or?
was only a trying to help btw other useres read them olso so some hints for them
was no aggresion on you
6234 Can Not Unlock ..:::Gsm india:::.. BB5 Box by D.K. 0 02-06-2008 05:17
6085 and 6234 can not make downgrade!!!! DanV Nokia Base Band 5 ( BB-5 ) 7 10-13-2007 22:38
there is no hope from mr Julvir, I can not Unlock X1-X5, anybody can help me!? KUBAT1 SwS_SaG_BoX 6 05-16-2006 11:17
Setool2 cracked can not flash or can not unlock jignesh_1000 LG 5 01-27-2006 11:51
tornado 1.2n can not unlock 7600 but griffin can kumkon UFS2 + UFS3-Tornadoflasher 2 04-11-2004 06:07
Page generated in 0.46929 seconds with 11 queries
