e65 unlock failed why? i am trying since moring but always unlock failed why?these are last tries i am sending u. Code: ************************************** |
Update to 2.26 and try it again. http://forum.gsmhosting.com/vbb/showthread.php?t=577385 (donīt forget Triggerupdate ;)) I tested some E65 today and all was OK. NoooX-Team |
sir same problem plz help i do update trigger and v2.26 nooox same thing plz check bcoz i have lots of e65 in line plz check Code: * LOG from 01/10/2008 0:23:00 **** |
whats the problem e65 not unlocking yet and the answer nooox box team is not working is it possible to unlock e65 from nooox box or it is fake solution off my *** TOO MUCH PROBLEMS IN THIS BOX.PLZ TOLD ANYONE WHO UNLOCK E65 FROM NOOOX BOX IS THERE ANY TRICK TO UNLOCK E65 FROM NOOOX BOX OR NOT . TP IS FINE |
Can you send me your PCB for test? You are inside EU so shipping is not expensive. NoooX-Team |
its not possible sir bcoz its not mine its customer mobile so i can not send it to any other place ,i do not want to told u that your box is bad but sir belive me i am try to unlock 2 e65 from last 5 days and no sucess ,i have one friend who has shop who unlock almost 90-100 mobiles daily in which almost 8-10 e65 and after opening the mobile he takes max two minutes to unlock the mobile he his also with me last night sir belive me he tries almost one hour with this box to unlock e65 and no sucess now today i go on to the shop of him and unlock my e65 just in 3 attemp (less than 2min),your box is not bad but sure your box has problem in unlocking e65 100% .if u need logs i will send u. |
I buy a locked E65 and try it with many tests again ;) NoooX-Team |
try with fast TP detection or your cables are not 100% good |
I think is a cable failure or u don't make the TP corectly. It happent to me also many times. But I use this box from 2 month and I did unlock any posiible BB5 that suport TP unlocking and also E65 and not just one. Try to rehot the IC couse some times the ball become damaged couse of the presure we put with the needle. And clean the IC after rehot. And be shure that u don't touch with the Clock needle the ground around the IC. I can tell u for shure it is workin 100% to unlock E65. Try to make a full flash with Full Factory settings sometimes this is helping too I can not explain why but I encounter this issue and solved by reflashing the phone. Before reflashing the unlock procedure didn't work but after I did flash the phone it workt from the first try. Best regards to all, alianu. |
I have maked many e65 and all without problems in some secunds,I use also fast test point detection, NOOX-BOX is a very good and fast unlocking solution for BB5 Phones ! You must fix the GND in the near of the testpoint area BROTHER! :) |
hello friend plz help me nokia e65 s code arbic language s code not open english language s code open plz help |
JAF version 1.98.61 Detected PKEY: 90014ACE Card life counter: 87.31% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.0.2.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 3.0615.3 31-01-08 RM-208 (c) Nokia. HW version: 0801 PCI version: RFIC version: 17141714 DSP version: A06w14PB_07w42 Retu version: 15 Tahvo version: 22 Production serial number: SIH999506 Product code: 0515722 Module code: Basic production code: 0536849 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 353262017947176 IMEI spare to net: 3A 35 62 02 71 49 17 07 IMEI SV to net: 33 35 62 02 71 49 17 37 F0 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-208.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0515722 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-208\ Searching for default location of ini... Checking path: \Products\RM-208\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-208\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: E:\ub\Files\Nokia\BB5\E65.RM-208\4.0633.74\rm208_m128_h20_ka_prod_406337400_c00 _combined.bin PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: E:\ub\Files\Nokia\BB5\E65.RM-208\4.0633.74\rm208_m128_h20_ka_prod_406337400_c00 _combined.bin PPM Flash file: E:\ub\Files\Nokia\BB5\E65.RM-208\4.0633.74\rm208_m128_h20_ka_prod_406337400_v08 _variant.bin CNT Flash file: NONE APE Variant file: NONE Fast phone flashing selected. Manual mode selected, version can't be checked! Booting phone... FAST PHONE detected! APE Boot Data: Asic ID: 17100708 Asic Mode ID: 00 Asic Public ID: 96BB6F95591FAC1858EF13AA73FF20112DDA306F HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 CMT Boot Data: Asic ID: 000000010000022600010006010C192101003000 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 2510011052D80154AA8BB0E57B50101429F49AA9 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 273F6D55DFAAF68F CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready APE Boot: C:\Program Files\ODEON\JAF\Flash\helen3_2nd.fg Loader version: 01.23.00 -> Revision: 0000 Patching APE boot step1... Patching APE boot step2... Patching APE boot step3... APE Boot Ready APE Flash ID: 00A100EC <=> SAMSUNG (SEC) -> K5E1G12ACM APE Flash Data: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF APE Loader: C:\Program Files\ODEON\JAF\Flash\h3_sam_nand_xsr.fg Loader version: 01.2F.00 -> Revision: 0000 Patching APE loader step1... Patching APE loader step2... Patching APE loader step3... APE Loader Ready... Operation took 0 minutes 7 seconds... Sending CNF Data... Sending CRT data... Erasing... Operation took 0 minutes 38 seconds... Writing... Stage 1 Sending APE HASH for KEYS Sending CMT HASH for NOLO Sending APE HASH for X-LOADER Sending CMT HASH for KEYS Sending APE HASH for PRIMAPP Sending CMT HASH for PRIMAPP Sending CMT HASH for PASUBTOC Sending APE HASH for SOS+LOADER Sending CMT PUB KEYS... Sending CMT HASH for ADL Sending APE HASH for ADL Sending CMT HASH for DSP0 Sending APE HASH for SOS+XZIP Sending APE HASH for PASUBTOC Sending APE PUB KEYS... Sending APE HASH for SOS*CORE Sending CMT HASH for MCUSW Stage 2 Sending APE HASH for SOS+ROFS Booting phone... FAST PHONE detected! APE Boot Data: Asic ID: 17100708 Asic Mode ID: 00 Asic Public ID: 96BB6F95591FAC1858EF13AA73FF20112DDA306F HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 CMT Boot Data: Asic ID: 000000010000022600010006010C192101003000 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 2510011052D80154AA8BB0E57B50101429F49AA9 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 273F6D55DFAAF68F CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready APE Boot: C:\Program Files\ODEON\JAF\Flash\helen3_2nd.fg Loader version: 01.23.00 -> Revision: 0000 Patching APE boot step1... Patching APE boot step2... Patching APE boot step3... APE Boot Ready APE Flash ID: 00A100EC <=> SAMSUNG (SEC) -> K5E1G12ACM APE Flash Data: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF APE Loader: C:\Program Files\ODEON\JAF\Flash\h3_sam_nand_xsr.fg Loader version: 01.2F.00 -> Revision: 0000 Patching APE loader step1... Patching APE loader step2... Patching APE loader step3... APE Loader Ready... Operation took 0 minutes 7 seconds... Sending CNF Data... Sending CRT data... Stage 1 Stage 2 Sending APE HASH for SOS+ROFX FAST MODE finish! Operation took 3 minutes 54 seconds... Reseting phone... PPM: E:\ub\Files\Nokia\BB5\E65.RM-208\4.0633.74\rm208_m128_h20_ka_prod_406337400_v08 _variant.bin Booting phone... FAST PHONE detected! APE Boot Data: Asic ID: 17100708 Asic Mode ID: 00 Asic Public ID: 96BB6F95591FAC1858EF13AA73FF20112DDA306F HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 CMT Boot Data: Asic ID: 000000010000022600010006010C192101003000 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 2510011052D80154AA8BB0E57B50101429F49AA9 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 273F6D55DFAAF68F CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready APE Boot: C:\Program Files\ODEON\JAF\Flash\helen3_2nd.fg Loader version: 01.23.00 -> Revision: 0000 Patching APE boot step1... Patching APE boot step2... Patching APE boot step3... APE Boot Ready APE Flash ID: 00A100EC <=> SAMSUNG (SEC) -> K5E1G12ACM APE Flash Data: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF APE Loader: C:\Program Files\ODEON\JAF\Flash\h3_sam_nand_xsr.fg Loader version: 01.2F.00 -> Revision: 0000 Patching APE loader step1... Patching APE loader step2... Patching APE loader step3... APE Loader Ready... Operation took 0 minutes 7 seconds... Sending CNF Data... Erasing... Operation took 0 minutes 1 seconds... Writing... Sending APE HASH for SOS+ROFX Booting phone... FAST PHONE detected! APE Boot Data: Asic ID: 17100708 Asic Mode ID: 00 Asic Public ID: 96BB6F95591FAC1858EF13AA73FF20112DDA306F HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 CMT Boot Data: Asic ID: 000000010000022600010006010C192101003000 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 2510011052D80154AA8BB0E57B50101429F49AA9 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 273F6D55DFAAF68F CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready APE Boot: C:\Program Files\ODEON\JAF\Flash\helen3_2nd.fg Loader version: 01.23.00 -> Revision: 0000 Patching APE boot step1... Patching APE boot step2... Patching APE boot step3... APE Boot Ready APE Flash ID: 00A100EC <=> SAMSUNG (SEC) -> K5E1G12ACM APE Flash Data: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF APE Loader: C:\Program Files\ODEON\JAF\Flash\h3_sam_nand_xsr.fg Loader version: 01.2F.00 -> Revision: 0000 Patching APE loader step1... Patching APE loader step2... Patching APE loader step3... APE Loader Ready... Operation took 0 minutes 7 seconds... Sending CNF Data... FAST MODE finish! Operation took 2 minutes 37 seconds... Reseting phone... Done! Total time: 7 Minutes, 26 Seconds DCT4/BB5 counter: 117 After flash processing... Waiting for phone to boot... Reading... Phone type: RM-208, Software version: 4.0615.2 IMEI: 353262017947176 APE Ver: (null) Variant Ver: (null) Product Code: 0515722 Setting FULL FACTORY......Setting test mode... Setting FULL FACTORY... Operation took 0 minutes 19 seconds... Done! Done! Done! |
e65 s code problem :rolleyes:JAF version 1.98.61 Detected PKEY: 90014ACE Card life counter: 87.31% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.0.2.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 3.0615.3 31-01-08 RM-208 (c) Nokia. HW version: 0801 PCI version: RFIC version: 17141714 DSP version: A06w14PB_07w42 Retu version: 15 Tahvo version: 22 Production serial number: SIH999506 Product code: 0515722 Module code: Basic production code: 0536849 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 353262017947176 IMEI spare to net: 3A 35 62 02 71 49 17 07 IMEI SV to net: 33 35 62 02 71 49 17 37 F0 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-208.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0515722 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-208\ Searching for default location of ini... Checking path: \Products\RM-208\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-208\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: E:\ub\Files\Nokia\BB5\E65.RM-208\4.0633.74\rm208_m128_h20_ka_prod_406337400_c00 _combined.bin PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: E:\ub\Files\Nokia\BB5\E65.RM-208\4.0633.74\rm208_m128_h20_ka_prod_406337400_c00 _combined.bin PPM Flash file: E:\ub\Files\Nokia\BB5\E65.RM-208\4.0633.74\rm208_m128_h20_ka_prod_406337400_v08 _variant.bin CNT Flash file: NONE APE Variant file: NONE Fast phone flashing selected. Manual mode selected, version can't be checked! Booting phone... FAST PHONE detected! APE Boot Data: Asic ID: 17100708 Asic Mode ID: 00 Asic Public ID: 96BB6F95591FAC1858EF13AA73FF20112DDA306F HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 CMT Boot Data: Asic ID: 000000010000022600010006010C192101003000 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 2510011052D80154AA8BB0E57B50101429F49AA9 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 273F6D55DFAAF68F CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready APE Boot: C:\Program Files\ODEON\JAF\Flash\helen3_2nd.fg Loader version: 01.23.00 -> Revision: 0000 Patching APE boot step1... Patching APE boot step2... Patching APE boot step3... APE Boot Ready APE Flash ID: 00A100EC <=> SAMSUNG (SEC) -> K5E1G12ACM APE Flash Data: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF APE Loader: C:\Program Files\ODEON\JAF\Flash\h3_sam_nand_xsr.fg Loader version: 01.2F.00 -> Revision: 0000 Patching APE loader step1... Patching APE loader step2... Patching APE loader step3... APE Loader Ready... Operation took 0 minutes 7 seconds... Sending CNF Data... Sending CRT data... Erasing... Operation took 0 minutes 38 seconds... Writing... Stage 1 Sending APE HASH for KEYS Sending CMT HASH for NOLO Sending APE HASH for X-LOADER Sending CMT HASH for KEYS Sending APE HASH for PRIMAPP Sending CMT HASH for PRIMAPP Sending CMT HASH for PASUBTOC Sending APE HASH for SOS+LOADER Sending CMT PUB KEYS... Sending CMT HASH for ADL Sending APE HASH for ADL Sending CMT HASH for DSP0 Sending APE HASH for SOS+XZIP Sending APE HASH for PASUBTOC Sending APE PUB KEYS... Sending APE HASH for SOS*CORE Sending CMT HASH for MCUSW Stage 2 Sending APE HASH for SOS+ROFS Booting phone... FAST PHONE detected! APE Boot Data: Asic ID: 17100708 Asic Mode ID: 00 Asic Public ID: 96BB6F95591FAC1858EF13AA73FF20112DDA306F HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 CMT Boot Data: Asic ID: 000000010000022600010006010C192101003000 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 2510011052D80154AA8BB0E57B50101429F49AA9 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 273F6D55DFAAF68F CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready APE Boot: C:\Program Files\ODEON\JAF\Flash\helen3_2nd.fg Loader version: 01.23.00 -> Revision: 0000 Patching APE boot step1... Patching APE boot step2... Patching APE boot step3... APE Boot Ready APE Flash ID: 00A100EC <=> SAMSUNG (SEC) -> K5E1G12ACM APE Flash Data: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF APE Loader: C:\Program Files\ODEON\JAF\Flash\h3_sam_nand_xsr.fg Loader version: 01.2F.00 -> Revision: 0000 Patching APE loader step1... Patching APE loader step2... Patching APE loader step3... APE Loader Ready... Operation took 0 minutes 7 seconds... Sending CNF Data... Sending CRT data... Stage 1 Stage 2 Sending APE HASH for SOS+ROFX FAST MODE finish! Operation took 3 minutes 54 seconds... Reseting phone... PPM: E:\ub\Files\Nokia\BB5\E65.RM-208\4.0633.74\rm208_m128_h20_ka_prod_406337400_v08 _variant.bin Booting phone... FAST PHONE detected! APE Boot Data: Asic ID: 17100708 Asic Mode ID: 00 Asic Public ID: 96BB6F95591FAC1858EF13AA73FF20112DDA306F HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 CMT Boot Data: Asic ID: 000000010000022600010006010C192101003000 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 2510011052D80154AA8BB0E57B50101429F49AA9 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 273F6D55DFAAF68F CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready APE Boot: C:\Program Files\ODEON\JAF\Flash\helen3_2nd.fg Loader version: 01.23.00 -> Revision: 0000 Patching APE boot step1... Patching APE boot step2... Patching APE boot step3... APE Boot Ready APE Flash ID: 00A100EC <=> SAMSUNG (SEC) -> K5E1G12ACM APE Flash Data: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF APE Loader: C:\Program Files\ODEON\JAF\Flash\h3_sam_nand_xsr.fg Loader version: 01.2F.00 -> Revision: 0000 Patching APE loader step1... Patching APE loader step2... Patching APE loader step3... APE Loader Ready... Operation took 0 minutes 7 seconds... Sending CNF Data... Erasing... Operation took 0 minutes 1 seconds... Writing... Sending APE HASH for SOS+ROFX Booting phone... FAST PHONE detected! APE Boot Data: Asic ID: 17100708 Asic Mode ID: 00 Asic Public ID: 96BB6F95591FAC1858EF13AA73FF20112DDA306F HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 CMT Boot Data: Asic ID: 000000010000022600010006010C192101003000 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 2510011052D80154AA8BB0E57B50101429F49AA9 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 273F6D55DFAAF68F CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready APE Boot: C:\Program Files\ODEON\JAF\Flash\helen3_2nd.fg Loader version: 01.23.00 -> Revision: 0000 Patching APE boot step1... Patching APE boot step2... Patching APE boot step3... APE Boot Ready APE Flash ID: 00A100EC <=> SAMSUNG (SEC) -> K5E1G12ACM APE Flash Data: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF APE Loader: C:\Program Files\ODEON\JAF\Flash\h3_sam_nand_xsr.fg Loader version: 01.2F.00 -> Revision: 0000 Patching APE loader step1... Patching APE loader step2... Patching APE loader step3... APE Loader Ready... Operation took 0 minutes 7 seconds... Sending CNF Data... FAST MODE finish! Operation took 2 minutes 37 seconds... Reseting phone... Done! Total time: 7 Minutes, 26 Seconds DCT4/BB5 counter: 117 After flash processing... Waiting for phone to boot... Reading... Phone type: RM-208, Software version: 4.0615.2 IMEI: 353262017947176 APE Ver: (null) Variant Ver: (null) Product Code: 0515722 Setting FULL FACTORY......Setting test mode... Setting FULL FACTORY... Operation took 0 minutes 19 seconds... Done! Done! Done! |
It's no JAF section. Use NoooX for read security code. |
