Help -my box lose testmode ??? - Phone does not power on Hello my noox box lose possiblity power phone in test mode ....??? for make unlock I must connect external power (+BSI conected) but conector Vcc & GND show 4,5V... and when I try connect N73 with externalpower phone only start 1s. vibra cant show test mode and impossible unlock this. how repair this ??? Please help ? Regards :confused: M_ALEX |
Do you use a USB Hub? Use only direct PC USB port! Disassembly complete phone and use only PCB without camera and LC display. Connect +, BSI, ground and popport cable to phone and simulate power on with a tweezer. NoooX-Team |
I have box connected always directly with USB 2.0 controler PCI VIA (VT-6212) working good 1 month after this time cant run any phones in test mode but when I use external power phone enter in test mode and possible still unlock. only any N73 cant enter in test or lokal mode... for unlocking this model I use Dejan box as power box ;-).... but I want repair my box, be again work when be new. please send me scheme or diagram block box with part responsiblity about power phone . A waiting your sunnest information Regards :rolleyes: M_ALEX |
You have problems with N73? Or with all phones? NoooX-Team |
I have problems with all phones. but N73 completly cant possible put in local mode. for others phones I must use external power together with cables from box. :confused: M_ALEX |
Try to resolder phone connector on PCB. If it does not help you can contact me via sonork for more instructions. ;) NoooX-Team |
Hello I open this box and check..... and find two burned resistors R7, R8. Please tell me what are their values ? :confused: |
hello, "I open this box and check..... and find two burned resistors R7, R8. Please tell me what are their values " i have same problem i posted today http://rapidshare.de/files/40742435/noox.BMP.html http://rapidshare.de/files/40742432/nooox.JPG.html please give support east51 |
both have 1 OHM change them and box should work (and look that you dont short cables again) |
1 Attachment(s) exactly.... I have this!!! Thank You ;-) ...he is work as fuse. |
problem solved by changing R7 and R8 http://rapidshare.de/files/40743741/new_R7_R8.BMP.html thx for quick support |
