10-16-2008, 14:37 | #1 (permalink) |
Freak Poster Join Date: Nov 2002 Location: Poland Age: 56
Member: 17920 Status: Offline Thanks Meter: 10 | Help -my box lose testmode ??? - Phone does not power on my noox box lose possiblity power phone in test mode ....??? for make unlock I must connect external power (+BSI conected) but conector Vcc & GND show 4,5V... and when I try connect N73 with externalpower phone only start 1s. vibra cant show test mode and impossible unlock this. how repair this ??? Please help ? Regards M_ALEX |
10-16-2008, 15:15 | #2 (permalink) |
Product Manager Join Date: Aug 2008 Location: inside ProASIC3
Member: 833635 Status: Offline Sonork: 100.1578967 Thanks Meter: 604 | Do you use a USB Hub? Use only direct PC USB port! Disassembly complete phone and use only PCB without camera and LC display. Connect +, BSI, ground and popport cable to phone and simulate power on with a tweezer. NoooX-Team Last edited by NoooX-Box; 10-16-2008 at 15:40. |
10-16-2008, 18:49 | #3 (permalink) |
Member: 17920 Status: Offline Thanks Meter: 10 | I have box connected always directly with USB 2.0 controler PCI VIA (VT-6212) working good 1 month after this time cant run any phones in test mode but when I use external power phone enter in test mode and possible still unlock. only any N73 cant enter in test or lokal mode... for unlocking this model I use Dejan box as power box ;-).... but I want repair my box, be again work when be new. please send me scheme or diagram block box with part responsiblity about power phone . A waiting your sunnest information Regards M_ALEX |
10-21-2008, 09:18 | #5 (permalink) |
Member: 17920 Status: Offline Thanks Meter: 10 | I have problems with all phones. but N73 completly cant possible put in local mode. for others phones I must use external power together with cables from box. M_ALEX |
10-23-2008, 16:02 | #8 (permalink) |
Freak Poster Join Date: Oct 2004 Age: 44
Member: 88552 Status: Offline Thanks Meter: 13 | hello, "I open this box and check..... and find two burned resistors R7, R8. Please tell me what are their values " i have same problem i posted today http://rapidshare.de/files/40742435/noox.BMP.html http://rapidshare.de/files/40742432/nooox.JPG.html please give support east51 |
10-23-2008, 17:01 | #9 (permalink) |
Product Manager Join Date: Jan 2003
Member: 19575 Status: Offline Thanks Meter: 134 | both have 1 OHM change them and box should work (and look that you dont short cables again) Last edited by NoooX-Box; 10-23-2008 at 19:51. |
The Following User Says Thank You to koksi For This Useful Post: |
10-23-2008, 18:40 | #11 (permalink) |
Member: 88552 Status: Offline Thanks Meter: 13 | problem solved by changing R7 and R8 http://rapidshare.de/files/40743741/new_R7_R8.BMP.html thx for quick support |
my lg-km710 does not power on after locked | rasheed88 | LG Hardware Repair | 0 | 01-17-2010 03:41 |
6131 Does not power on on battry but it works perfect while I connect UFS Cabel | .:.GSM-ANGEL.:. | Nokia Base Band 5 ( BB-5 ) | 1 | 10-25-2007 12:24 |
i connect the DC supply but phone does not power on | kaholukkk | UID - Box | 2 | 10-06-2007 15:38 |
Siemens SL45 does not power on. | sat | Siemens Hardware Repair Area | 0 | 01-09-2002 08:15 |
