Unlock Server
Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > NoooX Box
Old 09-20-2008, 14:37   #1 (permalink)
domidelcourt's Avatar
Member: 162067
nooo pb - >> problem solved <<
it's very strange , since the version 2,23 and 24 i have at startup a windows whit this message
"error while reading support.config"
and in the soft setting/support there is nothing in Unlock and profibit and counter
Old 09-20-2008, 16:02   #2 (permalink)
koksi's Avatar
Member: 19575
since this version update automatical this fils
this mean you need internet connection
i bet firewall block downloading this is reason that you have a half file
press update trigger close firewall and problem should be solved
Old 09-20-2008, 17:02   #3 (permalink)
Member: 137474
Sonork: 100.109924
I got the same like belowe got other custoerm how fix this I test on few PC computer and the same when press update trigger got too error only first file rest download ok then problem is in software not in snetwork I think ! !! !! I wait for solution. bye
The Following User Says Thank You to wgmmmx For This Useful Post:
Old 09-20-2008, 19:26   #4 (permalink)
koksi's Avatar
Member: 19575
when you start software you see this?
NoooX - BB5 Unlocker v2.24
Boxmodul_1 revision = A90AEB0835DB
Connect to server...OK
Update part 1 ...OK
Update part 2 ...OK
Update part 3 ...OK
Update part 4 ...OK
Update part 5 ...OK
Done
download this fils and replace them with your old
http://www.twisterflasher.net/configs.rar
The Following User Says Thank You to koksi For This Useful Post:
Old 09-22-2008, 11:48   #5 (permalink)
Member: 137474
Sonork: 100.109924
I got this
Boxmodul_1 revision = xxxxxx
Update part 1 ...ERROR
Update part 2 ...OK
Update part 3 ...OK
Update part 4 ...OK
Update part 5 ...OK
Done
Update part 2 ...OK
Update part 3 ...OK
Update part 4 ...OK
Update part 5 ...OK
Done
and your files not help any other solution ??
Old 09-22-2008, 11:53   #6 (permalink)
NoooX-Box's Avatar
Member: 833635
Sonork: 100.1578967
I uploaded new unlock.config to server now!
Please try it again and post result!
Thank you
NoooX-Team
Old 09-22-2008, 14:39   #7 (permalink)
Member: 137474
Sonork: 100.109924
Thank you
NoooX-Team
still the same
Boxmodul_1 revision = xxxxxxxxxxxx
Update part 2 ...OK
Update part 3 ...OK
Update part 4 ...OK
Update part 5 ...OK
Done
Update part 2 ...OK
Update part 3 ...OK
Update part 4 ...OK
Update part 5 ...OK
Done
Old 09-22-2008, 15:26   #8 (permalink)
NoooX-Box's Avatar
Member: 833635
Sonork: 100.1578967
strange.
I know this failure but only if unlock.config is open.
I changed something with triggerupdate in 2.25.
But for now please untick "search for Triggerupdate at startup" and copy
unlock.config from http://www.twisterflasher.net/configs.rar into NoooX folder.
NoooX-Team
Old 09-22-2008, 17:09   #9 (permalink)
Member: 137474
Sonork: 100.109924
I do this but still got the same error when start noox box I uncheck all but still when run software got this error like in 1 post and still got error when download update try any other help ?
Old 09-22-2008, 19:24   #10 (permalink)
NoooX-Box's Avatar
Member: 833635
Sonork: 100.1578967
download
http://www.unlockhardware.net/NoooX_2.23.rar
and wait for 2.25 please.
NoooX-Team
Old 09-23-2008, 13:34   #11 (permalink)
Member: 137474
Sonork: 100.109924
download
NoooX-Team
Still the same erorr like with 2.24 after unpack 2.23 that you give me link
NoooX - BB5 Unlocker v2.23
Update part 2 ...OK
Update part 3 ...OK
Update part 4 ...OK
Update part 5 ...OK
Done
Old 09-23-2008, 19:38   #12 (permalink)
NoooX-Box's Avatar
Member: 833635
Sonork: 100.1578967
Please check your firewall.
I think it block the unlock.config, because we use the same command for downloading all other files.
NoooX-Team
wat tis problem - >> problem solved << Gabiunlock NoooX Box 8 10-15-2010 09:55
And Another Telcel !!!!please Solve This!!! - >> problem solved << jjrock NoooX Box 20 09-23-2008 20:14
6233 alway Unlock Failed ?? >> problem solved << ExTeem-Unlocker NoooX Box 9 09-10-2008 11:22
Nooox Box Instructions Please!!!! - >> problem solved << jjrock NoooX Box 14 08-20-2008 23:17
phone locked but read info open why ?? >> problem solved << feritk NoooX Box 11 08-18-2008 11:43
Page generated in 0.61494 seconds with 11 queries
