11-08-2008, 21:40 | #1 (permalink) |
Freak Poster Join Date: Sep 2007
Member: 596972 Status: Offline Sonork: 100.1591686 Thanks Meter: 55 | Where can i buy the 1R0 resisitors? In Germany i could not find any adress, where i can buy this smd-resistors 0508. Can anyone help me and know an adress? Thanks Jomafi |
11-08-2008, 22:00 | #2 (permalink) |
Freak Poster Join Date: Jun 2004 Location: reparatiigsm ro Age: 51
Member: 69239 Status: Offline Sonork: reparatii-gsm ro Thanks Meter: 87 | searching in pcb for resistor 1k ohm searching in pcb for nokia 3310, 3410 etc or another dispositive electronic with component smd discrete br 1r0 posibile 1ohm please post photo pcb ,and details demaged try to short for 1 ohm resistor measuring with digital multimeter valued corect ,succes! Last edited by ciopa; 11-08-2008 at 22:08. |
11-09-2008, 11:22 | #4 (permalink) | |
Member: 596972 Status: Offline Sonork: 100.1591686 Thanks Meter: 55 | Quote: Yesterday i was in the Conrad Shop in Stuttgart and ask for this resistors. No way to get it from Conrad.de Jomafi edit: Hi i found it at www.reichelt.de. U need SMD 0805 for nooox!! Last edited by jomafi; 11-09-2008 at 11:32. | |
11-10-2008, 12:37 | #5 (permalink) |
Freak Poster Join Date: Oct 2004 Age: 44
Member: 88552 Status: Offline Thanks Meter: 13 | @jomafi i have bought the resistors from conrad. i have soldier the 0 OHM and it works fine. when you want i can send you 2 resistors per Post. |
The Following User Says Thank You to east51 For This Useful Post: |
11-11-2008, 21:42 | #6 (permalink) | |
I've bought now the resistors from Reichelt Elektronik (www.reichelt.de). In the next days when the resistors arrive i will test. Have you soldier it with hot air, or normally? Greets Jomafi | |
11-12-2008, 10:34 | #7 (permalink) |
No Life Poster Join Date: Nov 2007 Location: dm3unlock
Member: 631393 Status: Offline Thanks Meter: 749 | A 0-Ohm resistor is equivalent to a blob of solder across the pads. No need to buy anything for that. A 1R0 on the other hand, if it is there for a reason, it can certainly NOT be safely replaced with a 0-Ohm one! |
11-12-2008, 11:29 | #8 (permalink) |
Product Manager Join Date: Aug 2008 Location: inside ProASIC3
Member: 833635 Status: Offline Sonork: 100.1578967 Thanks Meter: 604 | you can also use a polyswitch fuse 0,5A http://de.rs-online.com/web/search/s...7-7111&x=0&y=0 So you do not need to replace a resistor anymore. NoooX-Team |
The Following User Says Thank You to NoooX-Box For This Useful Post: |
11-14-2008, 14:47 | #9 (permalink) | |
Thanks nooox-Team, a very good solution!! You should think about to use this switch at the production of the box. The cost of such a switch is about 9ct Greets Jomafi | |
Where can i buy the USB-Smart | pgtl | SonyEricsson (USB-Smart) | 5 | 03-18-2006 12:34 |
Where can I buy the cable for the Samsung Z130 / Z500V | toysoft | FuriouS II | 2 | 08-25-2005 22:02 |
where can i buy the bosch 909s 1800mah battery? | howardpam | Various | 1 | 07-25-2004 00:36 |
Where can I buy the NEC cable for DB500,DB1000,DB2000,DB4000 | cysttklc | NEC | 2 | 12-08-2003 19:59 |
Where can I buy the LCD of Maxon 6869?? | Ken-mkII | Various | 0 | 05-10-2002 17:03 |
