Unlock Server
Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > NoooX Box
Old 10-14-2008, 20:17   #1 (permalink)
Member: 333519
Sonork: 100.1620327
phones tested wih nooox box
5200, 5300, 6300, 6131, 3500, n95, works perferct
e50, e65, n73 not posible, i have many experience unlocking those phones with onother tools. I want to unlock them with nooox box but i can´t i´m sure that the tp is ok the cables are perfect. so please nooox box programers solve that problem i´m not the only user that have the same problem. sorry for post twice
Old 10-14-2008, 21:36   #2 (permalink)
koksi's Avatar
Member: 19575
have you used easy TP ?
1 log what be olso usefull
try e65 with fast TP detection
Old 10-14-2008, 23:39   #3 (permalink)
Member: 333519
Sonork: 100.1620327
log
Set trigger: 1 + 2 / loop 1 - 5242B441B520F0C2AD2CB2CA
Initialisation Done
Please connect testpoint now
waiting for testpoint - AD8 ........................................................................................................................................OK
Send password #pw+123456789012345+7#
UNLOCK FAILED :-(
MCU SW version: V 05wk47v34.1 05-10-06 RM-132 (c) Nokia
IMEI: 354804014882929
Provider: 7321030000000000
Providername: Móvil S.A. - Colombia
Profilbit: 0000000000000000
PSW counter: 1/3 - 0/10
Simlock status: >> CLOSED << (4 locks)
Server version: SIMLOCK SERVER VERSION 63
~ waiting for the phone ~
Unlock failed :-/
waiting for testpoint - AD8 ............................................OK
UNLOCK FAILED :-(
PSW counter: 2/3 - 0/10
Set trigger: 1 + 2 / loop 2 - 5242B441B520F0C2AD2CB2CA
Initialisation Done
waiting for testpoint - AD8 ...........................OK
UNLOCK FAILED :-(
PSW counter: 3/3 - 0/10
Set trigger: 1 + 2 / loop 3 - 5242B441B520F0C2AD2CB2CA
Initialisation Done
waiting for testpoint - AD8 .......OK
UNLOCK FAILED :-(
PSW counter: 3/3 - 1/10
Set trigger: 1 + 2 / loop 4 - 5242B441B520F0C2AD2CB2CA
Initialisation Done
waiting for testpoint - AD8 ....OK
UNLOCK FAILED :-(
Old 10-15-2008, 10:09   #4 (permalink)
NoooX-Box's Avatar
Member: 833635
Sonork: 100.1578967
I try some different N73 versions the next days!
NoooX-Team
Old 10-15-2008, 11:08   #5 (permalink)
Member: 8359
I try wth a 6 diferent versions (and phones) N73 and don't unlock any
Old 10-15-2008, 20:53   #6 (permalink)
NoooX-Box's Avatar
Member: 833635
Sonork: 100.1578967
hi
I tested N73 with differnet firmwares today and i uploaded modified triggers!
Please update trigger and it should work now!
I used 2.26 for tests!
NoooX-Team
Old 10-17-2008, 19:34   #7 (permalink)
Member: 202374
n95 unlock
hi as a new user of nooox box so far very good got the box yesterday easy to install unlocked a n95 v 21 and a 3110c version 6.60 i use another box and i would have to mess about down grading so thanks .
Old 10-17-2008, 20:28   #8 (permalink)
electrosoft's Avatar
Member: 93850
hi
for e50, e65, n73 and my experiance yous have to solder testpoint GND near RAP (not use alligator Clip)
br!
Old 10-18-2008, 18:08   #9 (permalink)
MichieMax's Avatar
Member: 40758
my addition to this is the Nooox box team should try to make there box work well with both the TP ( the easy tp and the normal tp) coz some people are ok with the easy tp and others are ok with the normal tp thats the only way they will avoid to many complains from users who use there product me being one of them although i have never unlocked any phone with there box but all phones that i fail to unlock with there box i unlock the with my other box but all in all Rome was not built in one day am always trying it i hope one day i will get it to work as i have done with my other boxes
Old 10-18-2008, 19:33   #10 (permalink)
NoooX-Box's Avatar
Member: 833635
Sonork: 100.1578967
Look at the TP picture and you'll see why Easy-TP and normal TP are the same
Most problems are ground problems and that some people use wrong TP.
NoooX-Team
Old 10-20-2008, 10:25   #11 (permalink)
MichieMax's Avatar
Member: 40758
unlocked 1 6280 v6.43 will keep trying
Old 10-20-2008, 23:50   #12 (permalink)
Member: 333519
Sonork: 100.1620327
6300 telcel
plase i have one 6300 v 4.20 from telce, but i can´t unlock it. here the log_
Test profilbit
waiting for testpoint - AD0 (NOT AD1 !) ................................OK
UNLOCK FAILED :-(
MCU SW version: V 04.20 05-12-06 RM-217 (c) Nokia
IMEI: 354827012863195
Provider: 3340201549764300
Providername: Telcel - Mexico
Profilbit: B000000000000000 - locked Profilbit
PSW counter: 0/3 - 0/10
Simlock status: >> CLOSED << (1 lock) - profilbit found
No valid ProfilBitTrigger K found
-> start 'Find ProfilBitTrigger K' now
PM Backup found
Set FindProfilbitTrigger to 9274344BED02...Done
Entering modus 1...OK
waiting for testpoint - AD0 (NOT AD1 !) ....OK
UNLOCK FAILED :-(
UNLOCK FAILED :-(
Got Triggervalue: 49AAF2A73731
waiting for testpoint - AD0 (NOT AD1 !) ...OK
UNLOCK FAILED :-(
UNLOCK FAILED :-(
Got Triggervalue: 6226A1E63DC8
Entering modus 2...OK
UNLOCK FAILED :-(
waiting for testpoint - AD0 (NOT AD1 !) ............OK
UNLOCK FAILED :-(
Old 10-21-2008, 13:56   #13 (permalink)
NoooX-Box's Avatar
Member: 833635
Sonork: 100.1578967
Untick "Enable Profilbit K searching" and "Test Profilbit"
Now it should work.
NoooX-Team
Old 10-21-2008, 18:02   #14 (permalink)
MichieMax's Avatar
Member: 40758
unlocked another 6233 v5.60 still trying
Old 10-21-2008, 18:16   #15 (permalink)
Member: 333519
Sonork: 100.1620327
exelent 6300 telcel unlocked
good support i untick profilbit k searching and test profilbit, and
PSW counter: 0/3 - 2/10
Set ProfilBitTrigger F0: 59DAFE25E231
Set Unlocktrigger: 3 / loop 1 - 0B2C52F71D35
Initialisation Done
waiting for testpoint - AD0 (NOT AD1 !) ......................................OK
UNLOCK OK ;-)
Simlock status: >> OPEN << (1 lock)
Phone is unlocked now
Nokia 6280 Unlock with Nooox-Box , Test Mode - >> problem solved << powerplay83 NoooX Box 4 10-12-2008 10:58
~Post here All Phone Tested Unlocked Using NOOOX Box~ master005 NoooX Box 3 09-24-2008 21:56
Telcel Phone question to the Nooox Box Team djkiddrick NoooX Box 1 08-30-2008 23:22
Page generated in 3.15766 seconds with 11 queries
