Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2008
Member: 862130 Status: Offline Thanks: 45
| Can someone tell me how to unlock this phone from Vodafone UK. I have a version 2.24, I noticed that the on key is on the top right corner of the screen, how can I press the on key if this is in front and the motherboard is on the back and the motherboard has to be taken off the housing and has to be disconnected withe screen. I haven't taken out yet because I want to make sure first how to unlock this with noox box. thank you I found out that is not supported on the list: 1.0633.18.01 11-01-07 RM:-208 Nokia E65 |
| | #2 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2006 Location: Palestine- Gaza Age: 55
Member: 330579 Status: Offline Sonork: 100.1620425 Thanks: 234
| Hello Quote:
If you don't press power you never unlock phone. Think! any posision for press Power. If you don't can ask a friend help you. But isin't necessary two persons to unlock one phone. Try, just try andyou see you can. BR Haicha | |
| | #3 (permalink) | |
| Quote:
I have to wait for update this firmware is not supported yet | |
| | #4 (permalink) |
| I found the picture " on how to make the phone to test mode" but no idea how does it work? it say 7 pins short to GND, I only can see the test point picture on the ver.2.24 folder but not in the Noox Box interface. Please help on all my question I'm really new with this Vodafone E65 how to unlock and how to make it turn-on since the on button is on the LCD screen side. to unlock we need to discnnect the PCB board to the lcd but how this thing work for E65? |
| | #5 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2008 Location: Romania Age: 33
Member: 724928 Status: Offline Thanks: 113
| so first thing , you conect pcb to nooxbox , then connect pin7 to GND like in pic ![]() after click Read Phone to check if ewrithing is fine , if yes then do unlock ![]() PS: dont forget to connect V+ BSI and GND , also you need to cut the shield.(for data you can use ball Nr3 which is in the same position like pin 5 its more easy. Its working fine and fast the unlock for E65 i made a lot off them with nooox. |
| | #6 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2005 Location: Salvador - Bahia - Brazil Age: 38
Member: 172567 Status: Offline Thanks: 39
| other option, open the slider and connect bouth fron flex cables, with slider open it will let you space to make testpoint, and you can press your famous power botton |
| | #7 (permalink) |
| Guys, thank you for your reply. But I just really can't get it how to GND that & 7 pins( sorry I'm new with this BB5 unlocking) is there anyway you can post an actual picture on how to GND to make the E65 turn on, by the way Noox Box doesn't support my E65 version yet so I have to wait for their update. Please Noox Box I'm still waiting for it still thank you |
| | #8 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2008 Location: inside ProASIC3
Member: 833635 Status: Offline Sonork: 100.1578967 Thanks: 48
| Connect the phone, press UNLOCK button, take a metal tweezer, hold one side to PIN7 and the other side to GND for about 1-2 seconds. And now NoooX can read the phone infos ![]() NoooX-Team |
| | #9 (permalink) |
| Last question for Noox Box team, is the small tp can reach this test point or do I have to modify it ( like soldering a small needle at the end) to reach the actual test point for E65? coz I'm not good on soldering yet. please verify if the small tp can reach it or not, Thank you |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| 6133 need help on flashing this model. pls. this is my first time using MxKEYHere is | mymiela0419 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-11-2010 09:25 |
| CU400 how to unlock via FG? this is my first time | Unlockemall | FuriouS TeaM Products | 6 | 10-23-2009 07:04 |
| ku990 NO NETWORK, team vygis please help for flashing it is my first time | mymiela0419 | VygisToolbox | 6 | 11-17-2008 05:50 |
| this is my first time here so i need some help please from supporter | SOFT3000 | HWK | 6 | 10-13-2008 07:36 |
| Help Please This Is My First Time | hany zaky | Chinese Miracle & PinFinder | 3 | 06-29-2008 12:28 |
