Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported IMEI calculator Sites or Software Products > allGSMunlock MultiOnline Remote Server > Samsung Remote Online server
Old 11-27-2009, 00:08   #1 (permalink)
Member: 1170427
FREEZE Samsung 5230
Hi, Whats the proccess to getting unfreeze and network code for a samsung 5230? please help me. The imei number is 357530034359971.
Old 11-27-2009, 04:19   #2 (permalink)
Member: 700741
Watch this video
http://www.youtube.com/watch?v=MCTOpQwEVp0
The Following User Says Thank You to MALIKTARIQ For This Useful Post:
Old 11-27-2009, 05:32   #3 (permalink)
Registered User
Member: 413478
unlock with ustpro2 % solved your problam
The Following User Says Thank You to javed ahmad For This Useful Post:
Old 11-27-2009, 05:47   #4 (permalink)
Member: 355565
Sonork: 1587260
direct unlock it with ns pro in few seconds bro
The Following User Says Thank You to super decent For This Useful Post:
Old 11-27-2009, 16:08   #5 (permalink)
Member: 1170427
Thanks to all for the answers, but i need the unfreeze code, can someone tell me the code, please?
Old 05-28-2010, 20:52   #6 (permalink)
Member: 60442
Unfreeze code
The unfreeze code is allways different, like the unlockcodes you get.
Based on the imei of your phone.
Old 05-28-2010, 21:14   #7 (permalink)
Member: 864271
GT-S5230 - Phone Freeze Solution م o (Via Z3X-Box)
Note:
- Use E210 cable RJ45 + USB (COMBO)
- Procedure done with battery and phone connected
- Use program Samsung Tool V3.3.0020 2G or higher
- Needs ل rio install the USB drivers regarding the phone if requested.
1 - Select Model S5230
2 - Check the opc م the "Use 2 in 1 cable"
3 - Click on the bot م "Read Info [Codes]" and wait for the program to read information from your phone.
4 - As soon go ل show aps code FREEZE
"On the message screen press the Phone Freeza opc م the call to release the numeric keypad, and enter the code Freeze, in my case was:
09302629
Will immediately release the screen.
5 - Remove the battery put the original chip and enter the normal procedure.
# 7465625 * 638 * NCK #
Ready, set successfully repaired!
__________________
Post from John Paul Francis
ABC team of Technical Brazil
Old 06-07-2010, 05:07   #8 (permalink)
Salami1_1's Avatar
Member: 3941
or you can just use the Simlock Remote Server as this is a sub support section for that product which does it job just as well or better then all others mentioned.
To use SRS you don't need any box but you do need a dual cable (a lot cheaper).
All you have to do is install a driver and press 'direct unlock' button.
B.r.
samsung 5230 erick lopez UST Pro II 1 11-08-2009 09:18
samsung 5230 adil hussain Z3X-Team Products 1 09-26-2009 18:44
Samsung 5230 unlock problem :::SOLVED::: paulb PolarBox 2 3 09-25-2009 16:10
freezed Samsung Z400 jackracker Samsung Flashers, Software, Firmware. 0 11-11-2006 15:55
Phone Freeze Samsung ZM60 Alantius QUALCOMM Models (3G) 3 08-13-2006 05:10
Page generated in 0.34851 seconds with 11 queries
