Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported IMEI calculator Sites or Software Products > allGSMunlock MultiOnline Remote Server > Samsung Remote Online server
Old 08-19-2008, 14:54   #1 (permalink)
Member: 126612
Serial cable for i710
Would it be possible to get a cable schematic as above ?
SRS requires a serial cable for that model for unlock ...
Thanks in advance
Old 08-20-2008, 12:41   #2 (permalink)
ssa
ssa's Avatar
Member: 23420
you can use an D800 Serial or FTDI cable for this
if you have an servicebox like USTpro or NSpro u can also use the RJ45 cable for d800 supplied with the box, make sure the box comport is between 1 and 16
Old 08-21-2008, 06:53   #3 (permalink)
Member: 126612
Thanks for your response but i have already tried that before posting ... i used nspro with the cable supplied with the box (D800) set to com5 but it does not work ... Since ust uses the unibox pinout i used the cable in a rs232 com box and also does not work ... when client says press power button on phone i do that (short power - one press not holding button down ) and phone powers on with no box communication .... both the cable work fine on there respective boxes ...
Driver for serial cable for Sharp ALEXEY1979 Sharp 9 11-11-2005 22:43
Serial Cable for the K750i HELLOOOO Sony Ericsson 2 09-09-2005 15:53
Where i can buy the serial cable for unlock GX30??? pippomix Sharp 9 10-22-2004 13:33
Serial cable for Nokia 3530 to connect to internet c_tosin Nokia Digital Core Technology 4 ( DCT-4 ) 2 09-15-2003 06:44
Build a serial cable for C35. Help!!! mf x1x to x45/x50 1 11-15-2000 07:16
Page generated in 0.34170 seconds with 11 queries
