Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported IMEI calculator Sites or Software Products > allGSMunlock MultiOnline Remote Server > Samsung Remote Online server
Old 09-06-2008, 16:58   #1 (permalink)
AtrixJ's Avatar
Member: 669827
Sonork: 1576281
Tutorial on how to change IMEI
Things you need:
  • E210 RJ45/USB Combo Cable for UST/Easy Unlocker
  • 15 Credits on Allgsmunlock Server
  • Allgsmunlock Server Software
  • Samsung Qualcom Client Ver 0.0.2
Things you need to know before you start:
  • Disable Bluetooth
  • Switch USB Connection mode to "PC Suite"
Instructions
  1. Connect "E210 RJ45/USB Combo Cable for UST/Easy Unlocker" to "Unibox" and PC USB port
  2. Connect Phone to USB Cable
  3. Open "Samsung Qualcom Client Ver 0.0.2"
  4. Both Ports should be shown at the top (Select the correct com port if its different to Auto Selected)
  5. Press "Make ASK" (Software will read info from phone and create ASK file in "Log" folder.
  6. Open "AllGSMunlock" software
  7. Login with your user name and password
  8. In the first column select "Special Services"
  9. In the second column select "Samsung 3G RPL"
  10. Next column "Universal format"
  11. Type in the current IMEI of your phone
  12. Press the button at the end of the "file" box, and find the "ASK" you created (its in the "Log" folder where your "Samsung Qualcom Client Ver 0.0.2" is.
  13. Takes up to 24hr to process
  • To download your RPL Select "Files" from the drop down on the right hand side this will list all files to download, find your corresponding IMEI and download it.
  • Once you recieve back your RPL
  • Copy your *.rpl folder from "\Program Files\allGSMunlock\allGSMunlock Client\Finished"
  • to your "Log" directory in the same folder as "Samsung Qualcom Client Ver 0.0.2"
  • Remove the "space" from the begining of the *.rpl file name
  • Connect "E210 RJ45/USB Combo Cable for UST/Easy Unlocker" to "Unibox" and PC USB port
  • Connect Phone to USB Cable
  • Open "Samsung Qualcom Client Ver 0.0.2"
  • Type in the "New IMEI"
  • Press "Use RPL" The software will write the RPL and the new IMEI to the handset.
  • (Once you have the RPL for that phone, you can change the IMEI as many times as you like.
The Following 2 Users Say Thank You to AtrixJ For This Useful Post:
[TUTORIALS] Video tutorials on how to use MXKEY BlackBerry Module hamada-almasry MXKEY Blackberry Flasher and Unlocker (by Alim Hape) 4 02-04-2010 22:49
can some one please give a guide on how to change imei on k750i please nokia_dan Cruiser Suite 0 11-26-2005 19:44
How to change imei on bosch 909/909S ? robbie Various 2 04-09-2003 20:58
How to change imei on S35? CompleteFone x1x to x45/x50 2 10-29-2001 13:29
How to change IMEI on T28 ?? Craig Old Ericsson Phones & Sony Phones 0 08-03-2000 00:31
Page generated in 0.20309 seconds with 11 queries
