09-14-2011, 16:50 | #1 (permalink) |
No Life Poster Join Date: Oct 2007
Member: 601921 Status: Offline Thanks Meter: 131 | Car Power Turbine Launcher F1-Z - Double Propeller F1-z power launcher turbine (double propeller) is designed by auto-engineer. The propeller of power launcher turbine spins with the engine speed generating a maximum force to create a powerful airflow into the combustion chamber at a higher speed. The single propeller ***** the airflow into the combustion chamber at a higher speed resulting atomized burning: Increase horse power and save gasoline. Why you need f1-z power launcher? Internal combustion gasoline engines run on a mixture of gasoline and air. The ideal mixture is 14.7 parts of air to one part of gasoline (by weight. ) one part of gas that is completely vaporized into 14.7 parts of air can produce tremendous power when ignited inside an engine. The quantity and quality of the air being mixed with fuel is of vital importance. It helps determine the longevity of an engine, more air you can get into the cylinder the more horsepower the engine will produce. F1-z power launcher was designed, to increase air intake volume to the engine. The concept is to create two different air velocity profiles, one traveling at higher speeds than the other does. This technology increases air volume and speed to the engine. Price: USD 15.91 [More Detail] More... |
******* Power Balance Energy Wristband Bracelet - 50PCS (Size: XS, S, M, L, XL) | IPMART | ipmart WebShop | 0 | 09-14-2011 12:40 |
******* Power Balance Energy Wristband Bracelet - 150PCS (Size: XS, S, M, L, XL) | IPMART | ipmart WebShop | 0 | 09-14-2011 12:40 |
******* Power Balance Energy Wristband Bracelet - 100PCS (Size: XS, S, M, L, XL) | IPMART | ipmart WebShop | 0 | 09-14-2011 12:40 |
