Unlock Server
Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SRS (Simlock Remote Server)
SRS (Simlock Remote Server) 160
Old 02-12-2010, 11:37   #1 (permalink)
Member: 1234376
Cool cant unlock t939 behold 2 [Solved and Unlocked]
hi for the life of me i cant unlock this for the wifey and its really the only reason i purchased 3 creidts this is the error i get
Locating Remote server...
Getting data from server.
Setting testmode..
6:16:02 AM - OMAP TESTMODE: DONE
6:16:02 AM - Reading Phonedata
6:16:03 AM - Firmware: T939UVIJ6
6:16:03 AM - Imei: 355078031099xx
6:16:04 AM - Chipset: M76XX-SDCBALUM-6375
6:16:04 AM - MSL Addr: R6XSB706xx
6:16:04 AM - Getting Bypass Code from server
6:16:06 AM - ERROR: Security bypass failed.
i apprecaiate any help as she doesnot have a phone at the moment and we have a new born
Old 02-12-2010, 11:56   #2 (permalink)
Member: 1234376
error fixeddddddd
went into samsung remote client folder and double clicked on reg-ocx.cmd said installing after that i tried again and it unlocked
Old 02-12-2010, 15:16   #3 (permalink)
ssa
ssa's Avatar
Member: 23420
Perfect, maybe some files where not correctly registered on your system during the install of the program, we never heard this error before, but we will track it, in case it's an sw bug it will be fixed in next release
anyway thanks for reporting succesfull unlock of Samsung T939 Behold 2
Old 02-13-2010, 16:18   #4 (permalink)
Member: 239856
Unlock OK 3 day ago. Thanks SRS Server. The best
Setting testmode..
4:55:21 PM - OMAP TESTMODE: DONE
4:55:21 PM - Reading Phonedata
4:55:22 PM - Firmware: T939UVIJ6
4:55:22 PM - Imei: 35507803010258
4:55:23 PM - Chipset: M76XX-SDCBALUM-6375
4:55:23 PM - MSL Addr: R5XSA06838
4:55:23 PM - Getting Bypass Code from server
4:55:24 PM - Not in database, Starting Security Analysis...
4:55:37 PM - AKSEED Bypass: 10441-13-55 -> 1279-91-94
4:55:47 PM - Leaving Testmode
4:55:47 PM - Unlock Done...
If phone asks for a code enter 31791323
Old 02-13-2010, 16:52   #5 (permalink)
ssa
ssa's Avatar
Member: 23420
Thxn for info
did you used original usb in usbdiag mode or pinout under batery in uartdiag ?
i think both options should work...
Old 02-14-2010, 13:22   #6 (permalink)
Member: 1234376
i used the i7500 trick where u type *#9 something something then pick usb 1dialog
ku990 eror 1001? /// SOLVED and UNLOCKED :!)) omer100 Basic Micro-Box Software Support 2 12-06-2008 17:41
Error 1003 KU990 KC910 // SOLVED and UNLOCKED :)) 131313 Basic Micro-Box Software Support 3 12-06-2008 17:21
6131 unlock error cause deffectived TP cable,solved and unlock yhob BB5BOX 1 04-26-2008 22:53
Page generated in 1.29252 seconds with 11 queries
