08-02-2010, 20:21 | #1 (permalink) |
Junior Member Join Date: May 2006
Member: 279751 Status: Offline Thanks Meter: 1 | Problem with s3370 [Solved] I've tried with 4 different computers and OS (Winxp-sp3 & Win7) but the result it's always the same and I followed all the given instructions! In the device manager the hw (modem, qualcomm diagnostics and so) is found! Thanks! |
08-03-2010, 03:55 | #2 (permalink) |
No Life Poster Join Date: Apr 2001
Member: 3941 Status: Offline Thanks Meter: 636 | Hi, Set com ports manually for this problem and don't use the rescan button. However there are some other problems with this model as well but that is not related with the problem you are describing. If you experience that we can't do your version yet and if possible we would like to get your phone in our hands to solve the problem. For that please contact SSA in this forum. Best regards, |
08-04-2010, 17:27 | #3 (permalink) |
Member: 279751 Status: Offline Thanks Meter: 1 | Thanks for your answer! But still no result I've tried what you've advised me and this is what i get: 5:57:53 PM - Reading phone 5:57:53 PM - Model: GT-S3370 5:57:53 PM - Current Firmware: GT-S3370 5:57:53 PM - Original Firmware: S3370NEJD4_3ITJ 5:57:54 PM - IMEI: 35xxxxxxxxxx 5:57:54 PM - Reading Partition... 5:59:34 PM - ERROR: Failed to get memory address () -- Operation done in 102 seconds -- Is it this the other problem you were talking about? Thanks again and best regards |
08-04-2010, 22:11 | #4 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Inside CPU Age: 43
Member: 23420 Status: Offline Thanks Meter: 3,080 | S3370 issue is fixed in new version i see from your log you have an S3370N phone please download latest client at http://www.UnlockSamsungOnline.nl/so.../srs-setup.exe install this and select model S3370N make sure you have simcard inside or type *#7465625# after entering qualcomm mode then press read codes to get your unlock codes |
08-05-2010, 08:16 | #5 (permalink) |
Member: 23420 Status: Offline Thanks Meter: 3,080 | some log of succesfull unlock Code: New Session 8/4/2010 10:02:21 PM Version: 10.0.15 Phone: S3370N Ports: C:12 M:14 10:01:47 PM - Reading phone 10:01:48 PM - Model: GT-S3370 10:01:48 PM - Current Firmware: GT-S3370 10:01:48 PM - Original Firmware: S3370NEJD4_3ITJ 10:01:48 PM - IMEI: 3526730408**** 10:01:48 PM - Reading Partition... 10:01:51 PM - Reading Security... 10:01:51 PM - Getting crypto data from server, Please Wait... - Unfreeze: Not Frozen - Unlock Network: #7465625*638*80294624# - Unlock SP Lock: #7465625*77*00000000# 10:02:00 PM - All Jobs done To repair Phone Freeze,insert other operator SimCard.Enter Code(it will not be visible) and accept with OK key To unlock: REMOVE simcard from phone and type the full unlock codes. -- Operation done in 38 seconds -- |
08-05-2010, 15:13 | #6 (permalink) |
Member: 279751 Status: Offline Thanks Meter: 1 | I've tried what you told me but still the same problem! But now I've a doubt as well... since I can't make the portscan (srs freezes) i've to put manually comport and modem. The comport is the one coming from the Samsung HS-USB Diagnostics 9002 (in my case COM4). The modem is Samsung HS-USB Modem 9002 and it's COM3. So if i'm not wrong i should write in comport "4" and in modem "3" in srs client, isn't it? One more thing: the lastest version of srs is still 10.0.15, right? Thanks! Last edited by orsettogommoso; 08-05-2010 at 15:19. |
08-05-2010, 15:43 | #7 (permalink) | |
Member: 23420 Status: Offline Thanks Meter: 3,080 | Quote:
if you have msn messenger we can solve this out remotely | |
The Following User Says Thank You to ssa For This Useful Post: |
NHE_8 wont work with NHEK5689.dll v3 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-1999 15:48 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
