Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SRS (Simlock Remote Server)
Old 09-11-2008, 19:46   #1 (permalink)
ssa
ssa's Avatar
Member: 23420
Thanks Meter: 3,080
Post here your successful unlocks
here you can post the screenshots of successful unlock by SRS Server
please also post what box / cable you used to unlock your phone
this way you can help others by unlocking their phones by SRS
The Following 3 Users Say Thank You to ssa For This Useful Post:
Old 09-11-2008, 19:51   #2 (permalink)
ssa
ssa's Avatar
Member: 23420
Thanks Meter: 3,080
Phone Model: Samsung F110 Read Codes
Phone Cable: E210
Phone Model: Samsung C180 Read Codes
Phone Cable: C180 FTDI Cable
Phone Model: Samsung J700 Read Codes
Phone Cable: E210 FTDI cable
Phone Model: Samsung E250w Read Codes
Phone Cable: D800 FTDI cable
Old 09-12-2008, 17:56   #3 (permalink)
ssa
ssa's Avatar
Member: 23420
Thanks Meter: 3,080
Phone Model: Samsung B130 Direct Unlock
Phone Cable: E210
The Following 2 Users Say Thank You to ssa For This Useful Post:
Old 09-17-2008, 11:48   #4 (permalink)
ssa
ssa's Avatar
Member: 23420
Thanks Meter: 3,080
LG KG800 Direct unlock in 10 secs.
Cable needed: FTDI KG800 unlock cable
Program: SRS LG Module 2.11
Old 09-27-2008, 11:02   #5 (permalink)
ssa
ssa's Avatar
Member: 23420
Thanks Meter: 3,080
WORLD FIRST,
code reading in new versions of C450 Sysol (special update for dutch people with new "POSTBANK" phone)
The Following User Says Thank You to ssa For This Useful Post:
Old 11-22-2008, 13:39   #6 (permalink)
ssa
ssa's Avatar
Member: 23420
Thanks Meter: 3,080
Samsung P960 TV
Cable: Original cable
Old 02-19-2009, 11:01   #7 (permalink)
Member: 43404
Thanks Meter: 19
Phone Model: Samsung B320 Read Unlock Code
Phone Cable: AT170 G800
The Following 2 Users Say Thank You to warm_icez For This Useful Post:
Old 05-17-2009, 11:10   #8 (permalink)
ssa
ssa's Avatar
Member: 23420
Thanks Meter: 3,080
Samsung C270 E2P code reading with E210 FTDI Cable
Unlock Code and repair phone freeze code readout successfull
Old 05-18-2009, 12:47   #9 (permalink)
ssa
ssa's Avatar
Member: 23420
Thanks Meter: 3,080
New Samsung E1360 unlocked in E2P mode with E210 cable
Old 05-21-2009, 13:05   #10 (permalink)
ssa
ssa's Avatar
Member: 23420
Thanks Meter: 3,080
Samsung P250 Code Reading
Old 06-26-2009, 07:06   #11 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
SAMSUNG i617 UNLOCK SUCESSFULL
WBR
sahil2000ind
The Following User Says Thank You to sahil2000ind For This Useful Post:
Old 07-04-2009, 14:17   #12 (permalink)
ssa
ssa's Avatar
Member: 23420
Thanks Meter: 3,080
Samsung S5200c Unlock Done
SWIFT Download Mode: Done
14:54:22 - SENDING PRELOADER...
14:54:38 - SENDING MAINLOADER...
14:55:05 - DETECTED: [00EC2206] KAP29SN00M
14:55:05 - DETECTED: [00000034] KBH1xPE00M
14:55:05 - READING E2P DATA 512/512
15:02:04 - READING: DONE
15:02:04 - ANALYSING EPROM DUMP...
Unlock Code 1 Found: 05485970
Unlock Code 2 Found: 95791080
15:02:21 - OPERATION: DONE
Old 07-05-2009, 16:51   #13 (permalink)
Member: 145289
Thanks Meter: 35
When others fail srs not... Sam E1075 by read epp.
The Following 2 Users Say Thank You to hakkothebest For This Useful Post:
Old 09-04-2009, 12:11   #14 (permalink)
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
SAMSUNG S3500 UNLOCKED WITH SRS
SRS NEVER FAILS. UNLOCK DONE BY USB CABLE
Locating Remote server...
Getting data from server.
Booting Trident Phone...
16:36:19 - SET TESTMODE DONE
16:36:20 - IMEI: 35455603050200
16:36:21 - FIRMWARE: S3500DDIE (May 2009)
16:36:22 - MSL2 IS LOCKED, PROGRAMMING CODE
16:36:23 - MSL ADDRESS: RW7S593827
16:36:27 - GETTING MSL INFO FROM SERVER: DONE
16:36:27 - MSL2 SECURITYCODE BYPASS: DONE
16:36:27 - MSL BYPASS: DONE
16:36:27 - CHECKING CUSTOMER CODE:S3500ODDIB5. DONE
16:36:32 - UNLOCKING PHONE .... DONE
Please reboot phone for normal operation..
WBR
sahil2000ind
The Following 2 Users Say Thank You to sahil2000ind For This Useful Post:
Old 09-05-2009, 10:19   #15 (permalink)
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
SAMSUNG S5233A USER CODE RESET AND DIRECT UNLOCK DONE BY SRS
SRS NEVER FAILS
USERCODE RESETLOG
Starting UserCode Reset Phase...
14:30:58 - RESETTING PHONECODEONE
14:30:59 - RESETTING SIMLOCK: DONE
14:30:59 - RESET: DONE
DIRECT UNLOCK LOG
14:46:32 - Starting Phone in servicemode
14:46:33 - ServiceBoot done.
14:46:33 - Getting Data from phone
14:46:33 - Firmware: S5233ADDIF
14:46:34 - Imei: 35518003025875
14:46:34 - MSL Serial: RPHS629883
14:46:34 - UniqueNumber: 55300000245100
14:46:34 - MSL Code: 319538
14:46:35 - AKSEED Bypass: 9017-16-23 -> 1488-96-95
14:46:36 - Switching USB Mode
14:46:36 - Starting Unlock Phase .....
14:46:41 - Unlock Done.
14:46:41 - Phonelock Reset to: 00000000.
14:46:41 - Simlock Reset to: 00000000.
14:46:41 - All jobs completed.
WBR
sahil2000ind
The Following 3 Users Say Thank You to sahil2000ind For This Useful Post:
..:::Please Post here Your Success by Z3X Mediatek Smart Tool:::.. rhamzky Z3X-Team Products 0 10-03-2009 08:02
!! Post Here your Successfully Working Presets !! GsmEasy TORNADO - SIM 8 05-15-2008 18:40
Please Post here BB5 Success Unlocked... Afzaal Nokia Base Band 5 ( BB-5 ) 222 07-12-2007 07:40
Page generated in 0.23537 seconds with 10 queries
