Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SRS (Simlock Remote Server)
SRS (Simlock Remote Server) 160
Old 08-24-2009, 16:55   #1 (permalink)
Member: 689942
Problem in unlock M2510
I have problem in unlock for model M2510.
I tried the options m2310 and M2510 and can not unlock.
Old 08-24-2009, 18:49   #2 (permalink)
ssa
ssa's Avatar
Member: 23420
power off phone
now connect to computer
battery will be charging, now press rescan in client, then direct unlock
btw i also add you to msn messenger, in case it not work we need to make some test, maybe you have different firmware in phone than our test phone
Old 08-24-2009, 19:07   #3 (permalink)
Member: 543573
M2510 locked on Claro Brasil
Hi, I have the same problem,
Locating Remote server...
Getting data from server.
Booting Trident Phone...
15:07:40 - SET TESTMODE DONE
15:07:40 - IMEI: 35401303XXXXXX
15:07:42 - FIRMWARE: M2510UTIE (May 2009)
15:07:43 - MSL2 IS LOCKED, PROGRAMMING CODE
15:07:44 - MSL ADDRESS: RS9S680216
15:07:47 - MSL BYPASS: FAILED
15:07:47 - CHECKING CUSTOMER CODE:M2510ZTAIE2_H8. DONE
15:07:52 - UNLOCKING PHONE .FAILED
Please try again or contact support
You can also try to read out the codes via READ CODES button
Now i tried by read codes:
This phone is not supported for Unlock/ Read codes yet ! Available options: Reset usercode, Imei Repair, SN Repair
Now by phone off charging batery:
Rescanning ports...
Detected COM1 - STATUS: READY
Detected COM3 - STATUS: READY
Any new's
for add on msn manutencel@hotmail.com
Old 08-25-2009, 18:08   #4 (permalink)
Member: 689942
My mobile is Claro ( Brazil ) and problem not solved
Old 08-25-2009, 18:20   #5 (permalink)
ssa
ssa's Avatar
Member: 23420
contact me on msn messenger as told before to do some testing
please ust support add correct bug in UNlocking m2510 failed bypass residentdenuevo UST Pro II 0 01-04-2010 03:54
problem in unlocking lg 8120 in setool askaralikp SETool2 5 12-12-2009 19:21
problem in unlocking bg3 kinyanjui BF, BG, TH, BHx Series 0 12-19-2003 11:54
problem in unlocking GD92 DrMobile Panasonic 6 05-12-2002 22:55
i have problem in unlocking mu v66 DrMobile P2k Series 4 03-29-2002 14:17
Page generated in 0.25097 seconds with 12 queries
