12-27-2010, 03:24 | #1 (permalink) |
Insane Poster Join Date: Jul 2004 Location: Italy Age: 40
Member: 72623 Status: Offline Thanks Meter: 0 | Problem unlock s3370 [Solved - Unlock Okay] When i try "read unlock codes" on my S3370, the program start read code, but after closes by itself. Why ? If i try direct unlock i view message error: Pls help me.... Other week i have unlock 1 samsung, same model with no error... |
12-27-2010, 13:59 | #3 (permalink) |
Member: 72623 Status: Offline Thanks Meter: 0 | yes, i have disable kies and firewall... have try also other pc with new installation srs... But not solve :-( same problem... help... i think is problem server srs... pls check... repeat... if select 3370, found com.. all ok.... select "read unlock codes" start unlock but after 2 second the program closes by itself... |
12-27-2010, 14:26 | #4 (permalink) |
Member: 72623 Status: Offline Thanks Meter: 0 | I noticed a strange thing. Although I flashed the phone with the version of the program S3370XEJD3 me anyway: 14:09:57 - Reading phone at 921600bps 14:09:57 - Model: GT-S3370 14:09:57 - Original Firmware: S3370NEJI1 (September 2010) 14:09:57 - IMEI: 351662040058432 14:09:58 - Received from EntryPoint Server .. 14:09:58 - Reading Security ... (1 / 411) but if I read with *#1234# the firmware version on display read correctly S3370XEJD3 Why srs read S3370NEJI1 and crash ? |
12-27-2010, 16:25 | #5 (permalink) |
Member: 72623 Status: Offline Thanks Meter: 0 | i think have found problem... the firmware S3370NEJI1 (September 2010) is a new EVO and now not unlock srs and hwk... only NSPRO... I try downgrade with other version, flash ok, +#1234# ok, but srs read always version S3370NEJI1. You think can add this model in next update srs ? Last edited by fabio84; 12-27-2010 at 16:31. |
12-27-2010, 21:08 | #6 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Inside CPU Age: 43
Member: 23420 Status: Offline Thanks Meter: 3,080 | SRS can unlock this version too.. but you have to select S3370N see log from other user with exact same firmware 19:57:35 - Reading phone at 921600bps 19:57:35 - Model: GT-S3370 19:57:35 - Original Firmware: S3370NEJI1 (September 2010) 19:57:35 - IMEI: 35267304896*** 19:57:36 - Received EntryPoint from Server.. 19:57:36 - Reading Security... (411 /411) 19:57:36 - Security Read: Done 19:57:36 - Getting crypto data from server, Please Wait... - Unfreeze: 15729475 + OK (State: Not Frozen) - Unlock Network: #7465625*638*08681942# - Unlock SP Lock: #7465625*77*00000000# - Unlock Sub Lock: #7465625*782*00000000# To repair Phone Freeze,insert other operator SimCard.Enter Code(it will not be visible) and accept with OK key To unlock: REMOVE simcard from phone and type the full unlock codes. -- Operation done in 7 seconds -- |
12-27-2010, 21:58 | #7 (permalink) |
Member: 72623 Status: Offline Thanks Meter: 0 | Have try select s3370N same problem :-( program crash when found firmware... You have firmware S3370NEJI1 ? I try first reflash phone with this and after try new unlock... |
12-28-2010, 01:04 | #9 (permalink) |
Member: 72623 Status: Offline Thanks Meter: 0 | also other box have problem with this firmware: http://forum.gsmhosting.com/vbb/f311...-help-1173651/ :-( |
01-07-2011, 16:14 | #11 (permalink) |
Member: 23420 Status: Offline Thanks Meter: 3,080 | SRS solved all issue's with this version.. was a corruption in the database some logs: Server: 07-01-2011 14:52:29 - User: New Session 07/01/2011 14:52:33 Version: 10.0.31 Phone: S3370 Ports: C:50 M:48 14:52:27 - Reading phone at 921600bps 14:52:27 - Model: GT-S3370 14:52:27 - Original Firmware: S3370NEJI1 (September 2010) 14:52:27 - IMEI: 352673049996888 14:52:28 - Received EntryPoint from Server.. 14:52:28 - Reading Security... (411 /411) 14:52:29 - Security Read: Done 14:52:29 - Getting crypto data from server, Please Wait... - Unfreeze: 50264957 + OK (State: Frozen) - Unlock Network: #7465625*638*08513970# - Unlock SP Lock: #7465625*77*00000000# - Unlock Sub Lock: #7465625*782*00000000# To repair Phone Freeze,insert other operator SimCard.Enter Code(it will not be visible) and accept with OK key To unlock: REMOVE simcard from phone and type the full unlock codes. -- Operation done in 38 seconds -- Server: 06-01-2011 2:20:56 - User: New Session 06/01/2011 1.20.55 Version: 10.0.31 Phone: S3370 Ports: C:3 M:4 1.20.49 - Reading phone at 921600bps 1.20.50 - Model: GT-S3370 1.20.50 - Original Firmware: S3370NEJI1 (September 2010) 1.20.50 - IMEI: 35267304911**** 1.20.50 - Received EntryPoint from Server.. 1.20.50 - Reading Security... (411 /411) 1.20.51 - Security Read: Done 1.20.51 - Getting crypto data from server, Please Wait... - Unfreeze: 39307313 + OK (State: Not Frozen) - Unlock Network: #7465625*638*64649146# - Unlock SP Lock: #7465625*77*00000000# - Unlock Sub Lock: #7465625*782*00000000# To repair Phone Freeze,insert other operator SimCard.Enter Code(it will not be visible) and accept with OK key To unlock: REMOVE simcard from phone and type the full unlock codes. -- Operation done in 36 seconds -- Server: 05-01-2011 14:04:50 - User: New Session 05-Jan-11 14:05:10 Version: 10.0.31 Phone: S3370N Ports: C:21 M:39 14:05:03 - Reading phone at 921600bps 14:05:04 - Model: GT-S3370 14:05:04 - Original Firmware: S3370NEJI1 (September 2010) 14:05:04 - IMEI: 35267304965*** 14:05:05 - Received EntryPoint from Server.. 14:05:05 - Reading Security... (411 /411) 14:05:05 - Security Read: Done 14:05:05 - Getting crypto data from server, Please Wait... - Unfreeze: 26904208 + OK (State: Not Frozen) - Unlock Network: #7465625*638*95717153# - Unlock SP Lock: #7465625*77*00000000# - Unlock Sub Lock: #7465625*782*00000000# To repair Phone Freeze,insert other operator SimCard.Enter Code(it will not be visible) and accept with OK key To unlock: REMOVE simcard from phone and type the full unlock codes. -- Operation done in 8 seconds -- |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
