Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| SRS (Simlock Remote Server) 160 |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2003 Location: Inside CPU Age: 32
Member: 23420 Status: Offline Thanks: 52
| Yes, just use the original micro-usb you can use Direct unlock, in case you get an error in SEED then use READ CODES (to bypass the new security) make sure you have an simcard inserted in the phone when using read codes (any simcard will do) |
| | #5 (permalink) |
| then the phone's diagport is detected wrong on your computer, instead of the diagport it uses the GPS port, check your device manager for correct qualcomm diagnostic port and enter it manual to the client |
| | #6 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2004 Age: 32
Member: 92401 Status: Offline Thanks: 22
| There are 2 Ports Qualcomm Diagnostics Interface 6000 (COM25) Qualcomnm NMEA Device (COM26) but when i press rescan in SRS client, it just shows port 26 and nothing else. I even cant choose port manual. |
| | #7 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2001
Member: 3941 Status: Offline Thanks: 35
| Hi, First try to just enter '25' into the box manually and see what it does. If you get an error it means port 25 (which is the correct one) is in use by some other software. Do you happen to have any 3G modem (UMTS dongle) software installed? If yes then probably that is the reason and you have to uninstall that first (and restart computer). The drivers used in many (specially huawei 3G internet dongles) are very similar as the QXDM drivers for unlocking. Best regards, |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| How to unlock S8300 with HWK? | Cake | HWK | 1 | 06-17-2009 17:25 |
| ust can t unlock s8300 even with ver 9.5.1 | yasminato | UST Pro II | 13 | 06-15-2009 16:16 |
| has any one unlocked S8300??? | sniper007 | QUALCOMM Models (3G) | 6 | 04-21-2009 12:04 |
| how to unlock s8300 ? which cable(usb) | hjfwei | UST Pro II | 5 | 04-15-2009 15:07 |
