01-10-2010, 21:11 | #1 (permalink) |
Junior Member Join Date: Jan 2010
Member: 1205721 Status: Offline Thanks Meter: 0 | S7350i unlock problem i'm facing problem in unlocking my S7350i Booting phone in testmode 20:56:14 - BOOT DONE. 20:56:14 - GETTING DATA FROM PHONE 20:56:14 - MSL SERIAL: 20:56:16 - FIRMWARE: 20:56:16 - UNIQUEKEY: 20:56:16 - IMEI: 20:56:17 - EXTENDED SEED ANALYSE: ACTIVATED 20:56:18 - PHONE SEED: 20:56:18 - SENDING DATA TO SERVER.. PLEASE WAIT.. 20:56:18 - ERROR: WRONG DATA FROM PHONE (UNIQUEKEY) Failed.. cannot bypass MSL same after reset with *2767*3855# plz help best regards |
01-10-2010, 22:30 | #2 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Inside CPU Age: 43
Member: 23420 Status: Offline Thanks Meter: 3,080 | The client instructs you to put the phone in QXDM (Qualcomm) mode with code *#782872# please do this and install the drivers, then press rescan to set the correct ports after this you can use the direct unlock button, all this info is also in the clients manual when you select your phone model.. please follow these steps, then all will be fine... |
01-10-2010, 23:05 | #3 (permalink) |
Member: 1205721 Status: Offline Thanks Meter: 0 | is exactly what i already done -samsung PC studio is deinstalled -Qualcomm drivers are installed -QXDM Mode *#782872# is on -com port is ok, according to device manager communication pc-phone looks good but the result is same... the phone work properly only with original SIM if i try to use different SIM card is frozen. shall i before unlock repair it with SRS? |
01-11-2010, 08:29 | #4 (permalink) |
Member: 23420 Status: Offline Thanks Meter: 3,080 | go to device manager > ports com&lpt here you see Qualcomm diagnostic port with a port number behind it select this port as COMPORT then go to devicemanager > modems here you see Qualcomm modem port, right click on it, and go properties then choose tab advanced > advanced port settings here you see the comport number, select this port as modemport in the client then click unlock the error you describe is caused by wrong port selection or missing driver installation. |
01-11-2010, 09:55 | #5 (permalink) |
Member: 1205721 Status: Offline Thanks Meter: 0 | thx, but there is still a problem: Booting phone in testmode 09:49:54 - BOOT DONE. 09:49:54 - GETTING DATA FROM PHONE 09:49:54 - MSL SERIAL:RVHSC60155 09:49:55 - FIRMWARE: S735IMMIH1_IJ1 (August 2009) 09:49:55 - UNIQUEKEY:80400000386456 09:49:55 - IMEI:358194030978505 09:49:56 - EXTENDED SEED ANALYSE: ACTIVATED 09:49:57 - PHONE SEED:88907E 09:49:57 - SENDING DATA TO SERVER.. PLEASE WAIT.. 09:49:57 - ERROR: WRONG DATA FROM PHONE (SEED) Failed.. cannot bypass MSL |
01-11-2010, 16:20 | #7 (permalink) |
Member: 23420 Status: Offline Thanks Meter: 3,080 | i see in the server log your issue is solved.. Remove Credit: Qualcomm MSL3 S7350i - IMEI:358194030978505 - Codes: MCK:93138616 NCK:57485047 SP:00000000 |
Samsung Jet S800 Unlock problem | javakiller | Z3X-Team Products | 8 | 05-15-2010 12:14 |
Alcatel ot 103 Unlock probleme | abote didier | Infinity-Box | 4 | 04-26-2010 17:04 |
s7350i unlock problem help spt team plssss [NOT SUPPORTED] | ibrahim_casper | SPT BOX | 2 | 03-06-2010 12:42 |
s7350i unlock error | lian500 | Z3X-Team Products | 1 | 12-18-2009 18:11 |
w200 unlock problem i think exe problem please lead look here | saily | Cruiser Suite | 22 | 08-15-2007 14:31 |
