06-02-2009, 18:48 | #1 (permalink) |
Freak Poster Join Date: Apr 2004 Age: 45
Member: 60701 Status: Offline Sonork: 100.1623285 Thanks Meter: 121 | samsung m7600 unlock with server need help Booting phone in testmode 19:37:22- BOOT DONE. 19:37:22 - GETTING DATA FROM PHONE 19:37:22 - MSL SERIAL:RU3S478118 19:37:23 - FIRMWARE: M7600BVID5 (April 2009) 19:37:23 - UNIQUEKEY:80810000032089 19:37:23 - IMEI:352826030***859 19:37:24 - PHONE SEED:4B1304000000000000000000FFFFFFFF 19:37:24 - SENDING DATA TO SERVER.. PLEASE WAIT.. 19:37:35 - MSL2 Bypass Code: 000000 (patched) 19:37:35 - MSL BYPASS FAILED, SWITCH ALTERNATIVE 19:37:35 - MSL2 Bypass Code: 000000 (patched) 19:37:39 - MSL BYPASS: FAILED 19:37:41 - RESTARTING PHONE Failed.. cannot bypass MSL with code *#782872# Booting phone in testmode 19:42:08- BOOT DONE. 19:42:08 - GETTING DATA FROM PHONE 19:42:08 - MSL SERIAL:RU3S478118 19:42:09 - FIRMWARE: M7600BVID5 (April 2009) 19:42:09 - UNIQUEKEY:80810000032089 19:42:09 - IMEI:352826030***859 19:42:10 - EXTENDED SEED ANALYSE: ACTIVATED 19:42:11 - PHONE SEED:88907E 19:42:11 - SENDING DATA TO SERVER.. PLEASE WAIT.. 19:42:11 - ERROR: WRONG DATA FROM PHONE (SEED) Failed.. cannot bypass MSL with code *#782872# but clic confirmed just after read imei Booting phone in testmode 19:51:09- BOOT DONE. 19:51:09 - GETTING DATA FROM PHONE 19:51:09 - MSL SERIAL:RU3S478118 19:51:10 - FIRMWARE: M7600BVID5 (April 2009) 19:51:10 - UNIQUEKEY:80810000032089 19:51:10 - IMEI:35282603*****59 19:51:11 - EXTENDED SEED ANALYSE: ACTIVATED 19:51:12 - PHONE SEED:4B1304000000000000000000FFFFFFFF 19:51:12 - SENDING DATA TO SERVER.. PLEASE WAIT.. 19:51:24 - MSL2 Bypass Code: 000000 (patched) 19:51:24 - MSL BYPASS FAILED, SWITCH ALTERNATIVE 19:51:24 - MSL2 Bypass Code: 000000 (patched) 19:51:28 - MSL BYPASS: FAILED 19:51:30 - RESTARTING PHONE Failed.. cannot bypass MSL |
06-03-2009, 10:59 | #3 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Inside CPU Age: 43
Member: 23420 Status: Offline Thanks Meter: 3,080 | this version is not supported yet.. we will upload an supported version incl. boot to our support servers today.. load this to the phone and then do unlock again. |
The Following User Says Thank You to ssa For This Useful Post: |
06-04-2009, 19:16 | #7 (permalink) |
Member: 60701 Status: Offline Sonork: 100.1623285 Thanks Meter: 121 | Booting phone in testmode 20:10:44- BOOT DONE. 20:10:44 - GETTING DATA FROM PHONE 20:10:44 - MSL SERIAL:RU3S478118 20:10:45 - FIRMWARE: M7600BVID5 (April 2009) 20:10:45 - UNIQUEKEY:80810000032089 20:10:45 - IMEI:3528260µµµµ859 20:10:46 - EXTENDED SEED ANALYSE: ACTIVATED 20:10:47 - PHONE SEED:88907E 20:10:47 - SENDING DATA TO SERVER.. PLEASE WAIT.. 20:10:48 - ERROR: WRONG DATA FROM PHONE (SEED) Failed.. cannot bypass MSL Booting phone in testmode 20:15:45- BOOT DONE. 20:15:45 - GETTING DATA FROM PHONE 20:15:45 - MSL SERIAL:RU3S478118 20:15:46 - FIRMWARE: M7600BVID5 (April 2009) 20:15:46 - UNIQUEKEY:80810000032089 20:15:47 - IMEI:352826030%µµ5859 20:15:48 - PHONE SEED:4B1304000000000000000000FFFFFFFF 20:15:48 - SENDING DATA TO SERVER.. PLEASE WAIT.. 20:15:59 - MSL2 Bypass Code: 000000 (patched) 20:15:59 - MSL BYPASS FAILED, SWITCH ALTERNATIVE 20:15:59 - MSL2 Bypass Code: 000000 (patched) 20:16:02 - MSL BYPASS: FAILED 20:16:05 - RESTARTING PHONE Failed.. cannot bypass MSL FLASH PHONE OK BUT UNLOCK NOT WORK |
06-04-2009, 20:13 | #8 (permalink) |
Junior Member Join Date: May 2007
Member: 503515 Status: Offline Thanks Meter: 0 | i have exactly the same probleme: Amorcer Telephone en testmode 20:11:56- AMORCAGE FAIT. 20:11:56 - OBTENIR DONNES DE TELEPHONE 20:11:56 - MSL SERIAL:R2XS576505 20:11:57 - FIRMWARE: S5600AEID3 (April 2009) 20:11:57 - UNIQUEKEY:70850000597862 20:11:58 - IMEI:352641030622471 20:11:59 - TELEPHONE SEED:4B1304000000000000000000FFFFFFFF 20:11:59 - ENVOI DE DONNEES AU SERVEUR .. S'IL VOUS PLAÎT ATTENDRE 20:12:11 - MSL2 Bypass Code: 000000 (patched) 20:12:12 - MSL DEPASSE RATÉ, CHANGEMENT ALTERNATIVE 20:12:12 - MSL2 Bypass Code: 000000 (patched) 20:12:15 - MSL DEPASSE RATÉ 20:12:17 - REDEMARRAGE TELEPHONE Raté .. ne peut pas dépasser MSL i think i have lost 15€, bad |
06-05-2009, 19:27 | #9 (permalink) | |
Member: 60701 Status: Offline Sonork: 100.1623285 Thanks Meter: 121 | Quote:
ET OUI MON pote c'est SOUVENT LA MEME HISTOIRE ON TE DIT FIRST IN THE WORLD MAIS UNE VERSION SUPPORTé et non dispo ! allready same storie , team say first in the world but when you want unlock it's not supported we know market ! and we stand ! | |
06-06-2009, 08:58 | #10 (permalink) |
No Life Poster Join Date: Apr 2001
Member: 3941 Status: Offline Thanks Meter: 636 | @ali42 Your first post: M7600BVID5 (April 2009) then after you 'flashed': 20:15:46 - FIRMWARE: M7600BVID5 (April 2009) Flash on the server M7600XEID2 .. Conclusion; you did not flash your phone. Multi loader remembers the previous flash files. Please unpack Multiloader to a new folder unpack our firmware file in the same folder. Make sure you select the CORRECT files in Multiloader and that they are selected. Then flash your phone. You can check software version using *#1234# to see if it was successful. @jpcorse. You didn't loose anything. If we can't help you with this problem you will receive a refund. I think you will need to flash your phone also but currently there is no firmware for your phone on the server and the programmer is on his honeymoon. When he gets back he will work on a solution and put flash file on the server. Our apologies for this delay. |
06-08-2009, 19:09 | #11 (permalink) | |
READ NEWS FOR DETAILS! Searching Samsung USB interface... not found Searching Qualcomm USB interface... detected (COM13) Model: M7600 IMEI: 35282603007585 SW: M7600XEID2 Searching phone at COM interface... ok Model: M7600 SW: M7600XEID2 Last edited by ali42; 06-08-2009 at 19:14. | |
06-09-2009, 06:59 | #12 (permalink) |
Member: 3941 Status: Offline Thanks Meter: 636 | Searching Qualcomm USB interface... detected (COM13) Contact me private this will be faster and give me full log from hitting the 'rescan' button. I think your drivers aren't installed properly. You need 2 QXDM drivers; Qualcomm Modem and Qualcomm Diagport Best regards, |
08-14-2009, 13:34 | #15 (permalink) |
Junior Member Join Date: Aug 2009
Member: 1096089 Status: Offline Thanks Meter: 0 | I have the same problem. Is there already a solution for this? My phone is a Samsung S8300 and I've firmware S8300XXIE1. The drivers are correctly installed and my phone is correct in quallcom mode. |
Samsung M7600 Unlock | noure30 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 1 | 09-03-2009 16:53 |
Samsung M7600 Unlock With Nspro | noure30 | NSPRO | 2 | 08-31-2009 03:26 |
Samsung M7600 Unlock | noure30 | UST Pro II | 4 | 08-29-2009 10:26 |
samsung X650 restart with sim need help!! | msantar | Samsung Flashers, Software, Firmware. | 1 | 04-14-2009 11:48 |
I Have Problem With Server Need Help Please | .::Zafar Communication::. | Redbox | 3 | 04-23-2005 10:13 |
