Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SRS (Simlock Remote Server)
SRS (Simlock Remote Server) 160
Old 08-30-2009, 11:28   #1 (permalink)
atukhi's Avatar
Member: 92401
SRS unlock S5230 with USB
Hi,
is the SRS client unlock the S5230 with the Original USB Cable, cause i tried to get the special cable for that phone no luck!!!
Old 08-30-2009, 13:49   #2 (permalink)
ssa
ssa's Avatar
Member: 23420
no you need an dual cable with com and usb together
if you have an servicebox like nspro, eub, ust etc you can also use the cable that came with that box, and use the box as interface
for example
NSPRO box with E210 cable works perfect for unlocking S5230 phone
in SRS Client select your nspro comport as COMPORT, and modem will be auto-detected while pressing RESCAN
The Following 2 Users Say Thank You to ssa For This Useful Post:
Old 09-28-2009, 19:30   #3 (permalink)
Member: 27606
re
witch e210 cable on NSpro, normal RJ45 or...becouse I connect it on RJ45 cable,instal drivers and cant be detected
Old 09-28-2009, 19:46   #4 (permalink)
ssa
ssa's Avatar
Member: 23420
if you use nspro box as interface you need to install the drivers for the phone
you can find them in c:\program files\samsung remote client\drivers\Mobile 1.0 Broadcomm driver
then in de client select as comport the port of your nspro box, and as modem the phone modem (make sure phone is in pc-studio mode !)
then click unlock, wait a moment, and voila phone unlocked and unfreeded
Old 09-28-2009, 20:49   #5 (permalink)
Member: 27606
when I enter rescan it find usb modem but no NSpro, but when I go to setings control panel,system,device manager, com ports, there is NS pro
Old 09-28-2009, 20:53   #6 (permalink)
ssa
ssa's Avatar
Member: 23420
make sure the port for nspro is not higher than 99
else select the port manualy
Old 09-28-2009, 21:00   #7 (permalink)
Member: 27606
re
it was higher than 99, now is on port2 and I can select it...but nothing happends just
21:57:25 - Booting Phone
ERROR: PHONE NOT FOUND
Make sure your phone is in pc-studio mode and the correct modem port is selected. Also make sure you installed the phone drivers!
TIP: Press RESCAN Ports to see if BCM modem is found.
In system/device manager/comport there is no samsung detected but in universal serial bus controler there is samsung USB modem detected
Old 09-28-2009, 21:12   #8 (permalink)
Member: 27606
I instal driver that are needed...
Old 09-28-2009, 21:55   #9 (permalink)
Member: 27606
re
2:52:36 - Starting Phone in servicemode
22:52:37 - ServiceBoot done.
22:52:37 - Getting Data from phone
22:52:38 - Firmware: S5230RFIG4
22:52:38 - Imei: 35767603430192
22:52:38 - MSL Serial: RP7S982180
22:52:38 - UniqueNumber: 55750000420502
22:52:39 - MSL Code: 186899
22:52:40 - AKSEED Bypass: 2533-33-39 -> 2519-97-98
22:52:40 - Switching USB Mode
22:52:40 - Starting Unlock Phase .....
22:52:46 - Unlock Done.
22:52:46 - Phonelock Reset to: 00000000.
22:52:46 - Simlock Reset to: 00000000.
22:52:46 - All jobs completed.
Problem was in comp, I instal everything on laptop and work fine
is it possible to unlock S5230 with nspro ? harish35200 NSPRO 4 10-31-2011 10:47
succesfully unlock i5700 with usb LABOSSEF NSPRO 5 09-08-2010 07:15
can't unlock s5230 with 9.9.00 derekh37 UST Pro II 7 08-19-2009 14:23
unlock S5230 with nspro HOPPER129 NSPRO 1 07-11-2009 08:42
is it possible to unlock S5230 with nspro ? harish35200 NSPRO 1 07-07-2009 11:04
Page generated in 0.43644 seconds with 11 queries
