SRS and UST problem in new relese Hi im having small problem with detecting UST Pro till this ver i had no problem using UST with UST cables but at the moment it seems it doesn't find ports attached to ust pro ... Any reason that might be happenig ? Thanks for info in advance .... |
did you used latest ust driver ? (FTDI driver) we added some port timeout.. so if your port respond to slow it will give you an timeout.. anyway you can also enter the port manual in the Comport Window just check the device manager > port com&lpt for the correct ust port number.. and type in this number into comport ;) i will make a change in new release to solve this issue |
