Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported IMEI calculator Sites or Software Products > allGSMunlock MultiOnline Remote Server > BB5 ASK/RPL Server Convertor (instant)
Old 09-19-2008, 20:54   #1 (permalink)
allGSMUnlock's Avatar
Member: 522338
Sonork: 100.1575111
BB5 ASK / RPL Convertor - Description
BB5 ASK/RPL Convertor is an application installed on www.askrpl.com (dedicated server) which can automatically convert an ASK file into a RPL file.
What does this “ASK/RPL” actually mean?
“ASK” is short for the word asking and in fact the file read from your phone and sent to the server;
“RPL” is short for reply and is the file converted by the www.askrpl.com server then you will then receive;
What are the supported phones and how does this help me?
The BB5 ASK/RPL service is available for Nokia phones (new generation) from the BB5 series. Any Nokia phone has an error counter for inputting the network unlock code with 3 attempts. If these attempts are exhausted, the error counter is blocked and no more codes can be entered. The only way to unlock this counter (so you can enter the code again) is the ASK/RPL service. More precisely with the help of a piece of software and your phone’s data cable, you connect your phone to this software available in the download section and the file read will be saved into your computer with the *.ASK extension. This file will be sent to our server www.askrpl.com and it can perform the conversion, sending you a file with the *.RPL extension. Once you receive this file and with the help of the software available in our support forum you can write the RPL file from our server into your phone and the phone’s counter will be reset to 0 so you’ll be able to enter the unlock codes 3 more times.
Just as well, the BB5 ASK/RPL service can repair the phone’s security zone, more exactly it can repair phones with SIMLOCK STATE: FFFFFFFFFFFFFFFF all you need is the data cable, the file from the server and the DSS or NSS application available in our support forum.
If your phone has the IMEI: 123456xxxxxxx, the server can calculate the repair file, but you will need special equipment such as: JAF Box, MTBOX, Universal Box and so on, to be able to flash the phone before the operation.
What is the time to receive the RPL file?
www.askrpl.com is a special application, a BB5 ask/RPL convertor which only needs a maximum of 1 minute to deliver the RPL file.
Does the service always work, including weekends?
The service is operational around the clock weekends included. It’s always available without the need for human intervention to generate the files. Everything is automated, the file conversion is instant.
What are the formats accepted by the www.askrpl.com BB5 ASK/RPL Convertor ?
All formats are accepted: MTBOX Nokia, DSS, NSS, JAF, NOKIA Universal FORMAT, UBOX.
Can I read and write the ASK/RPL if I don’t have any special equipment?
Yes, you can repair any Nokia BB5 with simlock state: FFFFFFFFFFFFF with only the use of the free software available in our support forum. If your phone has IMEI: 123456xxxx then you will need a flash tool (MTBOX, JAF, etc)
Provided I read the ASK file with another equipment before sending, is it necessary to use the same tool to write it back?
NO, you can read the ASK file with any tool.
For example:
you can read the file with MTBOX and write the RPL file with the DSS logger or vice-versa.
What is the procedure for reading ASK files in the previously mentioned formats?
1. Tutorial about how to create ASK file using MTBOX [Click here]
2. Tutorial about how to create ASK file using JAF Box [Click here]
3. Tutorial about how to create ASK file using DSS logger [Click here]
4. Tutorial about how to create ASK file using NSS logger [Click here]
What is the step-by-step procedure for repairing my Nokia phone by using this server?
You will need to follow these steps:
  • 1. Make the payment to access the server (prices will differ based on how many files you need)
  • 2. As soon as your account has been activated you can login into the www.askrpl.com server
  • 3. Download the logger to create the ASK file (this is available for free in our dedicated support forum)
  • 4. Start the logger, follow instructions and create the .ASK file
  • 5. Login into the www.askrpl.com server using the username/password you received when you paid for access
  • 6. Select the menu: File Process Order / NEW Order (file service=RPL, Inside service=BB5)
  • 7. Click the “Browse” button and load the .ASK file you have created by the use of the DSS logger from our support forum
  • 8. Press the “Submit” button, the server will tell you the file has been sent
  • 9. Select from the menu the Available/Finished submenu and there you will automatically get the converted file with the .RPL extension
  • 10. Start the logger downloaded from our support forum and connect the phone via USB cable, press the WRITE RPL button, select the file received from the www.askrpl.com server and follow the instructions from the software.
  • In a matter of seconds your phone will be repaired.
WBR,
allGSMunlock
The Following 11 Users Say Thank You to allGSMUnlock For This Useful Post:
GTSAccess 1.37 BB5 ASK/RPL SERVICE andro MT-BOX 906 04-13-2010 20:54
BB5 ASK / RPL Convertor - FAQ allGSMUnlock BB5 ASK/RPL Server Convertor (instant) 0 09-19-2008 20:52
newbie about bb5 ask rpl service. mentari MT-BOX 0 02-10-2007 11:20
Warning: BB5 ASK-RPL!!!! 911GT MT-BOX 8 01-26-2007 16:17
Page generated in 0.23956 seconds with 11 queries
