GPGIndustries Support section The Best of GPGIndustries |
01-27-2010, 14:47 | #1 (permalink) |
No Life Poster Join Date: May 2004 Age: 54
Member: 66136 Status: Offline Thanks Meter: 200 | question about TMA with my Cyclone box [ANSWERED] I use all the time the TMA with my cyclone box, and use the RJ45 cable and put it in the yellow adapter of cyclone (adapter v1), but from some time this don't work and I use now RJ48 (10 pin) adapter in my yellow adapter, and have Problem of peak power (USB), this is TMA probleme, anny one have idea for repair this or need change one all the 3 month ? Best Regards, JAVA Good. |
02-04-2010, 18:12 | #5 (permalink) |
Member: 66136 Status: Offline Thanks Meter: 200 | anny one have solution or can help me pls ? I have the ligth power on if I use RJ45 cable or RJ48 cable, and only RJ48 cable work with my box ? tma ligth.gif anny help pls, Best Regards, JAVA Good. |
02-15-2010, 11:05 | #6 (permalink) |
Member: 66136 Status: Offline Thanks Meter: 200 | hello all, my TMA don't work and after search on the forum I'am not sure about value of the fuse of my TMA, any one can confirme or correct me pls ? value fuse TMA.jpg Best Regards, JAVA Good. |
02-18-2010, 15:12 | #7 (permalink) |
Member: 66136 Status: Offline Thanks Meter: 200 | big tks for the team for all your invisible reply and help, and an other big tks for some unlocker like Alex for reply and help, I desolder all cable and resolder again and change the fuse with an other one, IMAG0086.jpg and my TMA now work, not perfectly but work fine because it's a GPG Money cable, Best Regards, JAVA Good. |
02-23-2010, 12:22 | #9 (permalink) |
Member: 66136 Status: Offline Thanks Meter: 200 | tks for your reply, so can you tell me why if I use the RJ45 or RJ48 cable I have the same led on PCB power on ? in the first time, it's not like now, maybe need change some think, if you can help me pls, maybe next time I buy other one, but I need understand, I don't use it many time, Best Regards, JAVA Good. |
02-24-2010, 04:16 | #10 (permalink) | |
Freak Poster Join Date: Nov 2009
Member: 1158723 Status: Offline Thanks Meter: 13 | Quote:
pls noted that RJ45 can be used with usb and Jaf cable, but RJ48 can be used the Jaf cable without usb. regarding to the same led powered on, pls let me know which led powered on, 8pin or 10pin? br winnie | |
02-24-2010, 12:48 | #11 (permalink) | |
Member: 66136 Status: Offline Thanks Meter: 200 | @ verry nice information and tks for the reply : Quote:
and have a question pls, maybe it's not the section, but the team I think can understand, can use the TMA with MTbox with out anny probleme pls ? Best Regards, JAVA Good. | |
02-24-2010, 14:24 | #13 (permalink) | |
Freak Poster Join Date: Mar 2005 Location: scotland Age: 43
Member: 126067 Status: Offline Thanks Meter: 20 | Quote:
problem with my cyclone box.box is not in needed mode | samih127 | Cyclonebox | 18 | 06-12-2010 06:05 |
question about TMA with my CycloneBox | JAVA Good | Cyclonebox | 4 | 01-24-2010 13:20 |
cyclone team,plz help with my cyclone box. | ADAMISKY | Cyclonebox | 9 | 09-28-2009 18:02 |
I have problem with my cyclone box. Only bootloader mode - No main mode [SOLVED] | ivanrlobato | Cyclonebox | 6 | 08-30-2009 21:16 |
Please help with my cyclone box ????? | geovanny78 | Cyclonebox | 9 | 07-27-2009 18:19 |
