Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section
GPGIndustries Support section The Best of GPGIndustries
Old 12-18-2009, 10:23   #1 (permalink)
fretburner's Avatar
Member: 45571
GPG Universal Interface and NSPro
Does anybody here successfuly used GPG UI with NSPro programmed? please confirm if tested.I tried it myself but not successful.Cannot use NSPro driver after reprogrammed.
The Following User Says Thank You to fretburner For This Useful Post:
Old 12-18-2009, 11:35   #2 (permalink)
MYUNLOCKING's Avatar
Member: 749969
Sonork: 100.1581886
i think its not work with ns pro..
Old 12-18-2009, 14:01   #3 (permalink)
fretburner's Avatar
Member: 45571
but it is listed as supported by GPG and it really doesnt work.dont know if i did it the wrong way but i successfuly programmed using MProg.The only problem is not work with nspro driver.
Old 12-18-2009, 20:45   #4 (permalink)
Bernie's Avatar
Member: 45814
It works perfect, I am using it, as of now I have Setool,Cruiser and NS-Pro in that box, and all work perfect, the problem you have is not with universal interface, it is with NS-Pro drivers that are crapp(no good)
Bernie
Old 12-18-2009, 23:50   #5 (permalink)
fretburner's Avatar
Member: 45571
Please share me nspro drivers that works with GPGUI so i could use my box.
Thanks in advance
Old 12-20-2009, 00:13   #6 (permalink)
fretburner's Avatar
Member: 45571
where is support? How to install drivers for this NSPro?
Old 12-25-2009, 10:40   #7 (permalink)
Bernie's Avatar
Member: 45814
Download nspro installer and use the drivers there, it works.
Bernie
Old 12-25-2009, 11:37   #8 (permalink)
fretburner's Avatar
Member: 45571
Bernie
Why should i download when already installed?i said original NSPro driver not work here on my pc but perfectly working on nspro box
Old 12-25-2009, 15:40   #9 (permalink)
Bernie's Avatar
Member: 45814
Yes it does, I hade the same problem as you, and it was my norton antivirus that did it, I uninstalled that then it worked.
bernie
Old 12-26-2009, 03:14   #10 (permalink)
Member: 1158723
Dear Sir,
pls noted that the following link is the driver for the nspro: http://www.nsteam.org/free/NsPro%20v5.5.8.exe
if you can not download it, pls send me the e-mail in the private message, we will send you in the e-mail.
br
winnie
Old 12-28-2009, 01:42   #11 (permalink)
fretburner's Avatar
Member: 45571
Thanks but my nspro is not yet activated for that version and i copied my old original eeprom from my nspro box and write it on GPG+UI.I cant see any reason why i cannot install the drivers.But if that really the only solution i will try to install new version.I already have that version because i'm an old nspro user and always tracking their releases.I just dont activate yet because still observing their updates.
Old 01-01-2010, 14:45   #12 (permalink)
fretburner's Avatar
Member: 45571
Tested today using latest NSPro v5.5.8 software,driver not working. What's next?
@bernie
do you have some tricks how you did it? i almost concluded now that GPG+UI not work with NSPro.
Old 01-01-2010, 18:08   #13 (permalink)
Bernie's Avatar
Member: 45814
Tested with this Mprog My box Collection!!!
Uninstalled my antivirus uninstalled my ns-pro, then work pefect with GPG-+UI.
I am not using the lates installer. it was some time since I did this.
Bernie
@bernie
Old 01-01-2010, 18:29   #14 (permalink)
Member: 1128235
i have the solution but plz contact me praivitly at my msn fiftycent_112@hotmail.com
Old 01-01-2010, 20:06   #15 (permalink)
Member: 126167
Sonork: 100.1591387
GPG universal inteface with ns pro
Hi Bro,
This is not a private issue, if you post a solution on not , .
hassanjinja
GPG Universal Interface Now released! GPGIndustries Latest GPGIndustries News 115 06-08-2011 14:53
GPG Universal Interface Box with Nspro 69eyes GPGInterfaces - www.gpginterface.com 5 12-18-2009 10:09
GPG Universal Interface What can it be? GPGIndustries Latest GPGIndustries News 41 10-30-2009 16:13
NEW!!HOT!! Cyclone box ,GPG universal interface,UFC V2 cable,TMA v2 cable on stock gsm-sources Main Sales Section 0 09-09-2009 16:53
<<<<< HOT Products: GPG-HUB, GPG Universal Interface, GPG Red Cable >>>>> sagtel Main Sales Section 0 08-10-2009 07:13
Page generated in 2.10257 seconds with 11 queries
